Results 1 to 2 of 2
    June 2003
    8
    [BUG] Security Problem with relative DT_RPATH
    Hi there,
    on Gentoo Linux I get the following error when installing Teamspeak 3 (beta-12 and beta-15)
    The whole Bug report can be found https://bugs.gentoo.org/show_bug.cgi?id=301344
    Thanks
    scanelf: rpath_security_checks(): Security problem with relative DT_RPATH '.'
    in
    /var/tmp/portage/media-sound/teamspeak-server-bin-3.0.0_beta12/image/opt/teamspeak3-server/libts3db_sqlite3.so
    in
    /var/tmp/portage/media-sound/teamspeak-server-bin-3.0.0_beta12/image/opt/teamspeak3-server/libts3db_mysql.so
    in
    /var/tmp/portage/media-sound/teamspeak-server-bin-3.0.0_beta12/image/opt/teamspeak3-server/ts3server-bin
    in
    in
    in
    July 2002
    2,192
    the ts3server loads the database plugins (e.g. libts3db_sqlite3.so) which are,
    by default, in the same location as the binary.
    The ts3client loads the fmod library and the Qt libraries which are, by default, in
    You see the rpath has a reason, the only alternative I could imagine would be do
    write a "startscript" that uses LD_LIBRARY_PATH to achieve the same effect,
    but that adds another layer and another place where errors can occure on the
    user side (executing wrong file)
  1. Few security problem.
    By v3ko123 in forum Server Support
    Last Post: July 27th, 2015, 12:54 PM
  2. Replies: 8
    Last Post: December 18th, 2011, 01:54 PM
  3. [BUG] Security Problem with relative DT_RPATH
    By JamieWolf in forum Linux / FreeBSD
    Last Post: January 20th, 2010, 12:55 PM
  4. Problem w/ Improving Security
    By DavidC99 in forum Client Support
    Last Post: December 31st, 2009, 04:04 AM
