Results 1 to 9 of 9
    Munich
    25
    Problems with starting up Ts3 server beta 17
    hey guys,
    If i start the minimal run script i get the error ./ts3server_linux_amd64: no such file or directory. But i´m sure that the file is there. if you dont believe in me i can upload a screenshot of my ts3 dictionary.
    Im thanking you in anticipition of your answers.
    LG Zion
    July 2002
    2,191
    Paste the exact way you run your script, then run "pwd" and "ls -Fla" and "whoami" for us after the script failed to start (and paste the entire thing).
    Munich
    25
    Hey Peter,
    exakt way how i start up the script:
    cd ts3
    ./ts3server_minimal_runscript.sh start
    after doing this i get the error
    Here you are
    pwd
    root/ts3
    [email protected]:~/ts3# ls
    CHANGELOG libts3db_sqlite3.so ts3server_minimal_runscript.sh
    LICENSE serverquerydocs ts3server_startscript.sh
    doc sql
    libts3db_mysql.so ts3server_linux_amd64
    [email protected]:~/ts3# whoami
    root
    Munich
    25
    Hey Guys,
    now i get another error code:
    [email protected]:/root/ts3$ ./ts3server_startscript.sh start
    -sh: ./ts3server_startscript.sh: /bin/bash^M: bad interpreter: No such file or directory
    I hope anyone of you can help me with this Problem.
    Im thanking you in anticipation of your answers
    best regards
    July 2002
    2,191
    hmm I ask for "ls -Fla" and you give output of "ls". Your new error is that you copied your file to windows, edited it and reupped it O_o. Extract the beta17 archive *on*linux*, edit the file (if you must) *on*linux*. Everything else messes up permissions and line endings.
    Munich
    25
    Sry Peter my mistake. Here is what you asked for:
    sh-3.1$ ls -fla
    total 6680
    drwxr-xr-x 7 ts root 4096 Feb 6 20:02 .
    drwxr-xr-x 6 root root 4096 Feb 6 11:05 ..
    -rw-r--r-- 1 root root 13919 Feb 6 19:42 CHANGELOG
    -rw-r--r-- 1 root root 195085 Feb 6 19:42 libts3db_mysql.so
    -rw-r--r-- 1 root root 827409 Feb 6 19:43 libts3db_sqlite3.so
    -rw-r--r-- 1 root root 23747 Feb 6 19:42 LICENSE
    -rwxrwxrwx 1 root root 5520348 Feb 6 19:46 ts3server_linux_x86
    -rwxrwxrwx 1 root root 157 Feb 6 19:43 ts3server_minimal_runscript.sh
    -rwxrwxrwx 1 root root 2629 Feb 6 19:57 ts3server_startscript.sh
    drwxr-xr-x 2 root root 4096 Feb 6 19:43 doc
    drwxr-xr-x 2 root root 4096 Feb 6 19:46 serverquerydocs
    drwxr-xr-x 4 root root 4096 Feb 6 19:46 sql
    -rw-r--r-- 1 root root 75 Feb 6 19:53 ts3db_mysql.ini
    -rw-r--r-- 1 root root 310 Feb 6 19:53 ts3server.ini
    drwx------ 2 ts ts 4096 Feb 6 19:59 logs
    -rw-r--r-- 1 ts ts 171008 Feb 6 20:01 ts3server.sqlitedb
    drwx------ 3 ts ts 4096 Feb 6 19:59 files
    -rw-r--r-- 1 ts ts 10 Feb 6 19:59 query_ip_whitelist.txt
    -rw-r--r-- 1 root root 930 Feb 6 20:02 licensekey.dat
    I will now edit the startscript on linux because i need to edit the start parameter inifile=ts3server.ini
    big thanks to you for your helping
    best regards
    Good old Germany
    222
    login as root
    go t parent directory of your ts3 folder and do an: chown -R ts:ts ts
    Then change user with: su ts
    And now try to start your server again.
    Cheech
    Munich
    25
    Hey Guys,
    Now i get a error by starting the minimal_runscript.sh
    Here is my Logifle:
    2010-02-07 11:35:38.742137|INFO |ServerLibPriv | | Server Version: 3.0.0-beta17 [Build: 10115]
    2010-02-07 11:35:38.744249|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, (c)TeamSpeak Systems GmbH
    2010-02-07 11:35:38.744852|INFO |DatabaseQuery | | dbPlugin version: 3.6.21
    2010-02-07 11:35:38.745853|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2010-02-07 11:35:38.814134|INFO |SQL | | db_CreateTables() tables created
    2010-02-07 11:35:39.980906|INFO |Accounting | | Licensing Information
    2010-02-07 11:35:39.982754|INFO |Accounting | | type : Non-profit
    2010-02-07 11:35:39.984549|INFO |Accounting | | starting date : Mon Dec 21 00:00:00 2009
    2010-02-07 11:35:39.986323|INFO |Accounting | | ending date : Tue Dec 21 00:00:00 2010
    2010-02-07 11:35:39.987916|INFO |Accounting | | max virtualservers: 10
    2010-02-07 11:35:39.990193|INFO |Accounting | | max slots : 512
    2010-02-07 11:35:40.062576|INFO |FileManager | | listening on 0.0.0.0:30033
    2010-02-07 11:35:40.760839|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2010-02-07 11:35:40.763574|INFO |VirtualServer | 1| client 'server'(id:0) added token for servergroup 'Server Admin'(id:6)
    2010-02-07 11:35:40.765631|WARNING |VirtualServer | 1| --------------------------------------------------------
    2010-02-07 11:35:40.766789|WARNING |VirtualServer | 1| ServerAdmin token created, please use the line below
    2010-02-07 11:35:40.769110|WARNING |VirtualServer | 1| token=/---------------------------------------------------
    2010-02-07 11:35:40.770676|WARNING |VirtualServer | 1| --------------------------------------------------------
    2010-02-07 11:35:40.772279|INFO |Query | | whitelist ips: 127.0.0.1,
    2010-02-07 11:35:40.776095|CRITICAL| | | Failure during pthread_create 12
    Good old Germany
    222
  1. having problems starting server
    By brandon789 in forum Linux / FreeBSD
    Last Post: November 17th, 2013, 08:14 PM
  2. Server Starting problems
    By uaksz555 in forum Windows
    Last Post: November 10th, 2010, 12:09 PM
  3. Starting Server fater update Beta 17 failed
    By Passe0815 in forum Linux / FreeBSD
    Last Post: February 5th, 2010, 09:45 AM
