Page 49 of 55 FirstFirst ... 394748495051 ... LastLast
Results 721 to 735 of 820
  1. #721
    July 2009
    Australia
    34
    anyone got a download link for 2.9.1? or atleast a fix for the server logs not showing
  2. #722
    Updated to latest Beta. Got 500 Internal Server Error.
    Any suggestions?
  3. #723
    Netherlands
    76
    Quote Originally Posted by dcFaded View Post
    So Ive read multiple posts about this and multiple website (mainly .de so I cant understand lol)..
    How do we fix the following issue:
    Error in connect() on line 3313: Error: connection failed!
    Error in login() on line 2060: script isn't connected to server
    This is a fairly new Error from what Ive noticed. Was working 100% for the longest time until recently! Need this fixed asap..
    Any ideas?
    I can connect via Telnet without any issues. Not a problem with the config.php Ive checked. It was working for the longest time.
    I'm having the same problem. I dont know why this is happening.
    Update:
    Rebooted the webserver. And it's working fine now. Don't know what it was.
  4. #724
    Nevada
    12
    I am having same problem
    I have ports
    9987 UDP
    10011 TCP
    30033 TCP
    all open and TSViewer works on site but the TS3 Admin WebInterface gives me the same error message
    http://f.cl.ly/items/3F2p2C0m052F3j1...21.16%20PM.png
  5. #725
    March 2011
    70
    Hi.
    How do I use Psychokiller's WebInterface if I host with gamesevers.com or instantteamspeak.com....???
    On the login screen, what is the username and password that I need to enter.
    I made the changes to the config file but I still cannot get anywhere.
    Can someone please help??
    Thanx.
    --d.
  6. #726
    244
    1. You need to have the good ports open on your webserver (if it's on a rented one, you've got 99% chance the outgoing ports are not open and you'll need to ask your web hoster). If you run it locally it should be good.
    2. Create a query account on your teamspeak server (if you can, most providers blocks it) (Tools - ServerQuery Login)
    3. Try again, and if it doesn't work, give us more informations....
  7. #727
    March 2011
    70
    Thanx for the responce TotolsBack.
    Ok, this is what I have done.
    ONE:
    In config.php I have this (Installation instructions talked about a config.cfg file but I could not find it. I found this config.php file):
    $server[0]['alias']= "Lokaler Server";
    $server[0]['ip']= "1.2.3.4";   // My TS server's IP with gamseservers.com
    $server[0]['tport']= "5555";  //  Query Port for my TS server on gameservers.com
    TWO:
    I have also gotten the admins on gameservers.com to add the IP address of my domain name on Godaddy to their query_ip_whitelist.txt. Then I have re-booted my TS server. I have installed this addon in a sub-directory of this domain name and calling it like so: www.domain.com/ts3wi
    THREE:
    I have also created a Query Login Account via my TS client and made sure that gameservers.com supports it. I am using this username/password pair to login at http://www.domain.com/ts3wi/index.php
    But this is the error it is giving me:
    Error in connect() on line 3347: Error: connection failed!
    Error in login() on line 2090: script isn't connected to server
    Can you please help...??
    Thanx,
    --d
  8. #728
    244
    Once again, are you sure that www.domain.com (your domain server) have the outgoing ports open ?
    you checked the whitelist that's good, but now you have to be sure that the connection can be made from your webserver to your ts server.
    I suppose the problem is there, the ports on your webserver are closed on the outgoing side (webserver -> ts server).
    Ask your web hoster if the needed port (query) is open and not blocked, and if not, if they can do it.
    The reste looks good to me for now
  9. #729
    March 2011
    70
    Ok, you were absolutely right about the webserver not allowing that port to go out.
    So, I moved the addon to my local machine and installed it on my local webserver.
    I was able to log in without any problems. But I am not sure exactly where I have logged into....
    I have attached a pic of the screen that I see after I log in.
    Seems like it is a control panel of some sort of a bunch of TS servers.
    How do I log into MY TS server and see the screen and manage it as Psychokiller's snapshots show....???
    Any idea as to what is going on here...??
    Thanx much,
    --d.
  10. #730
    244
    Lol, looks like you listed all the virtual servers on one instance of your hoster ^^
    you can try to find yours in the list and try to edit it (btw you could try the others to and if you can, contact your hoster and tell them about it as a big security issue in their configuration of query permissions).
    The thing is that that one instance with several virtual servers will share the same query port.
    So normally, your login/pass should give you only edit and other SA permission on your server, not the others (on the others you should only have GuestQuery permissions).
    Curious about this, could you confirm all of this ?
  11. #731
    March 2011
    70
    I tried to STOP another server that was not mine and it did not let me do it, so I think they are secure enough.
    But, as far as my server is concerned, even though I see it in the list, the only options that are in the drop-down list is START, STOP, DELETE.
    How do I actually manage it using Pychokillers add-on...???
    Thanx.
    --d.
  12. #732
    244
    try to click on the name of the server
  13. #733
    March 2011
    70
    Ahhhh.....right...thanx.
    Do you know if there is any way for me to not allow my admins to create channels AND not to have the power to grant others Admin-status, from within this interface....???
    Thanx for all your help.
    --d.
  14. #734
    244
    for this you should create another group and restrict the permission and add them in this new created group.
    Personally i suggest to never add someone else on the SA group other than yourself.
    For the reste, make group copy/new group and give/restrict permission (don't forget to reduce the powers to below 75 and let the needed to 75 on the permission you want to be the only one to be able to modify).
  15. #735
    March 2011
    70
    Understood.
    Thank you very much for your time and patience.
    Best,
    --d.
  1. Replies: 0
    Last Post: July 19th, 2014, 12:12 PM
  2. [DEV] Ts3 Webinterface
    By Psychokiller in forum Client Plugins / Lua Scripts
    Last Post: May 13th, 2011, 01:51 AM
