Page 1 of 2 12 LastLast
Results 1 to 15 of 26
    The Netherlands
    6
    [Solved] Limiting total disk space per virtual server and total traffic
    I've watched the YouTube video's for ATHP's and want to follow the proposed suggestion to offer different TeamSpeak packages (with and without file sharing).
    However, I find myself with a pretty big problem and that is limiting the total amount of disk space being used per virtual server. I cannot seem to find a setting to limit this. For example, if I want to provide a package with 250 MB total disk space and 10 GB traffic per month, I cannot do this from within TeamSpeak.
    I would like to suggest to make a total traffic limit setting. For example limiting the cumulative upload and download traffic to X GB per month. And also create a setting for the maximum amount of disk space a virtual server can use at any given time.
    Is such a feature / setting in the making?
    June 2002
    Krün / Germany
    1,638
    bandwidth limiting is already possible, diskspace limiting we dont support.
    Germany, Siegen
    23
    But why not? It is very important for Hosters!
    1500 Servers, every Server use 500 MB Space, 750 GB HDD ! I think that there must be a resolution!
    23
    @sebuch
    Disable it and sale it as an option.
    Like Teamspeak Systems planned it.. take a look ATHP Podcasts.
    April 2006
    8
    honestly, you made ts3 now so fucking very customizable and flexible, why not add this feature as it is really helpful and usefull too ?!
    Germany, Siegen
    23
    If i do that, the users cannot upload Avatars... Thats stupid.
    23
    Quote Originally Posted by sebbuch79de View Post
    Sure you can.
    Do not disable Bandwith but disable the Quotas by set it to 0
    Germany, Siegen
    23
    Okay thank you but in the TeamSpeak 3 Podcast for ATHPs (part 2 of 2) Video they talk about Hosting plans. Example:
    1 GB Space, 100 GB File Transfer per mo.
    But how can i control the 1 GB Space? The 100 GB File transfer can i set with the down/upload quota.. i know.
    April 2006
    8
    external programs will make the trick
    i am not sure, but I think "monit" should be able to do so for example...
    Germany, Siegen
    23
    I have one question about the download/upload quota.. ist it per month? Know the Teamspeak that the month ist over?
    18,414
    Yes it is per month
    Germany, Siegen
    23
    But when does the Month "starts" for Teamspeak Server and when does it "ends" ?
    1. - 29./30./31. ?
    Sorry for my questions
    18,414
    It starts
    1. 00:00 and ends last day of month 23:59:9999
    Next start is
    1. 00:00 ........
    Germany, Siegen
    23
    Thank You!
    Switzerland
    6
    Quota
    As for you guys asking for a quota system.
    - doing quota in an application is always a quirk and not reliable. What happens if you put in (or delete) a file manually on the serve? Well, one could recalculate it every day or so, but on a filesystem with many many files this takes ages.
    So, it's always better to leave this to the OperatingSystem, well to be precise, to the FileSystem of the OS.
    If you're planning on using a Windows based server, you're in luck, as there you have the best possible solution: "Directory Quota"
    There you can set, with a nifty GUI or via command line, a quota to a directory (e.g. [ts3_serverdir]/files/virtualserver_1)
    All files that go in or our of this directory will be counted immediatly and as you can also set a warning (soft) limit with built in email notification, it's also easy to alert your customers abouth reaching the limit of their disk space.
    On Linux it might be a bit more complicated, as you can just use user/group based quotas.
    A workaround would be, to remount the ts3 virtualserver directorys as independant/virtual partitions and limit the diskspace this way.
  1. 2 virtual servers = 124 slots on each or total?
    By Vahx1987 in forum Off Topic
    Last Post: November 16th, 2014, 03:01 PM
  2. How much Disk space is needed for Logs on a server?
    By Trunkz Jr in forum General Questions
    Last Post: August 19th, 2013, 08:04 AM
  3. [Resolved] NPL, 512 for each server or total?
    By Seegurke in forum General Questions
    Last Post: May 21st, 2013, 05:26 PM
  4. Total Uninstall For Ts in my Centos Server
    By nikeddy in forum Linux / FreeBSD
    Last Post: April 9th, 2013, 01:42 PM
  5. Total Server Access
    By tim478 in forum Windows
    Last Post: September 16th, 2010, 09:01 AM
