Page 48 of 55 FirstFirst ... 384647484950 ... LastLast
Results 706 to 720 of 820
  1. #706
    May 2010
    Austria
    13
    if your webinterface is hosted on an external webhost which is blocking in/outgoing traffic by ports you have to open the ports first to get it working... in this case ask your support to open the ports for you...
    outgoing ports
    TCP:10011
    OUT:9987 (or which port ever you may use fpr ts3)
    both on your ip where your ts3 is located...
  2. #707
    July 2009
    Australia
    34
    Hey Psychokiller, i just upgraded from 2.9.1 or something to 3.1 and in the log viewer it comes up with only has "Show more entries" but when i click on it the page refreshes/loads and nothing else comes up. the logs are blank
  3. #708
    December 2005
    Colorado
    75
    Hi
    I Am Tring to set up the WebInterface but when I got to log in I get this error
    Error in connect() on line 3347: Error: connection failed!
    Error in login() on line 2090: script isn't connected to server
    Message of the day
    This is a box for a message of the day.
    You can turn it on/off on the config.php
    The text can be changed on the motd.txt on the main folder
    Login
    Server:
    Username:
    Password:
    Port:
    Option:
    Host Login
    how do I fix this error and also where do I get the password to log in the password I was useinig was the one that was in the config.php and can I setup diff log ins so my other admins can have access to it? thanks
    tbarlow
  4. #709
    November 2010
    11
    Quote Originally Posted by chackonman View Post
    you must be deleted all older files and new fresh install from 3.1.
    Sry for my bad english i'm german guy
  5. #710
    July 2009
    Australia
    34
    Yeah i deleted it all through a ftp program, then re uploaded and still the logs show nothing
  6. #711
    April 2010
    The Netherland
    24
    All channel deleted
    So this morning i connected to my teamspeak server and everything where gone.
    Luckely i make dayly backups and could restore it easily but i dont like it to happen again.
    How is this possible and what should i do to protect my server against it.
    The server version is 3.0.1
    I run linux, but there is no log that shows a breaking through linux so it should be done by serverquery.
    if you need more information plz ask.
  7. #712
    May 2010
    6,310
    There is no "hack".
    You have to check you entire permission system. Every time it's just a bad permission on server group.
    Accordgind the server log, look the first actions did by this bad guy and you will find where is the permission problem.
    I have a little time, so if you want you can send me in private message, the log and the database. I'll help you to find where the bad permissions.
  8. #713
    April 2010
    The Netherland
    24
    Well that is to bad, i though of that to after i restored the update.
    So the logs where reset and so did the database.
    In my knowlage my permissions are not able to delete channels.
    you may try it your self is you want.
    BTW, how could it be that all my virtual server where gonne to?
  9. #714
    February 2006
    Holland
    Now it happend again.
    I am a mate from Burnacid
    The guy simple connects to our server and already have admin rights.
    Where can i find the log file?
  10. #715
    Catalunya
    2,350
    In the server's installation directory, folder "logs"
  11. #716
    April 2010
    The Netherland
    24
    According to research he hacked the TeamSpeak 3 Webinterface by Psychokiller
    We deleted it and changed all passwords of the serverquery
    Edit by mod
    According this information, thread merged.
  12. #717
    244
    Is your installation of webadmin up to date? An older version had security issues.
  13. #718
    December 2011
    So Ive read multiple posts about this and multiple website (mainly .de so I cant understand lol)..
    How do we fix the following issue:
    Error in connect() on line 3313: Error: connection failed!
    Error in login() on line 2060: script isn't connected to server
    This is a fairly new Error from what Ive noticed. Was working 100% for the longest time until recently! Need this fixed asap..
    Any ideas?
    I can connect via Telnet without any issues. Not a problem with the config.php Ive checked. It was working for the longest time.
  14. #719
    July 2009
    Australia
    34
    Quote Originally Posted by dcFaded View Post
    Any ideas?
    if you have localhost as the address in the config, try the actual IP of the server
    --- Merged ---
    also still having a problem where the logs are not showing.
  15. #720
    December 2011
    Thats not the issue.
    I have this script on a Webserver completely seperate from the Teamspeak3 Server. Everything was 100% functioning till the most recent update.. (I think)
    Config.php is fine :-X
  1. Replies: 0
    Last Post: July 19th, 2014, 12:12 PM
  2. [DEV] Ts3 Webinterface
    By Psychokiller in forum Client Plugins / Lua Scripts
    Last Post: May 13th, 2011, 01:51 AM
