Results 1 to 5 of 5
    January 2009
    US
    46
    Question PTT Not Recognized
    I had been using a Logitech G5 mouse, and had button 4 assigned to my PTT (push to talk) and everything worked just fine. I changed to a Logitech LX8 mouse and set my PTT to button 4 again (its a side button on both), Teamspeak allows me to set the button, but then fails to recognize it when i try to use it.
    January 2009
    US
    46
    looks like this got overlooked
    January 2009
    US
    46
    Is anything going to be done about this? I mean, its pretty sad that mouse buttons worked in TS2 and not TS3 for things like PTT. What's the deal here?
    October 2006
    San Antonio, TexASS | USA
    85
    I moved from a Logitech G5 to a G9, I had this issue as well, sadly someone in the mouse drivers causes this issue...
    I had to use the unhide Command Line string (CMD in Windows) to show the old mouse, uninstall it, uninstall the old setpoint if you had it, uninstall the new mouse, restart the pc (keyboard it, windows key + r, brings up run menu, type in shutdown -r -t 01 ) let it install the default drivers for the mouse, then reinstall the latest setpoint (make sure to get the latest... so many problems with older box supplied versions), then try again
    that worked for me, should work for you, but only trying can you find out :P
    January 2009
    US
    46
    Lightbulb Fixed
    I actually found the solution just recently. Apparently, the button I am using on the wireless mouse is set up as a momentary switch by default. Meaning, when you press it, it signals and releases itself no matter how long you hold it down.
    The solution to this was in the Logitech Setpoint software. The button assignments that are listed show button 4 (the one I use, which is the left side button) is marked BACK for use in document control and things like IE browser history control. If you set this to GENERIC it changes from a momentary switch to a normally open switch, thus when pressing and holding, it sends a constant signal, allowing the PTT to work properly.
    As for the original functionality, I have not noticed a change in software control by changing the type from BACK to GENERIC. My IE history still goes back a page anytime I press it over an active IE window.
  1. TS3 Microphone not being recognized
    By Shingles in forum Windows
    Last Post: November 18th, 2013, 03:19 AM
  2. Soundpack not recognized
    By LIMBSAVER in forum General Questions
    Last Post: April 25th, 2013, 08:36 AM
  3. Skins not recognized?
    By UW-SoulReaper in forum Skins / Icon & Sound Packs
    Last Post: December 30th, 2009, 12:05 AM
