Results 1 to 6 of 6
    2,355
    Problem with telnet command logview
    I tried one of the following commands on telnet:
    logview limitcount=2 comparator=< timestamp=2010-02-11\s11:12:17
    logview limitcount=2 comparator== timestamp=2010-02-11\s11:12:17
    But the server answer was:
    error id=1281 msg=database\sempty\sresult\sset
    If I try:
    logview limitcount=2 comparator=> timestamp=2010-02-11\s11:12:17
    I get the first line of the log (date 2009-12-19). It does not matter which timestamp I try.
    What did I wrong? My timestamp maybe? Server beta 18 (Debian 5).
    2,029
    try using real Timestamps instead of written Dates. That should work.
    logview limitcount=5 comparator=> timestamp=1265828400
    would show the next 5 Logentries from 2010-02-10 20:00:00 UTC
    2,355
    Quote Originally Posted by SilentStorm View Post
    The help text says:
    logview limitcount={1-500} [comparator={<|>|=}] [timestamp=YYYY-MM-DD\shh:mm:ss]
    Thats why I got problems here.
    2,029
    I know what the help text says.
    But still timestamp is timestamp and a timestamp is a numeric Value not a string. Apparently they tried to make it more userfriendly by allowing a time expression to be passed but obviously they either forgot to convert it into an actual timestamp or it's not working properly.
    Try it out with passing a timestamp you will find it works. In case you don't know how to get the timestamp for a given date try PHP's strtotime Function.
    2,355
    I know, already tried after your first answer. Thanks for the information.
    My last post should only say that the help text is wrong, a small notice for the teamspeak devs :P .
    2,029
    Quote Originally Posted by Stefan1200 View Post
    ah ok must have misunderstood you then. Sorry
  1. logview problem
    By elraro in forum Linux / FreeBSD
    Last Post: June 12th, 2014, 06:15 PM
  2. [Resolved] command logview - read log from all files - TS Query
    By Kledr in forum Server Support
    Last Post: January 7th, 2013, 02:53 PM
  3. Telnet command suggestions
    By Stefan1200 in forum Suggestions and Feedback
    Last Post: February 19th, 2010, 11:53 AM
