Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 118
  1. #61
    June 2010
    germany
    11
    Tried the latter approach, did not help.
  2. #62
    April 2010
    moon
    I just now fixed my own 0xc015002 by installing Visual C++ redistributable! Joy. I really should have checked event log sooner
  3. #63
    June 2010
    germany
    11
    I checked my event logs, there is nothing about this error in it.
  4. #64
    June 2010
    Unhappy Canīt start Teamspeak
    HI
    Im new here, because I need help.
    I have reinstalled Windows XP, yesterday. Now I wanna Start Ts3, but I Canīt.
    Anytime I wanna start Ts3 this Error Message http://img256.imageshack.us/img256/9...mspeakfail.png (this is a german Error message I hope you can read it) comes.
    I deletet Ts and Installed the newest Ts. But allways the same error.
    I hope you can Help me.
    Sry for my Bad English.
  5. #65
    June 2010
    Italy
    9
    I've Antonio's same problem and i try to follow both the solutions posted by Peter but nothing's changed. I report my problem in another post anyway when i start ts3 a process appears in the task manager for a few istant and then disappears, the tray icon disappears when i run the mouse over it.
    Nothing on my event viewer
  6. #66
    June 2010
    germany
    11
    Problem solved.
    I installed the latest DirectX (June 2010) and the lastest Catalyst (I updated both before without any positive results, now I noticed newer versions of both were available).
    After that theTS3 Client works again. I would recommend to first try DX and then the Display Driver for those getting the dreaded 0xc0150002 bug.
    It eludes me, though, why this advice was not given by the developers...
  7. #67
    February 2006
    Texas, USA
    4,143
    The devs don't have all the answers. I'm happy you found a solution to the problem and thanks for posting it in here so the devs will have a solution for future questions.
  8. #68
    June 2010
    germany
    11
    Sure. But something this obvious...
  9. #69
    June 2010
    Italy
    9
    I have just tried with directx and it doesn't work.. I'm tryin with catalyst now..
  10. #70
    July 2010
    Poland
    Error while ts3 starting
    Hi. when i turn on Teamspeak 3 i have this error
    http://img185.imageshack.us/img185/5272/36406375.jpg
    i dont know what i need Do .. before it i have reinstal Windows and instal sound drive.. other programs conditions is good..
    in Google i read to i want MSVS2008 buy i dont know where I download it :
    Plz help
  11. #71
    August 2010
    germany
    error message 0xc0150002
    hello,
    i have download the teamspeak3 32-bit client and install teamspeak and every time when i start teamspeak 3 i get the error message : The application failed to initialize properly. Click on "OK" ,to terminate the application.
    pleace help me
  12. #72
    July 2010
    netherlands
    Exclamation error
    If I want to open Teamspeak 3 i get an error (its dutch BTW).
    there is standing "Kan de toepassing niet juist initialiseren (0xc0150002). Klik op OK om de toepassing te beëindigen.
    Can someone pls help me??
  13. #73
    September 2010
    Running Problem
    Hello Users I have a problem with TeamSpeak 3!
    I have the following error message ts3client_win32.exe (The application failed to initialized properly (0xc0150002). Click on OK to terminate the application.
    This error message always appears when I try to run the exe.
    I tried reinstalling already has brought nothing. Work with Windows Vista Home.
    Nvidia Geforce 8600gt
    4gb Ram
    Amd Athlon 64 X2 5000+
    Greetz DonToni
  14. #74
    May 2010
    Hello to all,
    I fixed the problem,... well it seems so. I hope it will work for a longer time.
    since Beta20 the TS3CLient crashed directly after startup. Exactly the problem which was discussed here but without the error report.
    Since then i tried every thing. Last weekend I reinstalled windows.
    I use Windows XP with the newest drivers and nothing else installed. TS3 didn't work. With Win7 on the same Computer it worked -.-
    so it couldn't be problem with hardware.
    I installed ALL Frameworks an all dll wich was mentioned here... nothing worked.
    I uesed a win XP pro version without anyservice pack. So I insstalled SP3. But it doesn't help.
    But then I used the com Updatepack Buillderto install Windows updates.
    I can tell that after SP3 there are not so many updates left. But I had not enough time to test every update. So I installed at first all framework updates.
    -> TS3 didn't work.
    Then I installed all the other updates for XP... restart... and it works =D
    I don't know why but there must be an update which influence the needed dlls or something else.
    Mybe some of you guys which the same problem can look up which update is needed for TS3 and can write it so the developer can help other people faster. Or build it into the next beta...
    best wishes
    Killerregenwurm
  15. #75
    May 2010
    6,310
    @Killerregenwurm
    Thank's for this report.
  1. failed to initialize properly
    By grof5 in forum Windows
    Last Post: April 27th, 2014, 11:44 AM
  2. Replies: 1
    Last Post: July 4th, 2011, 03:36 PM
  3. Failed To Initialize (0xc0150002)
    By Farss in forum Windows
    Last Post: May 21st, 2010, 06:25 AM
  4. Failed to Initialize
    By jdrambam in forum Windows
    Last Post: February 12th, 2010, 02:45 AM
