Page 52 of 55 FirstFirst ... 2425051525354 ... LastLast
Results 766 to 780 of 820
  1. #766
    November 2012
    I'm clic for login, is pass and after i'm clic for select me virtual server, and is come back in the login page
    I do now, but now this error come
    Error in connect() on line 3411: Error: connection failed!
    Error in selectServer() on line 2271: script isn't connected to server
    Thank you
    EDIT: Is work now O-o.
  2. #767
    June 2012
    Hi all. I have a problem with the web panel displays me the following error: Error in login () on line 2090: You got banned from server. Socket closed.
    The panel is on the hosting and vps server on the machine and added whitelist check where your ip and ip hostigu but the problem still appears panel install 3.3 and earlier version if someone tells me I can be the problem?
    I'm Sorry my english
  3. #768
    February 2013
    47
    I have same problem.
    1.Add the Ip from your webserver into the query_ip_whitelist.txt
    2.Edit the config.php with the correct data!
    <?php
    *Copyright (C) 2012-2013  Psychokiller
    *This program is free software; you can redistribute it and/or modify it under the terms of
    *the GNU General Public License as published by the Free Software Foundation; either
    *version 3 of the License, or any later version.
    *This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY;
    *without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    *See the GNU General Public License for more details.
    *You should have received a copy of the GNU General Public License along with this program; if not, see <http://www.gnu.org/licenses/>.
    if(!defined("SECURECHECK")) {die($lang['error_file_alone']);}
    REGARD!!
    If you use the web interface, they must write the webserver ip in the query_ip_whitelist.txt.
    After adding the ip, the server must be restarted!
    Add more Server Ip's.
    For Example
    $server[0]['alias']= "Lokaler Server1";
    $server[0]['ip']= "127.0.0.1";
    $server[0]['tport']= "10011";
    $server[1]['alias']= "Lokaler Server2";
    $server[1]['ip']= "127.0.0.2";
    $server[1]['tport']= "20022";
    $server[2]['alias']= "altro";
    $server[2]['ip']= "127.0.0.3";
    $server[2]['tport']= "30033";
    $server[0]['alias']= "Altro";
    $server[0]['ip']= "xxx.xxx.xxx.xxx";
    $cfglang	=	"en";			//Language German = de, English = en, Netherlandish=nl (by pd1evl)
    $duration = "100";				//Set the Limit for Clients show per Page on Client List
    $fastswitch=true;				//If true you can switch the Server on the header
    $showicons="left";				//Define the position where the icons on the Viewer will show left or right
    $style="new";					//Chose your design  set 'new' for the default design or the name of your own create design
    $msgsend_name="Webinterface";	//This Name will be show if you send a message to a Server
    $show_motd=true;				// Set it to false to not show the message of the day window
    3.Set the folder icons, temp, templates_c, site/backups and all subfolders from backups chmod 0777 (cpanel)
    4.Open the index.php with your Browser!
    5.Login with the Query Login Account Data!
    And
    why?can u help me? thk
  4. #769
    Germany / NRW
    74
    Hey,
    @Death_Balgor
    There are only 3 possibilities for your problem.
    1. Your IP/Port is wrong
    2. Your connection can't be established because of firewall limitations
    3. Your webspace blocks connections to other servers
    Check with telnet that you can connect to the queryport of your server (if you don't know how to do this then write me your IP and I'll check).
    If that's working you should check the limitations of your webspace.
    Best regards
    par0noid
  5. #770
    February 2013
    47
    change the host site, and all went well on the first attempt, thk
  6. #771
    Deutschland
    140
    Beta 3.4 is now available!!
    Download
    http://addons.teamspeak.com/director...chokiller.html
    Changelog:
    ! This version will not Work 100% with server versions < 3.0.7
    * Add french to the language file
    * The server msg field on the serverlist is now a textarea field
    * The serverbackups will now sorted by date groups
    * The channelbackups will now save more settings
    * Add the new Codecs of server 3.0.7
    - Fixed bug with the permissionlists on server version 3.0.7
    Best regards
    Psycho
  7. #772
    Germany / NRW
    74
    Works very fine thanks
  8. #773
    January 2006
    United Kingdom
    12
    TS3 server version: 3.0.7 (Linux x86)
    Web Interface Version: Beta 3.4
    Additional Info:
    Just reverted back to Beta 3.3 web interface and this problem dose not exist there!
    so it is defiantly some thing to do with how the channel backup process has been updated for beta 3.4
    Channel Backup Bug Report:
    Problem:
    Channel backups are slightly bugged.
    Once a channel backup has been made, if viewed or deployed only the top level channels/spacers will be showing/deployed any sub channels are ignored even though they are present inside the backup file.
    Expected Result:
    All channels to be backed up and deployed.
    Repo Steps:
    1. Log in to web interface
    2. Select a server
    3. Change to channel backup section
    4. Create a channel backup
    5a. View newly created backup - only top level channels/spacers will be displayed.
    5b. Deploy newly created backup - only top level channels/spacers will be restored.
    The Original Server showing all channels
    The Channel Backup Viewer showing only top level channels (spacers in this case all have PID=0)
    The deployed back up.
    Channel Backup File showing all channels (to make it readable iv added a line break at the beginning of each ||)
    pid=0 channel_name=[spacer0]Founders\sArea channel_topic= channel_description= channel_codec=2 channel_codec_quality=7 channel_maxclients=0 channel_maxfamilyclients=0 channel_order=0 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=0 channel_flag_private=0
    ||pid=50 channel_name=The\sLounge channel_topic= channel_description= channel_codec=4 channel_codec_quality=10 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=0 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=1681784810 channel_flag_private=0
    ||pid=50 channel_name=Meeting\sRoom channel_topic= channel_description= channel_codec=4 channel_codec_quality=10 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=51 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=1681784810 channel_flag_private=0
    ||pid=50 channel_name=Server\sMaintenance channel_topic= channel_description= channel_codec=4 channel_codec_quality=10 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=52 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=1681784810 channel_flag_private=0
    ||pid=0 channel_name=[spacer0]Developer's\sArea channel_topic=Senior\sDevelopers\sOnly channel_description= channel_codec=2 channel_codec_quality=7 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=50 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=0 channel_flag_private=0
    ||pid=54 channel_name=The\sLounge channel_topic= channel_description= channel_codec=4 channel_codec_quality=10 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=0 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=-554498006 channel_flag_private=0
    ||pid=54 channel_name=Meeting\sRoom channel_topic= channel_description= channel_codec=4 channel_codec_quality=10 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=55 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=-554498006 channel_flag_private=0
    ||pid=54 channel_name=Work\sRoom channel_topic= channel_description= channel_codec=4 channel_codec_quality=10 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=56 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=-554498006 channel_flag_private=0
    ||pid=54 channel_name=Class\sRoom channel_topic= channel_description= channel_codec=4 channel_codec_quality=10 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=57 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=-554498006 channel_flag_private=0
    ||pid=0 channel_name=[spacer0]Public\sArea channel_topic= channel_description= channel_codec=2 channel_codec_quality=7 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=54 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=0 channel_flag_private=0
    ||pid=59 channel_name=Visitors\sChannel channel_topic= channel_description= channel_codec=4 channel_codec_quality=10 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=0 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=1 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=2142836834 channel_flag_private=0
    ||pid=59 channel_name=The\sLounge channel_topic= channel_description= channel_codec=4 channel_codec_quality=10 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=60 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=2142836834 channel_flag_private=0
    ||pid=0 channel_name=[spacer0]Gaming\sArea channel_topic= channel_description= channel_codec=2 channel_codec_quality=7 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=59 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=0 channel_flag_private=0
    ||pid=62 channel_name=Gaming\sArea channel_topic= channel_description= channel_codec=4 channel_codec_quality=10 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=0 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=2142836834 channel_flag_private=0
    ||pid=0 channel_name=[spacer0]Away\sFrom\sKeyboard\sArea channel_topic= channel_description= channel_codec=2 channel_codec_quality=7 channel_maxclients=0 channel_maxfamilyclients=0 channel_order=62 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=0 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=0 channel_flag_private=0
    ||pid=64 channel_name=AFK channel_topic= channel_description= channel_codec=0 channel_codec_quality=0 channel_maxclients=-1 channel_maxfamilyclients=-1 channel_order=0 channel_flag_permanent=1 channel_flag_semi_permanent=0 channel_flag_default=0 channel_flag_password=0 channel_codec_latency_factor=1 channel_codec_is_unencrypted=1 channel_flag_maxclients_unlimited=1 channel_flag_maxfamilyclients_unlimited=1 channel_flag_maxfamilyclients_inherited=0 channel_needed_talk_power=1337 channel_forced_silence=0 channel_name_phonetic= channel_icon_id=0 channel_flag_private=0
    Analysis:
    It seems only those channels with PID=0 are being shown and deployed every thing else is being ignored for some reason.
    i have tried this on three separate server im running and the result is the same across all three, only the top level (pid=0) channels or spacers will display or deploy.
    Last edited by Terminal-Access; March 6th, 2013 at 07:52 PM. Reason: Spelling, Layout
  9. #774
    Deutschland
    140
    Beta 3.4.1 is now available!!
    Download
    Changelog:
    - Fixed bug with the channel backup function. (All channel backups created with 3.4 are broken!) (thx to Terminal-Access)
    - Fixed bug with instanz server backup
    Best regards
    Psycho
  10. #775
    January 2006
    United Kingdom
    12
    Awesome downloading now, thanx Psycho xD
  11. #776
    March 2013
    What ports needs to be unblocked?
  12. #777
    April 2013
    I can log into the the webinterface but whenever I try to do anything it kicks me then when I try to reconnect it says this Error in login() on line 2306: You got banned from server. Socket closed. I've whitelisted every ip I could find that had anything to do with my webserver.
  13. #778
    York, UK
    23
    You need to restart your TeamSpeak server to make the changes to the whitelist come to effect.
  14. #779
    July 2006
    1,600
    Whitelist/Blacklist gets reloaded every 5 minutes
  15. #780
    York, UK
    23
    Quote Originally Posted by maxi1990 View Post
    Oh, Wow. Thats good.
  1. Replies: 0
    Last Post: July 19th, 2014, 11:12 AM
  2. [DEV] Ts3 Webinterface
    By Psychokiller in forum Client Plugins / Lua Scripts
    Last Post: May 13th, 2011, 12:51 AM
