Results 16 to 30 of 53
  1. #16
    25
    Thank u
    If u have more wishes or suggestions tell it me.
  2. #17
    German
    A great skin!!
    But I have a request, the links are in the channel description, and the channels in Textlog, too blue, I do not see so well, could you possibly tell me the code / post where I could adjust for these matters a different color? For example, green ....
    Would be very grateful for this
  3. #18
    25
    Thx for the compliment.
    I wanna make a final version without bugs and different text colors.
    So just wait for that i have lust to work :P
    But thx for ur inspiration.
    I writed it to the To Do List.
    Greetz _,,.->DarkCode<-.,,_
  4. #19
    Malmö
    11
    I liked your skin but i wanted it changed only a minor.
    *Changed 4 lines of code.
    *New pictures
    *Sorted out the whole code so it would be easy to read (for some reason it was a mess when i opened it with dreamweaver or QTcreator)
    Will post screenshot, but will only post the pakage when the original creator approves it
    [Screenshot]
    PS, Left and Right img is a small img (184x120) but it repeats itself just nicely. Bottom img is fixed so it wont repeat, if you want carbon on that also i will change it.
    Edit:
    Found a bug; Moving tabs in TS3 makes them black.
  5. #20
    October 2006
    San Antonio, TexASS | USA
    85
    Galactca... I WANT...
  6. #21
    25
    Hi Guys,
    @ Galactica:
    Thx for the Bug report and nice that u like the Skin (or the most of it ^^)
    Generell its ok if u change it for urself or friends and send it with icq or some else.
    But dont make it public.
    Bugs and errors are opend then too if some in there.
    Mybe cous wrong formating or some else.
    Well, the file is very strong formated, so its a very small file!
    Fast to loading and friendly with the client ^^
    @ least i will look that i fix all known bugs (black Tab while moving)
    and add a few new features, like the different Link color.
  7. #22
    Malmö
    11
    about the bug its odd but i tested few other skins like bluesky and someones l4d2 skin and it seems that all of them have the same issue. (only different look)
  8. #23
    Eastern Us
    68
    I love the theme only thing I'd like to see is the background for the chat be lighter maybe some kind of gray the red and blue texts on that dark seem a little hard to read
  9. #24
    25
    @ Galactica:
    Ya in TSł are a few Skin bugs, who arent a part of the Styles.
    They´re part of the Client! But in later future they will be fixed.
    I written a list off all known bugs, and report was sent out too.
    @ DonkeyP:
    THX ! Nice that u like it
    I wanna make different text/link colors in the next version.
    So just wait a litle bit.
  10. #25
    berlin
    very good skin, good work.
    thank you
  11. #26
    October 2006
    85
    DarkCode, any way you can take what galicta did for cleanup and redo yours with it (not the style totally, but the code behind it... im a clean freak ok?)
    Additionally is it also a client side bug that makes the check/radio options not show up properly with your skin? (like you cant see the normally black X in the box when you click it, IE go into edit channel and change the option from permanent to temporary and you cant see it
    Thanks
  12. #27
    25
    OK...
    its nice for u if u a "clean freak" ^^
    I know that felling but u have to take ur choice if u want see my TSł Style or the Recourse Code.
    So after i formated and compressed the qss file i dont redo all the work.
    Well... i dont know or im not able to remake ur bug, so plz take a screenshot.
    What u can try bevore! is to restart ur client after chose my style.
    Sometimes the problem is that the different skins overload an other, if some objekt are not written in the style.
  13. #28
    October 2006
    85
    Question
    heres a SS of the issue... the style setting doesn't seem to matter at all (well windows default and some of the other ones make the RADIO buttons reappear but not the checkbox's)
  14. #29
    dE
    Hey sehr schöner skin kann ich auf jeden fall empfehlen
    Oo
  15. #30
    25
    Lightbulb
    Hi aigan!
    For the first i list all bugs in the actually version:
    1. Server/Chat Tab moving make them black (Client/Qt bug) @ Galactica
    2. Check/Radio are not visible (fixed in final version)
    Quote Originally Posted by DSCKerry View Post
    3. Server/Client Log are not visible (Client bug?)
    Quote Originally Posted by jlt1087 View Post
    I like this skin, it's awesome. But I have a problem with it. When I go to look at the server log, It's a completely black background with black text, therefore, making it unreadable. Can you fix that issue?
    - - -> to fix it go to ur Server/Clientlog window and press the Highlight button
    - - -> pic the message u want and change the font color to white.
    The blue text/link color in the chat and channeldescription
    will be possible in future client versions.
    So the skin dont get a change for it.
    At least i can tell u,
    that im nearly finished the final version of the Dark Code Style.
    Pictures will come later in this Tread that u get a litle Preview
    Its a nice remake with clear lines and some nice effects.
    Well... cya and look for the next Post
  1. Dark Star Trek Online Style for v 3.0.14 and FullHD Screens
    By ZuiMelanieForno in forum Skins / Icon & Sound Packs
    Last Post: May 24th, 2015, 04:19 AM
  2. Replies: 0
    Last Post: June 8th, 2014, 10:58 AM
  3. Replies: 1
    Last Post: May 1st, 2014, 05:34 PM
  4. Dark Code Black
    By ZiFFi in forum Off Topic
    Last Post: November 11th, 2012, 07:40 PM
  5. [Skin] PS1D3R Dark Skin
    By Sp1D3r in forum Skins / Icon & Sound Packs
    Last Post: May 26th, 2010, 01:17 AM
