Results 1 to 11 of 11
    Massachusetts
    10
    Switch active microphone between servers? Solution AT BOTTOM
    Hello, I have set up several bookmarks so I can be connected to Several TS servers.
    Because the game I play when using TS will crash if I alt-tab, I have set up a hotkey to switch be to the next server in my list. HOWEVER, when I do this the microphone will not activate in that server.
    Am I using the Switch To Next Server function incorrectly?
    I have also tried setting a hot key to activate microphone - but this does not work either.
    Is the "Switch to" function not working properly yet, or am I going about this in the wrong way?
    If anyone knows how to make this work I would appreciate it.
    FYI - I am using Windows XP sp2 (I tried searching the forums but have not found the info.)
    Thanks,
    I forgot to mention I am using version 3.0.0-beta9 build (9592)
    Germany, Cologne
    1,364
    Try to use another Key to speak (I used ALT).
    If you connect to a 2. Server the first one muted the Mic.
    Massachusetts
    10
    Quote Originally Posted by SpWiRa View Post
    I'm not quite sure what you mean. I tried to set another button for talking....but it still only works on the last server I opened. Not the one I just switched to using a hot key.
    Also, if I try activate microphone it also does not work.
    Any other suggestions?
    Portugal
    492
    Hi
    Try this and see if it works:
    http://forum.teamspeak.com/showthread.php?t=49964
    Regards
    Massachusetts
    10
    Thanks for trying but it still doesn't work.
    I tried both setting a hot key for activate microphone and activate push to talk. But neither will do it.
    Germany, Cologne
    1,364
    You can only speak on one Server.
    All other will be muted the Mic.
    Massachusetts
    10
    Yes. But if I use a hot Key to switch servers I should be able to then only speak on that server. Don't you think?
    Massachusetts
    10
    WWOOHOO!! The answer is to set "Settings-->Options--->Applications-->Activate Microphone automatically"
    Now when I use my hotkey to switch active servers it will let me talk on whichever is active.
    Germany, Cologne
    1,364
    Learning by Doiing. Fine.
    Switzerland
    439
    No, learning by finding the answer in another post
    Massachusetts
    10
    Quote Originally Posted by PeterW View Post
    That would be learning by research!
  1. I wanna switch my servers IP address
    By wmj259 in forum Server Support
    Last Post: August 22nd, 2015, 10:39 PM
  2. Possible to have mic active on 2 different servers.
    By railto in forum General Questions
    Last Post: July 15th, 2010, 07:46 AM
  3. [Solved] Hotkey Switch Servers
    By InterCEptor in forum Client Support
    Last Post: March 7th, 2010, 11:47 AM
