Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    February 2010
    UK
    12
    [Solved] insufficient group modify power
    When I try and set 'Group Modify Power' I get the following error 'insufficient group modify power'
    I am trying to set up a group so that members that are alreay in that group can invite Guest members into it. ie Guild mates that join the new TS3 can be added to the group by other members.
    But when the User (already a member of the group) tries to add another User he gets 'failed on i_group_needed_member_add_power'
    When I try to add permission 'Group Member add power' as Admin it will only acept 0 as a value.
    Thanks in advance,
    Tony
    February 2006
    Texas, USA
    4,143
    You need to adjust i_group_needed_member_add_power not group_member_add_power. The error tells you what permission caused it so just go to that permission and make an adjustment.
    February 2010
    UK
    12
    I can not adjust Group_member_Add_Power I get insufficient group modify power and I can not adjust Group_Modify_Power I get insufficient group modify power again
    Tony
    February 2006
    Texas, USA
    4,143
    What are the current values for all of the permissions that have been talked about so far?
    February 2010
    UK
    12
    Current value is 25
    February 2006
    Texas, USA
    4,143
    What are the values for the server group you are in and the values for the group you are working on? (sorry should have been more specific last time)
    group_modify_power
    need_group_modify_power
    February 2010
    UK
    12
    i_group_needed_member_add_power - I can not set this
    group_member_add_power - 25
    group_modify_power - I can not set this
    need_group_modify_power I can not set this
    Probably as I can not set the group_modify_power?
    Tony
    February 2006
    Texas, USA
    4,143
    When you say you can't set it does that mean it's grayed out and you get an error when you attempt to add this permission?
    February 2010
    UK
    12
    No its not greyed out, If I try and set it to a value it just errors
    Tony
    February 2006
    Texas, USA
    4,143
    does they currently have a value? Are you in the server admin server group?
    I am an admin on my clan's server and by default for the Server Admin group all the GROUP->MODIFY permissions are set to 75 w/ a GRANT of 75.
    Server Admin Group Permissions
    i_needed_modify_power_group_modify_power 75 0 0
    i_needed_modify_power_group_needed_modify_power 75 0 0
    i_needed_modify_power_group_member_add_power 75 0 0
    i_needed_modify_power_group_needed_member_add_powe r 75 0 0
    i_needed_modify_power_group_member_remove_power 75 0 0
    i_needed_modify_power_group_needed_member_remove_p ower 75 0 0
    i_needed_modify_power_permission_modify_power 75 0 0
    February 2010
    UK
    12
    Something is totaly wrong here, I created a new group and still I am unable to set the Group_Modify_Power.
    On my Server Admin group I have 75 on Grant but the value is not set, So I think I may have removed it by mistake? though I dont rememeber doing that.
    Is there a way to reset admin permissions? I may need to do a new server lol
    Thanks for your help anyway.
    Tony
    February 2010
    UK
    12
    Seem I must have removed the value 75 from Group_Modify_Power from the Server Admin Group. is there a way I can add this back on with out restarting?
    Thanks,
    Tony
    December 2003
    227
    via ServerQuery?
    February 2006
    Texas, USA
    4,143
    When you say removed do you mean the permission is grayed out or you just changed the value 75? As far as I know you can just right click/add permission if it's grayed out and put whatever value you want in there w/ out having to restart the server.
    February 2010
    UK
    12
    Thanks poisonpanik for al your help, I have just restored a backup now and all is fine.
    Seems the 'Group Modify Power' value of 75 had vanished from the server admin group. I dont remember even playing around with the server admin group (Why would I do that!)
    So admin had no Modify power.
    Luckily I had a backup and lost nothing.
    Thanks again,
    Tony
  1. Insufficient Group Modify Power
    By Pixel22 in forum Permission System
    Last Post: April 23rd, 2012, 09:28 PM
  2. Insufficient group modify power
    By HxCRobb in forum Permission System
    Last Post: December 7th, 2011, 08:01 PM
  3. Replies: 3
    Last Post: July 8th, 2011, 12:25 AM
  4. [solved] insufficient permission modify power
    By Misjahx in forum Linux / FreeBSD
    Last Post: August 29th, 2010, 12:28 PM
  5. [Solved] insufficient permission modify power
    By BobBart in forum Permission System
    Last Post: February 10th, 2010, 11:58 PM
