Results 1 to 4 of 4
    Pitt
    103
    [How-to] Portable Teamspeak 3
    1. Download 7zip
    2. Download a current version of TS3 client
    3. Open 7zip
    4. Navigate to your TS3 Client download location
    5. Right click on the .exe and press Open Inside
    6. Extract those files into a folder of your choosing (I used "TS3")
    7. Open the folder you extracted TS3 to.
    8. Navigate to $_OUTDIR
    9. Copy all the files in this directory
    10. Paste the files into the previous directory (Base TS3 folder)
    11. Launch TS3!
    *Note: I haven't fully tested this, as I just tried this at school on limited computers. I have no mic or headset. But it seems to work.
    June 2010
    South Africa
    Question Portable TS3
    Same idea here, only one problem.
    Your Contact list, saved passwords, and identities are in your "{USER}\AppData\Roaming\TS3Client" folder.
    Is there a way to change this so that they can travel with you to other computers?
    I also plan to use this at school.
    2,360
    You can install TS3 on a USB stick, just select global configuration while installation. Anything should be saved on the USB stick.
    May 2011
    Quote Originally Posted by Soljia View Post
    1. Download 7zip
    3. Open 7zip
    11. Launch TS3!
    The concept of TS3 portable whit 7-zip is impossible becasue TS3 depend of 2 runtimes:
    QT and Net.framework
  1. TS3 Portable
    By arsirc in forum Suggestions and Feedback
    Last Post: December 29th, 2009, 07:48 PM
