Results 1 to 7 of 7
Thread: TS3 Cronjob
    88
    TS3 Cronjob
    Edit by mod
    Please don't use this outdated script anymore! The script got an overhaul long time ago.
    Please use the minimal or startscript instead
    Hey, I've tried to do a Cronjob for starting TS3 in Background after Root-server reboot. But it wont work :S
    Cronjob:
    crontab -e -u ts3
    @reboot /home/ts3/teamspeak3-server_linux-x86/ts3server_linux_x86&
    Error when trying to use the command manually with user "ts3"
    2010-01-19 11:39:31.128000|ERROR |ServerLibPriv | | Failed to create "logs" directory
    ERROR: openFile( file:logs/ts3server_2010-01-19__11_39_31.128000.log) failed
    2010-01-19 11:39:31.128000|WARNING |LogFile | | Failed to open file for logging, file logging disabled
    TeamSpeak Server 3.0.0-beta15 [Build: 9884]
    (c)TeamSpeak Systems GmbH
    Logging started
    2010-01-19 11:39:31.128000|INFO |ServerLibPriv | | Server Version: 3.0.0-beta15 [Build: 9884]
    2010-01-19 11:39:31.132000|CRITICAL|DatabaseQuery | | unable to load database plugin library, halting!
    [1] 3113
    [1]+ Exit 1 /home/ts3/teamspeak3-server_linux-x86/ts3server_linux_x86
    Whats wrong? seems like the user "ts3" dont have enough permissions :S
    it works when i start ts3 via screen and the user root. but starting a server with root user, sux. So what should i do?
    44
    give the filerights to your ts3 user? maybe the files are still owned by root?
    88
    okay, starting with command works now, but on root restart, it wont run ts3 automatically :S
    September 2007
    8
    try
    crontab -e -u ts3
    @reboot cd /home/ts3/teamspeak3-server_linux-x86/ && ./ts3server_linux_x86 &
    i cant understand, why the ts3 executable isnt able to determine its own path but with changing the directory before launching it works like a charm.
    88
    will try it asap
    Portugal
    492
    Quote Originally Posted by XioniX View Post
    try
    crontab -e -u ts3
    Yea, this should work
    I've noticed it when i did the start script to my server. The server just can't be started from outside of its own dir...Its kinda weird.
    88
    yes, its working now
