There is a little bug in the ServerQuery Manual (*.pdf).
Maybe it will be fixed with next Server Release (whenever this will be).
In table of contents there is 2x "permfind", guess one should read "permreset" (see pic 2).
Also, if you copy&paste from one item you should read and edit it to fit the new item, in this case except the description its the same text for "permreset" as in "permfind" (see pic 1).
