Results 1 to 5 of 5
    July 2008
    canada
    77
    Question insufficient permission modify power Beta13 fix?
    is this something Beta13 will have to fix? I have newly installed beta12 servers using ServerAdmin tokens that receive these errors:
    <11:17:09> insufficient permission modify power
    and
    <11:20:11> insufficient client permissions (failed on b_client_issue_client_query_command (20626/0x5092))
    doesnt seem to matter if you are using a ServerAdmin token, or the ServerQuery Login user/pass, same result.
    Fix in Beta13?
    17,923
    When you get this errors? Did you enter it under Permissions / Use token?
    July 2002
    2,192
    Did you update from an older beta without adding the new permissions (like b_client_issue_client_query_command) to your groups? It looks like it...
    You think my answer is stupid ? Read This:
    http://www.catb.org/~esr/faqs/smart-...ons.html#intro
    In a world without fences and walls - who needs windows and gates ?
    July 2008
    canada
    77
    yes im using SA Token, and yes its from updated beta server linux files.
    but the virtualservers are new installs of beta12, default permissions
    these errors occur when clicking greyed out permissions under Server Groups
    is this something I have to fix on the linux server files or something I have to tell each customer to do with their SA Token?
    Secret Base in Arctic Region
    1,671
    Not all permission can be set as and for SA, some are reserved by default for the superadmin.
    Thats why you get the error.
    (At least this is what me understands what you asking for).
  1. Replies: 0
    Last Post: June 3rd, 2015, 02:05 AM
  2. insufficient permission modify power
    By CrazyFinal in forum Client Support
    Last Post: May 22nd, 2015, 04:44 PM
  3. insufficient permission modify power
    By Wiinchesterr in forum General Questions
    Last Post: April 5th, 2015, 01:58 PM
  4. insufficient permission modify power
    By Juzaa in forum Server Support
    Last Post: June 3rd, 2013, 04:13 PM
  5. insufficient permission modify power
    By mr-brown in forum Permission System
    Last Post: May 1st, 2012, 02:49 AM
