Results 1 to 11 of 11
    February 2010
    Oregon
    10
    [SOLVED]Too Many Slots Hosted, Fresh beta21 install, Non-Profit License Key Present
    I have been trying to resolve this issue for the better part of the day, but cant seem to find the solution.
    Currently, I am running a beta17 server. I saw that there was a beta21 release and decided to update to the latest version, however, instead of updating the installation, I decided to use a fresh install.
    I believe I have the proper files. I have a ts3server.ini file, with a ts3server_startscript.sh that has been modified to point to the ts3server.ini file. The licensekey.dat is present in the TS3 root directory.
    When running the server without a license, everything works fine. However, when I put the License file in the root directory, I get the following log message:
    2010-04-04 11:56:22.576499|INFO    |ServerLibPriv |   | Server Version: 3.0.0-beta21 [Build: 10608], Linux
    2010-04-04 11:56:22.576671|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, (c)TeamSpeak Systems GmbH
    2010-04-04 11:56:22.576700|INFO    |DatabaseQuery |   | dbPlugin version: 3.6.21
    2010-04-04 11:56:22.576866|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2010-04-04 11:56:22.587836|INFO    |SQL           |   | pruning old database log entries where timestamp is older than 90 days
    2010-04-04 11:56:23.310332|INFO    |Accounting    |   | Licensing Information
    2010-04-04 11:56:23.310806|INFO    |Accounting    |   | type              : Non-profit
    2010-04-04 11:56:23.311150|INFO    |Accounting    |   | starting date     : Sun Jan 17 23:00:00 2010
    2010-04-04 11:56:23.311469|INFO    |Accounting    |   | ending date       : Mon Jan 17 23:00:00 2011
    2010-04-04 11:56:23.311800|INFO    |Accounting    |   | max virtualservers: 10
    2010-04-04 11:56:23.312114|INFO    |Accounting    |   | max slots         : 512
    2010-04-04 11:56:23.333395|INFO    |FileManager   |   | listening on xx.xxx.xx.xxx:30033
    2010-04-04 11:56:23.368892|INFO    |VirtualServer |  1| listening on xx.xxx.xx.xxx:9987
    2010-04-04 11:56:23.369250|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2010-04-04 11:56:23.369742|INFO    |Query         |   | listening on xx.xxx.xx.xxx:10011
    2010-04-04 11:56:24.062009|ERROR   |Accounting    |   | too many slots hosted, shutting down!
    2010-04-04 11:56:24.391096|INFO    |VirtualServer |  1| stopped
    The server is set to host only 32 slots, the default upon a fresh install.
    beta17 works just fine, however.
    December 2007
    238
    Is the other server still running?
    February 2010
    Oregon
    10
    Found the solution to the issue.
    In the SQLite DB, the value for "virtualserver_maxclient" was set to a null value. I went in and manually updated this value to 512, and everything is working now.
    August 2009
    Essen (Germany - NRW)
    10
    Exclamation
    I've run across the whole MySQL and always get the error: 2010-04-11 21:14:57.296451 | ERROR | Accounting | | too many slots hosted, shutting down!
    2010-04-11 21:14:57.297046 | ERROR | Accounting | | too many slots hosted, shutting down!
    2010-04-11 21:14:57.297423 | ERROR | Accounting | | too many slots hosted, shutting down!
    My non-profit license is valid:
    2010-04-11 21:14:56.894041 | INFO | Accounting | | Licensing Information
    2010-04-11 21:14:56.894620 | INFO | Accounting | | type: Non-profit
    2010-04-11 21:14:56.894998 | INFO | Accounting | | starting date: Sun Jan 3 23:00:00 2010
    2010-04-11 21:14:56.895292 | INFO | Accounting | | ending date: Mon Jan 3 23:00:00 2011
    2010-04-11 21:14:56.895575 | INFO | Accounting | | max virtual servers: 10
    2010-04-11 21:14:56.895875 | INFO | Accounting | | max slots: 512
    In the database are the values virtualserver_maxclient Perfect for all.
    Where is the problem?
    See Screenshot
    Secret Base in Arctic Region
    1,671
    Did you restart the TS serverprocess after applying the license, as it was mentioned in the email?
    August 2009
    10
    I have rebooted the Server 9 - 10 times more often and ... previously ran everything with no problems until now stressed out with the beta 21 from it so ...
    February 2010
    Oregon
    10
    Are you sure that the server is looking at the MySQL DB and not defaulting to the SQLite DB?
    August 2009
    10
    Correct. TS3 I've been using MySQL connection. Up to the Beta 21 without problems.
    Only since the Beta 21 update is nothing more>. <
    February 2010
    Oregon
    10
    Quote Originally Posted by OlliTheDarkness View Post
    Are you updating from Beta 21 or are you using a new installation?
    Good old Germany
    222
    Hi Oli,
    did you replace all files ?
    When yes, did you edit again your start script with your parameters ?
    cheech
    August 2009
    10
    My problem has done himself. Have I won through to install TS3 and rebuild all virtual server. Was true of 8 servers ne lot of work but no matter the problem I went to the ... ^ ^ Thanks anyway. In operation now Beta 22nd on MySQL
    ----------German-----------
    *** German part deleted ***
    *** This forum is english only ***
  1. [Resolved] Non-Profit License 512 slots with 32 slots
    By cognaman in forum Server Support
    Last Post: August 31st, 2018, 12:12 PM
  2. Replies: 7
    Last Post: June 2nd, 2011, 07:57 PM
  3. Fresh Install -> New ID
    By r4z0r in forum General Questions
    Last Post: January 7th, 2010, 09:23 PM
  4. Replies: 0
    Last Post: December 27th, 2009, 06:14 AM
