Page 4 of 14 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 204
  1. #46
    February 2010
    washington usa
    I have 2 requests for changes, 1 is to add itunes support please. and the other is to instead of use application's it should use its one line so that you can have applications shown at the same time
    please and thank you
    Last edited by dj sendi; February 4th, 2010 at 08:31 PM. Reason: forgot to say please and thank you
  2. #47
    April 2009
    Germany / Deutschland
    71
    Quote Originally Posted by dj sendi View Post
    Thank you
    Both things you are requested arent easy to solve.
    Itunes implementation would already be there, but it's not so easy to communicate with the iTunes Client like with Winamp for example.
    The Second request can simply not be solved by me, its only doable as an teamspeak developer.
    Cheers antihacker
  3. #48
    34
    Great Work 4nt1h4cker!
  4. #49
    The Shadows
    51
    Need to be able to seperate by userid
    Maybe lke a check for DB id or for name or better yet for unique identity? and if its the one in the config (or a list) then announce, otherwise do nothing.
  5. #50
    April 2009
    71
    Quote Originally Posted by Dragonshadow View Post
    Okay this is the new version, sorry for delay, i was away.
  6. #51
    Munich
    I tested the command /nowplaying foo but nothing happens just shows what i listening and not streaming? I using Winamp need i a extra plugin for this?
  7. #52
    March 2010
    Pennsylvania, USA
    The download link isn't working for me
  8. #53
    April 2009
    71
    @Chris_F
    Download link works, check again.
    @Ploedman
    This plugin never supported streaming stuff, please be specific.
    Cheers antihacker
  9. #54
    Indiana
    50
    @Ploedman, This program is only supposed to tell you or rather those in the channel what you are playing when you stream. It doesn't stream it for you you have to do that.
  10. #55
    March 2010
    10
    is it possible to disable / enable the appscanner through a plugin?
    this would offer the possibility to reactivate the appscanner when this plugin isn't grabbing any track information.
    we should request custom profile fields from the TS devs
    cheers
  11. #56
    April 2009
    71
    You cant enable/disable the app scanner. You should open a new thread for this, i dont think any developer will read this here.
  12. #57
    18,151
    The appscanner get's an overhaul and becomes an plugin. I'm not sure if this is planned before Beta Ends.
  13. #58
    68
    Plugin does not work since 3.0.0-beta18 [Build: 10492]
  14. #59
    April 2009
    71
    Beta-18 is not yet offical released, so how should i support this version.
  15. #60
    18,151
    Api 4 is needed for Beta 18
  1. [RELEASE]Now Playing Plugin
    By Screech in forum Client Plugins / Lua Scripts
    Last Post: February 3rd, 2018, 02:59 AM
  2. TSX Bot speaking and playing mp3 files plus plugin system
    By Master_Jochen in forum Tools / Web Based
    Last Post: December 12th, 2013, 12:08 AM
  3. OFFLINE User Viewer Plugin or Tool
    By Grimshad in forum General Questions
    Last Post: June 26th, 2012, 10:47 AM
  4. [Request] Sound playing plugin
    By Sir_JusTic3 in forum Client Plugins / Lua Scripts
    Last Post: June 9th, 2011, 09:14 AM
  5. Now Playing Plugin Win64 API 8
    By savinna in forum Client Plugins / Lua Scripts
    Last Post: September 15th, 2010, 05:47 PM
