Page 3 of 55 FirstFirst 123451353 ... LastLast
Results 31 to 45 of 820
  1. #31
    italy
    23
    Quote Originally Posted by Lil-rich View Post
    the groups with the green icon are template groups! You must NOT change or delete them...
    i see that groups (4,5,6) just only from web_tool and that are not signaled as template..
    How can be used them?
  2. #32
    7
    Number 3, 4, 5 are the templates and Temporary Groups
    Best Regards
    Helmut
  3. #33
    February 2009
    416
    Parse error: syntax error, unexpected T_STRING, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or '}' in /var/www/web0/html/ts3wi/ts3admin.class.php on line 35
    And now?
  4. #34
    UK
    88
    Quote Originally Posted by nsateam View Post
    And now?
    You need to have php5 to run this script.
    If you have it installed on your server but not running as default, add a .htaccess file to the 'ts3wi' directory with the following added:
    SetEnv DEFAULT_PHP_VERSION 5
  5. #35
    February 2009
    416
    Ok thank you i dont have see the information... Lets work it.
  6. #36
    January 2008
    Spain / salamanca
    very good, nice panel
  7. #37
    Deutschland
    140
    Beta 1.5 available for Downloadlink and Changelog look at the first post.
    Greetz
    Psycho
  8. #38
    UK
    88
    I have an error while changing server slot count on the edit server screen:
    Error while fetching: 'error id=2568 msg=insufficient client permissions failed_permid=9005'
    Admin Server Qery login is fine as all other commands work, and 'serveredit' command works in Putty using same login details.
  9. #39
    Deutschland
    140
    RogueT
    Permid 9005 is the welcomemessage pls check at the servergroup permissionlist whether the permission 9005 has been altered.
    MfG
    Psycho
  10. #40
    Portugal
    7
    Question Help
    sry for my ignorance, but when you say unpak to web folder do you mean "c:\windows\web"?
    if so, when i go to config.php the ip address e see is my localhost, do i have to change it? and the port is 10011, do i have to change it too? if so what ip do i change for, my local network or my dyndns name, and the port do i use 9987 default one?
    plz help.
    Best regards
  11. #41
    Deutschland
    140
    you need first a Webserver with php5 support.
    Then you unzip the .rar file in the folder where you can open the files with your browser.
    For example you use xampp on your pc:
    the web folder is xampp/htdocs then you unzip the package to htdocs
    open your browser and write as url http://localhost/ts3wi
    i hope you do understand what i mean
    If the Ts3 running on your PC and the webserver is running on your PC the ip is 127.0.0.1 and the port is default 10011 but if you change the port at the server install you must need this port.
    Greetz
    Psycho
  12. #42
    April 2008
    Next to Hannover
    212
    i find the interface verry well.. go on :-)
    In teamspeak 2 was the navigation on the left side. can you create one style, that the navigation on the left site?
    and can you bulid an serverlog viewer, for only the one server?
    i mean if you slect one server (server 9987) you see only the log of the server 9987, not the global log.
    the new funktions (kick,ban etc) does not permanently work.
    sometimes if I have try to kick me, then I was on a other server page. form serverpage 5050 to serverpage 9987.
    whats wrong?
  13. #43
    Deutschland
    140
    I don't know what is the Problem with the kick. If i try something its work perfect. o.0
    The new version will be have only left a menu because i need more place for new links.
    //Edit:
    I found the Bug with the Kick problem
    It will be fixed in the next version.
  14. #44
    April 2008
    Next to Hannover
    212
    Uiii O__O
    If I were a woman I would marry you xD
    when do you publish you the next version?
  15. #45
    9
    I wish a channel backup funktion and a Traffic Server List but very nice job until now...
    mfg Terrier
    Looking forward to the next version... and I hope that my wish will be fulfilled...
  1. Replies: 0
    Last Post: July 19th, 2014, 11:12 AM
  2. [DEV] Ts3 Webinterface
    By Psychokiller in forum Client Plugins / Lua Scripts
    Last Post: May 13th, 2011, 12:51 AM
