Page 2 of 7 FirstFirst 1234 ... LastLast
Results 16 to 30 of 95
  1. #16
    118
    Quote Originally Posted by Theowningone View Post
    Apparently my host (and maybe others) sometimes refuses the connection randomly. Since the socket work is in the library thats where it generates the exception. I'm not sure if it's possible to handle an exception for a library, or if you've included a way, but when it happens it halts the program.
    Just catch the specific exception and retry it.
  2. #17
    New York, USA
    28
    Quote Originally Posted by Scordo View Post
    I tried:
    try
                    queryRunner = new QueryRunner(new SyncTcpDispatcher(serverip, queryport));
                catch (Exception ex)
                    Console.WriteLine(ex.Message);
    but to no avail, it still just stops responding and the program halts, i'm not sure of any way around this.
  3. #18
    118
    Send me a link to a file containing the source of your program and instructions to reproduce the scenario and I'll check this.
  4. #19
    New York, USA
    28
    I've sent you a PM.
  5. #20
    USA
    83
    Hrm, has this been tried in Mono on Linux?.
  6. #21
    New York, USA
    28
    I've released an updated version (1.2.0)
    New features are:
    Persistent connection (Bot will only connect once, and stay connected til closed.)
    Ability to hide window (Read OP for details.)
    Away Mover (Bot moves clients regardless of idle time if they have set themselves away.)
    Code optimizations and fixes thanks to Scordo.
  7. #22
    November 2006
    Netherlands
    24
    On startup it gives me the message testing connection and then it will say
    No connection could be made because the target machine actively refused it
    Ive tried running it from a different computer as wel as the server itself. Using its real IP but also its local IP.
    Any ideas whats causing this?
  8. #23
    New York, USA
    28
    Quote Originally Posted by Geoff View Post
    Have you checked to make sure the query port is correct? Depending on your provider the port may be different than the default.
  9. #24
    November 2006
    Netherlands
    24
    I'm the provider, Im sure it runs on 10011.
    EDIT,
    lets give you some more info on the versions
    OS: Windows 2k3 Server
    TS3 Server: 3.0.0-beta16 [Build: 9929] (win 32)
  10. #25
    New York, USA
    28
    EDIT,
    You're positive all the port numbers and host are correct? I just tried it on beta 16 x32 on my win7 rig and it connected fine. If you need to you can connect to my TS (ts58.gameservers.com, port 9109) or if you have msn you can add me if you need to, info is in my profile.
    If a mod sees this, can you remove the (v1.0.0) from the thread title please?
  11. #26
    November 2009
    Dublin, Ireland
    379
    im an admin server query, and when using this is tells me " invalid client permissions" yet on another serverquery program i can log into serverquery admin with no issues on the same user / password
    beta15 server linux.
    ******EDIT*********
    Working with beta16
  12. #27
    WI
    18
    EDIT,
    You host TS 3 from your house or local machine?Do you run the server and client on the same machine?
  13. #28
    November 2006
    Netherlands
    24
    Quote Originally Posted by Splicer View Post
    No I host my TS3 server from a dedicated server located in a data center. I run several game and voice servers on it.
    @theowningone Ill add you on msn.
  14. #29
    October 2006
    San Antonio, TexASS | USA
    85
    "Away Mover (Bot moves clients regardless of idle time if they have set themselves away.)"
    2 questions:
    On/Off option for this?
    Option to move client back to previous channel when the client clears away???
  15. #30
    New York, USA
    28
    Quote Originally Posted by DSCKerry View Post
    This I can add later.
    This doesnt seem doable. The only way to see that the person is not away is by querying, therefore they would have to wait to be moved back, at which time they could probably move themselves.
  1. Auto Poker and Mover
    By SplintDK in forum Client Plugins / Lua Scripts
    Last Post: December 16th, 2014, 07:38 AM
  2. Is there a way to get around the Team Speak Auto Idle mover?
    By SampsonNation in forum General Questions
    Last Post: March 11th, 2013, 04:17 PM
  3. [Rejected] IDLE mover?
    By Purifina in forum Suggestions and Feedback
    Last Post: November 17th, 2011, 12:56 PM
  4. [Question] Group mover ?
    By vexxx in forum Tools / Web Based
    Last Post: September 11th, 2010, 08:51 PM
  5. TS3 Idle Mover
    By PD1EVL in forum Suggestions and Feedback
    Last Post: June 24th, 2010, 09:22 PM
