Results 1 to 7 of 7
    118
    Question Why is there a queryport timeout when using servernotifyregister?
    Hello TS3-Devs,
    can you tell me why I get disconnected after a few minutes even when I've used "servernotifyregister" on the query port?
    I do understand that there is a timeout for queryport connections but "servernotifyregister" is to get callbacks and I think it doesn't make sense to disconnect "listening" clients.
    Maybe I'm doing something wrong and the sudden disconnect is my fault but I believe its TS3 server.
    Thanks,
    SCO
    September 2005
    Germany / Dortmund
    1,376
    I'm no developer, but perhaps my answer is still helpfull.
    Honestly, I didn't test, if there is a timeout even if I register to an event, but if you say, I believe.
    I always do a little workaround for not getting a timeout.
    After a given interval I send a nonsense command, "help" or "whoami" to the server.
    And when I send a "real" command, I reset the timer.
    I know, this is not the satisfying answer you are waiting for (and as well it isn't for me), but to avoid the timeout, I think that's one possibility.
    118
    I'm already doing a Version-Command-Call to get around the timeout. Just wanted to know if this is a wanted behaviour.
    Thx,
    SCO
    18,513
    Yes this is volitional. When there is no need to hold the connection, you will get timed out.
    118
    But when registering for notifications, there is a need for holding the connection. So why is TS3 cutting the connection even when I've sent a servernotifyregister?
    I would suggest:
    - cut the connection when the client has not registered for receiving notifications
    - do not cut the connection when the client has registered for receiving notifications
    July 2006
    1,600
    A feature that I would suggest to be implemented IF the timout behaviour gets changed would be that a query superadmin has a command to cut query connections off a specific server or globally from the instance if the likes to.
    October 2003
    2,527
    Sorry guys! This is working as intended and will not be changed...
  1. [PHP] servernotifyregister ?
    By Compix in forum General Questions
    Last Post: July 29th, 2010, 07:55 AM
  2. TS3 Queryport ändern
    By xDGeForcexD in forum Off Topic
    Last Post: March 28th, 2010, 12:23 PM
