Results 1 to 3 of 3
    February 2010
    13
    [solved] Problem when starting server!
    I think I made something wrong when updating the server! It is running but the log file is flooded with warnings like this:
    2010-02-04 09:34:03.687221|WARNING |PermGroupMgr  |  1| permID: i_needed_modify_power_virtualserver_token_list(65314), double assigned to sgid: 6, ignoring!
    2010-02-04 09:34:03.687632|WARNING |PermGroupMgr  |  1| permID: i_needed_modify_power_virtualserver_token_add(65315), double assigned to sgid: 6, ignoring!
    2010-02-04 09:34:03.688133|WARNING |PermGroupMgr  |  1| permID: i_needed_modify_power_virtualserver_token_use(65316), double assigned to sgid: 6, ignoring!
    2010-02-04 09:34:03.688549|WARNING |PermGroupMgr  |  1| permID: i_needed_modify_power_virtualserver_token_delete(65317), double assigned to sgid: 6, ignoring!
    2010-02-04 09:34:03.688955|WARNING |PermGroupMgr  |  1| permID: i_needed_modify_power_virtualserver_log_view(65318), double assigned to sgid: 6, ignoring!
    2010-02-04 09:34:03.689462|WARNING |PermGroupMgr  |  1| permID: i_needed_modify_power_virtualserver_log_add(65319), double assigned to sgid: 6, ignoring!
    2010-02-04 09:34:03.689845|WARNING |PermGroupMgr  |  1| permID: i_needed_modify_power_virtualserver_join_ignore_password(65320), double assigned to sgid: 6, ignoring!
    how can i fix this?
    June 2002
    KrŁn / Germany
    1,638
    just ignore it, in one of the next build we got code which removes this double entries.
    February 2010
    13
    ok thank you
  1. Problem starting TS3 Server
    By Overkillz in forum Linux / FreeBSD
    Last Post: July 12th, 2014, 05:04 PM
  2. Problem with Starting TS≥ Server
    By Arazel Ftw in forum Linux / FreeBSD
    Last Post: June 24th, 2012, 08:02 AM
  3. [solved] Starting a second T3 Server
    By Celindra in forum Linux / FreeBSD
    Last Post: August 15th, 2010, 11:02 PM
  4. [Solved] Problem starting ts3 after upgrade
    By shocker38 in forum Windows
    Last Post: May 22nd, 2010, 03:32 PM
  5. [Solved] Problem when starting
    By Djinndrache in forum Linux / FreeBSD
    Last Post: January 29th, 2010, 12:38 AM
