Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 95
  1. #61
    March 2009
    Netherlands
    39
    Did you find out what's the cause of the error?
  2. #62
    April 2009
    242
    Quote Originally Posted by PSTJoker View Post
    I don't think that is entirely true. I have dedicated boxes, so I could be wrong.
    If you rent a server, you would get the "serveradmin" and "password" so that you can admin and setup your newly rented server OR the serveradmin token to enter so you can admin and setup your newly renter server.
    Assuming that the above is true, then when you (the serveradmin) connect to your TS3, you click Permissions, ServerQuery Login, input a username in the "Name:" field and click OK -- a password should come up for you in a few moments.
    That is what you put in the XML file along with the other variables. You should be able to run this Idle Mover from your own computer on your Rented TS3 server.
    Again, this is assuming that I understand all of this correctly.
    I am afraid you are wrong. I dont speak of renting a dedicated Server, but just a TS3 Server which will be pre-setup by the hoster, not yourself. You dont get any ServerQuery access, that is a fact. I've gone through several hosters by now on my way finding the right one, and they all said that they dont give access to the ServerQuery Login.
    So you see Plugins like this here for example that need that login to the ServerQuery dont work at all. Most people still rent a TS Server, not a whole Dedicated Server. So the Devs of TS should have thought about that.
  3. #63
    March 2009
    Netherlands
    39
    solution:
    Update to .net framework 3.5
  4. #64
    New York, USA
    28
    Quote Originally Posted by Wolfseye View Post
    are you sure? to my knowledge all you need is server admin and thats it. I run my server through gameservers.com and it works perfectly for me.
  5. #65
    October 2006
    San Antonio, TexASS | USA
    85
    Quote Originally Posted by ThaLegend View Post
    solution:
    hahaha, see i got .net FW 1/1.1/2/3/3.5/4(beta)
    so i guess theowningone you should put a REQUIRES .NET FRAMEWORK 3.5 in your first post :P
  6. #66
    February 2010
    California, USA
    6
    .NET 3.5 and it is working just fine on my Dedi Server now
    Good find!!
  7. #67
    New York, USA
    28
    Added that .NET 3.5 is required to first post. My next two goals with this project are to make it run as a service in windows and to make a linux compatible version.
  8. #68
    March 2009
    Netherlands
    39
    already possible in windows, Use Firedaemon for windows
    And question:
    In Teamspeak 3 you have the away status: http://img682.imageshack.us/img682/7721/awayu.jpg
    Can you add the function that if an player presses the away button, he/she will be moved to afk?
  9. #69
    October 2006
    85
    IIRC thats already a function in the new version (i requested it have an on/off option as well)
    additionally, FireDaemon ISNT CHEAP... AT ALL...
    im still having trouble trying to figure out why the WinServer doesnt have ConsoleLogging and or an actual GUI/Updater... load of crap I say (since the one for the client is so god damn perdy
  10. #70
    January 2007
    Rhode Island, USA
    15
    Quote Originally Posted by DSCKerry View Post
    I'm running it as a service using SRVANY, which is free from Microsoft.
  11. #71
    October 2006
    85
    Quote Originally Posted by Crash View Post
    what makes me cry is i have that saved on my HDD
  12. #72
    Netherlands
    76
    Great
    Wow,
    Great tool man works fine on my server. Thank you.
    And you can download Firedeamon on the internet with serial. It's a great tool to run a service.
    Come on our TS server to try it out(ts.techq.nl). If you stay idle for 30 minutes than you should automaticly being moved to AFK.
    (ThaLegend and me are the admins of the same server)
  13. #73
    March 2009
    Netherlands
    39
    Keep up the good work, and extend this project with more cool features if possible
  14. #74
    118
    Theowningone, if you release this project as open source for example on codeplex, i would do the "run as a service part". So the app could be run as console or as a service.
  15. #75
    March 2010
    9
    Ok, well it works from my computer, but a friend hosts the server from his home server. When we try and enter his local IP, it says no host found, or something like that. When we enter his external IP it times out the connection and gives an error message about a paragraph long pretty much saying it can't find anything. so whats up with it not connecting to local IPs? anyone else have that issue? also we tried updating netframe to 3.5, it didn't help at all.
    Screenshots:
    http://www.masonk.com/nosuchhost.png
    http://www.masonk.com/aconnection.png
    Last edited by SpNightMare; March 15th, 2010 at 01:36 AM. Reason: Screenshots included :)
  1. Auto Poker and Mover
    By SplintDK in forum Client Plugins / Lua Scripts
    Last Post: December 16th, 2014, 07:38 AM
  2. Is there a way to get around the Team Speak Auto Idle mover?
    By SampsonNation in forum General Questions
    Last Post: March 11th, 2013, 04:17 PM
  3. [Rejected] IDLE mover?
    By Purifina in forum Suggestions and Feedback
    Last Post: November 17th, 2011, 12:56 PM
  4. [Question] Group mover ?
    By vexxx in forum Tools / Web Based
    Last Post: September 11th, 2010, 08:51 PM
  5. TS3 Idle Mover
    By PD1EVL in forum Suggestions and Feedback
    Last Post: June 24th, 2010, 09:22 PM
