Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 61
  1. #46
    November 2015
    109
    You also need i_channel_permission_modify_power to set/remove the priority speaker flag.
    I don't remmeber why this permission also is a must have for priority speaker.
    I keep getting insufficient client permissions (failed on i_channel_permission_modify_power) !!!
    i_permission_modify_power 65 0 0 75
    b_client_is_priority_speaker 1 0 0 65
    i_channel_permission_modify_power 65 0 0 75
  2. #47
    18,409
    In that case your current i_channel_permission_modify_power is to low.
    Check your permissions via Permissions Overview . This can done under Right-Click on yourself --> Permissions.
  3. #48
    November 2015
    109
    I changed everything from 65 to 70, still nothing. And in Permissions Overview my permission is the same 70 (now).
  4. #49
    November 2015
    109
    Anyone? Is this bugged??
  5. #50
    18,409
    Quote Originally Posted by AGamer View Post
    Please show the permissons overview for target channel. I can't say what it wrong if i don't see it on my own.
    No it's working. Tested on server 3.0.13.x.
  6. #51
    November 2015
    109
    It was working!!! Then stopped working... I used
    i_permission_modify_power 70 0 0 75
    b_client_is_priority_speaker 0 0 0 70
    i_channel_permission_modify_power 70 0 0 75
    In channel permissions I edited.
    i_channel_needed_permission_modify_power 70
    Permission Overview
    Administrators
    		b_virtualserver_info_view 1 0 0 75
    		b_virtualserver_connectioninfo_view 1 0 0 75
    		b_virtualserver_channel_list 1 0 0 75
    		b_virtualserver_channel_search 1 0 0 75
    		b_virtualserver_client_list 1 0 0 75
    		b_virtualserver_client_search 1 0 0 75
    		b_virtualserver_client_dblist 1 0 0 75
    		b_virtualserver_client_dbsearch 1 0 0 75
    		b_virtualserver_client_dbinfo 1 0 0 75
    		b_virtualserver_permission_find 1 0 0 75
    		b_virtualserver_custom_search 1 0 0 75
    		b_virtualserver_start 0 0 0 75
    		b_virtualserver_stop 0 0 0 75
    		b_virtualserver_token_list 0 0 0 75
    		b_virtualserver_token_add 0 0 0 75
    		b_virtualserver_token_use 1 0 0 75
    		b_virtualserver_token_delete 1 0 0 75
    		b_virtualserver_log_view 1 0 0 75
    		b_virtualserver_log_add 1 0 0 75
    		b_virtualserver_join_ignore_password 1 0 0 75
    		b_virtualserver_notify_register 1 0 0 75
    		b_virtualserver_notify_unregister 1 0 0 75
    		b_virtualserver_modify_name 1 0 0 75
    		b_virtualserver_modify_welcomemessage 1 0 0 75
    		b_virtualserver_modify_maxclients 1 0 0 75
    		b_virtualserver_modify_reserved_slots 1 0 0 75
    		b_virtualserver_modify_password 1 0 0 75
    		b_virtualserver_modify_default_servergroup 1 0 0 75
    		b_virtualserver_modify_default_channelgroup 1 0 0 75
    		b_virtualserver_modify_default_channeladmingroup 1 0 0 75
    		b_virtualserver_modify_channel_forced_silence 1 0 0 75
    		b_virtualserver_modify_complain 1 0 0 75
    		b_virtualserver_modify_antiflood 1 0 0 75
    		b_virtualserver_modify_ft_settings 1 0 0 75
    		b_virtualserver_modify_ft_quotas 1 0 0 75
    		b_virtualserver_modify_hostmessage 1 0 0 75
    		b_virtualserver_modify_hostbanner 1 0 0 75
    		b_virtualserver_modify_hostbutton 1 0 0 75
    		b_virtualserver_modify_port 1 0 0 75
    		b_virtualserver_modify_autostart 1 0 0 75
    		b_virtualserver_modify_needed_identity_security_level 1 0 0 75
    		b_virtualserver_modify_priority_speaker_dimm_modificator 1 0 0 75
    		b_virtualserver_modify_log_settings 1 0 0 75
    		b_virtualserver_modify_min_client_version 1 0 0 75
    		b_virtualserver_modify_icon_id 1 0 0 75
    		b_virtualserver_modify_weblist 1 0 0 75
    		b_virtualserver_modify_codec_encryption_mode 1 0 0 75
    		b_virtualserver_modify_temporary_passwords 1 0 0 75
    		b_virtualserver_modify_temporary_passwords_own    75
    		b_virtualserver_modify_channel_temp_delete_delay_default 1 0 0 75
    		i_channel_min_depth    75
    		i_channel_max_depth 10 0 0 75
    		b_channel_group_inheritance_end    75
    		i_channel_needed_permission_modify_power 70 0 0 75
    		b_channel_info_view 1 0 0 75
    		b_channel_create_child 1 0 0 75
    		b_channel_create_permanent 1 0 0 75
    		b_channel_create_semi_permanent 1 0 0 75
    		b_channel_create_temporary 1 0 0 75
    		b_channel_create_private 1 0 0 75
    		b_channel_create_with_topic 1 0 0 75
    		b_channel_create_with_description 1 0 0 75
    		b_channel_create_with_password 1 0 0 75
    		b_channel_create_modify_with_codec_speex8 1 0 0 75
    		b_channel_create_modify_with_codec_speex16 1 0 0 75
    		b_channel_create_modify_with_codec_speex32 1 0 0 75
    		b_channel_create_modify_with_codec_celtmono48 1 0 0 75
    		b_channel_create_modify_with_codec_opusvoice 1 0 0 75
    		b_channel_create_modify_with_codec_opusmusic 1 0 0 75
    		i_channel_create_modify_with_codec_maxquality 10 0 0 75
    		i_channel_create_modify_with_codec_latency_factor_min 1 0 0 75
    		b_channel_create_with_maxclients 1 0 0 75
    		b_channel_create_with_maxfamilyclients 1 0 0 75
    		b_channel_create_with_sortorder 1 0 0 75
    		b_channel_create_with_default 1 0 0 75
    		b_channel_create_with_needed_talk_power 1 0 0 75
    		b_channel_create_modify_with_force_password    75
    		i_channel_create_modify_with_temp_delete_delay 86400 0 0 75
    		b_channel_modify_parent 1 0 0 75
    		b_channel_modify_make_default 1 0 0 75
    		b_channel_modify_make_permanent 1 0 0 75
    		b_channel_modify_make_semi_permanent 1 0 0 75
    		b_channel_modify_make_temporary 1 0 0 75
    		b_channel_modify_name 1 0 0 75
    		b_channel_modify_topic 1 0 0 75
    		b_channel_modify_description 1 0 0 75
    		b_channel_modify_password 1 0 0 75
    		b_channel_modify_codec 1 0 0 75
    		b_channel_modify_codec_quality 1 0 0 75
    		b_channel_modify_codec_latency_factor 1 0 0 75
    		b_channel_modify_maxclients 1 0 0 75
    		b_channel_modify_maxfamilyclients 1 0 0 75
    		b_channel_modify_sortorder 1 0 0 75
    		b_channel_modify_needed_talk_power 1 0 0 75
    		i_channel_modify_power 70 0 0 70
    		i_channel_needed_modify_power 70 0 0 70
    		b_channel_modify_make_codec_encrypted 1 0 0 75
    		b_channel_modify_temp_delete_delay 1 0 0 75
    		b_channel_delete_permanent 1 0 0 75
    		b_channel_delete_semi_permanent 1 0 0 75
    		b_channel_delete_temporary 1 0 0 75
    		b_channel_delete_flag_force 1 0 0 75
    		i_channel_delete_power 70 0 0 75
    		i_channel_needed_delete_power 75 0 0 75
    		b_channel_join_permanent 1 0 0 75
    		b_channel_join_semi_permanent 1 0 0 75
    		b_channel_join_temporary 1 0 0 75
    		b_channel_join_ignore_password 1 0 0 75
    		b_channel_join_ignore_maxclients 0 0 0 75
    		i_channel_join_power 70 0 0 75
    		i_channel_needed_join_power    70
    		i_channel_subscribe_power 70 0 0 75
    		i_channel_needed_subscribe_power    75
    		i_channel_description_view_power 70 0 0 75
    		i_channel_needed_description_view_power    75
    		i_icon_id 403127093 0 0 70
    		i_max_icon_filesize 8192 0 0 75
    		b_icon_manage 1 0 0 75
    		b_group_is_permanent 1 0 0 75
    		i_group_auto_update_type 45 0 0 75
    		i_group_auto_update_max_value 45 0 0
    		i_group_sort_id 2 0 0 70
    		i_group_show_name_in_tree    75
    		b_virtualserver_servergroup_list 1 0 0 75
    		b_virtualserver_servergroup_permission_list 1 0 0 75
    		b_virtualserver_servergroup_client_list 1 0 0 75
    		b_virtualserver_channelgroup_list 1 0 0 75
    		b_virtualserver_channelgroup_permission_list 1 0 0 75
    		b_virtualserver_channelgroup_client_list 1 0 0 75
    		b_virtualserver_client_permission_list 0 0 0 75
    		b_virtualserver_channel_permission_list 1 0 0 75
    		b_virtualserver_channelclient_permission_list 1 0 0 75
    		b_virtualserver_servergroup_create 1 0 0 75
    		b_virtualserver_channelgroup_create 0 0 0 75
    		i_group_modify_power 70 0 0 75
    		i_group_needed_modify_power 75 0 0 75
    		i_group_member_add_power 70 0 0 75
    		i_group_needed_member_add_power 75 0 0 75
    		i_group_member_remove_power 70 0 0 75
    		i_group_needed_member_remove_power 75 0 0 75
    		b_virtualserver_servergroup_delete 1 0 0 75
    		b_virtualserver_channelgroup_delete 0 0 0 75
    		i_client_permission_modify_power 70 0 0 75
    		i_client_needed_permission_modify_power 75 0 0 75
    		i_client_max_clones_uid 1 0 0 75
    		i_client_max_idletime    75
    		i_client_max_avatar_filesize 512000 0 0 75
    		i_client_max_channel_subscriptions -1 0 0 75
    		b_client_is_priority_speaker    75
    		b_client_skip_channelgroup_permissions 0 0 0 75
    		b_client_force_push_to_talk    75
    		b_client_ignore_bans 1 0 0 75
    		b_client_ignore_antiflood 1 0 0 75
    		b_client_issue_client_query_command 1 0 0 75
    		b_client_use_reserved_slot 1 0 0 75
    		b_client_use_channel_commander 1 0 0 75
    		b_client_request_talker 1 0 0 75
    		b_client_avatar_delete_other 1 0 0 75
    		b_client_is_sticky    75
    		b_client_ignore_sticky 1 0 0 75
    		b_client_info_view 1 0 0 75
    		b_client_permissionoverview_view 1 0 0 75
    		b_client_permissionoverview_own 1 0 0 75
    		b_client_remoteaddress_view 1 0 0 75
    		i_client_serverquery_view_power 75 0 0 75
    		i_client_needed_serverquery_view_power 75 0 0 75
    		b_client_custom_info_view 1 0 0 75
    		i_client_kick_from_server_power 70 0 0 75
    		i_client_needed_kick_from_server_power 75 0 0 75
    		i_client_kick_from_channel_power 70 0 0 75
    		i_client_needed_kick_from_channel_power 75 0 0 75
    		i_client_ban_power 70 0 0 75
    		i_client_needed_ban_power 75 0 0 75
    		i_client_move_power 70 0 0 75
    		i_client_needed_move_power 70 0 0 75
    		i_client_complain_power 70 0 0 75
    		i_client_needed_complain_power 75 0 0 75
    		b_client_complain_list 1 0 0 75
    		b_client_complain_delete_own 1 0 0 75
    		b_client_complain_delete 1 0 0 75
    		b_client_ban_list 1 0 0 75
    		b_client_ban_create 1 0 0 75
    		b_client_ban_delete_own 1 0 0 75
    		b_client_ban_delete 0 0 0 75
    		i_client_ban_max_bantime -1 0 0 75
    		i_client_private_textmessage_power 70 0 0 75
    		i_client_needed_private_textmessage_power    75
    		b_client_server_textmessage_send 1 0 0 75
    		b_client_channel_textmessage_send 1 0 0 75
    		b_client_offline_textmessage_send 1 0 0 75
    		i_client_talk_power 70 0 0 75
    		i_client_needed_talk_power    75
    		i_client_poke_power 70 0 0 75
    		i_client_needed_poke_power 10 0 0 75
    		b_client_set_flag_talker 1 0 0 75
    		i_client_whisper_power 70 0 0 75
    		i_client_needed_whisper_power 30 0 0 75
    		b_client_modify_description 1 0 0 75
    		b_client_modify_own_description 1 0 0 75
    		b_client_modify_dbproperties 1 0 0 75
    		b_client_delete_dbproperties 1 0 0 75
    		b_client_create_modify_serverquery_login 0 0 0 75
    		b_ft_ignore_password 1 0 0 75
    		b_ft_transfer_list 1 0 0 75
    		i_ft_file_upload_power 75 0 0 75
    		i_ft_needed_file_upload_power    75
    		i_ft_file_download_power 75 0 0 75
    		i_ft_needed_file_download_power    75
    		i_ft_file_delete_power 75 0 0 75
    		i_ft_needed_file_delete_power    75
    		i_ft_file_rename_power 75 0 0 75
    		i_ft_needed_file_rename_power    75
    		i_ft_file_browse_power 75 0 0 75
    		i_ft_needed_file_browse_power    75
    		i_ft_directory_create_power 75 0 0 75
    		i_ft_needed_directory_create_power    75
    		i_ft_quota_mb_download_per_client -1 0 0 75
    		i_ft_quota_mb_upload_per_client -1 0 0 75
    	All
    		b_virtualserver_start 1 0 0 75
    		b_virtualserver_stop 1 0 0 75
    		b_virtualserver_token_list 1 0 0 75
    		b_virtualserver_token_add 1 0 0 75
    		i_channel_permission_modify_power 75 0 0 75
    		i_channel_modify_power 75 0 0 75
    		i_channel_needed_modify_power 70 0 0 75
    		i_channel_delete_power 75 0 0 75
    		b_channel_join_ignore_maxclients 1 0 0 75
    		i_channel_join_power 75 0 0 75
    		i_channel_needed_join_power    75
    		i_channel_subscribe_power 75 0 0 75
    		i_channel_description_view_power 75 0 0 75
    		i_icon_id 403127093 0 0 75
    		i_group_sort_id 2 0 0 75
    		b_virtualserver_servergroup_client_list 1 1 0 75
    		b_virtualserver_client_permission_list 1 0 0 75
    		b_virtualserver_channelgroup_create 1 0 0 75
    		i_group_modify_power 75 0 0 75
    		i_group_member_add_power 75 0 0 75
    		i_group_member_remove_power 75 0 0 75
    		i_permission_modify_power 75 0 0 75
    		b_virtualserver_channelgroup_delete 1 0 0 75
    		i_client_permission_modify_power 75 0 0 75
    		i_client_max_clones_uid 10 0 0 75
    		b_client_skip_channelgroup_permissions 1 0 0 75
    		i_client_kick_from_server_power 75 0 0 75
    		i_client_kick_from_channel_power 75 0 0 75
    		i_client_ban_power 75 0 0 75
    		i_client_move_power 75 0 0 75
    		i_client_complain_power 75 0 0 75
    		b_client_ban_delete 1 0 0 75
    		i_client_private_textmessage_power 75 0 0 75
    		i_client_talk_power 75 0 0 75
    		i_client_poke_power 75 0 0 75
    		b_client_create_modify_serverquery_login 1 0 0 75
    Client
    	AGamer
    Channel
    	Room 3
    		i_channel_needed_permission_modify_power 30
    		i_channel_needed_modify_power 0
    		i_ft_needed_file_upload_power 5
    		i_ft_needed_file_rename_power 5
    		i_ft_needed_file_browse_power 0
    		i_ft_needed_directory_create_power 5
    Channel Groups
    	Guest
    		i_group_auto_update_type 10
    Edit !!! *****
    Its not working for people in the "Administrators" server group, but it works for me when I'm in that group.. It works for a lower level admin server group ex test below
    Room 3 / Administrators <----- doesn't work
    Room 4 / lower level admin <--- works
  7. #52
    18,409
    What overview is this?
    It's supposed to be the permission overview, but something is wrong with it.
    1. How can it be that All shows (b_client_skip_channelgroup_permissions 1 0 0 75) in line 374 when you only have one Server group?
    Your Administrator has (b_client_skip_channelgroup_permissions 0 0 0 75) in line 153
    Search "b_client_skip_channelgroup_permissions" (2 hits in 1 file)
      C:\Users\dante696\Desktop\new.txt (2 hits)
    	Line 153: 		b_client_skip_channelgroup_permissions 0 0 0 75
    	Line 374: 		b_client_skip_channelgroup_permissions 1 0 0 75
    Are you mixing 2 different overviews?
    Is this in server 3.0.13.3?
    Or what is happening here?
    This is what i did expect:
Name:	skip is right.png
    2. All (the sum of all Permissions) is completely missing. It's impossible for me to see if everything is right with the permissions shown on my picture
Name:	modify power for priority speaker.png
  8. #53
    November 2015
    109
    Server Version:3.0.12.4 and using Client 3.1 beta. I right clicked my name > permissions > permission overview.
    Line 374 and 153 are both b_client_skip_channelgroup_permissions 0 0 0 75 (looking at it now).
    My current permission settings for priority speaker are:
    Server group:
    Channel Permission:
    It is working, I can toggle priority speaker on and off. But I want to know if this is the correct way to do this? Because I don't want it to stop working after...
  9. #54
    18,409
    Looks correct. That's what i can tell with that information.
  10. #55
    July 2010
    Earth
    74
    Priority Speaker Permission
    I have a group that can not set itself as Priority Speaker.
    Even tho, as admin, i have given that group Permission Modify Power of 75 and skip that group still gets the message "Insufficient Permission Modify Power"
    Only when i give that group "Ignore Permission Modify Power" it works as it should.
    Am i thinking wrong? Where is the "supposed to be" needed permission modify power to enable a group to set themself as Priority Speaker?
    SOLVED: found the solution within the forum.
  11. #56
    January 2018
    Priority Speaker from Channel Group for Server Admins
    I'm currently trying to make a channel group "Caller" which automatically gives priority speaker when a client is added to it (b_client_is_priority_speaker=1). Currently the group is working fine for all clients except those who belong to the Server group "Server Admin" - Server Admins can be given the group Caller but Priority Speaker is just not set - although it can be set manually in the right-click menu and works fine. But at the moment I just can't find out why this doesn't work for Server Admins. (When I take away their server admin it works as usual so the reason must be anywhere within the server admin group).
    Reading this thread https://forum.teamspeak.com/threads/...ker-quot/page2 I have to set two Permisisons:
    You guys are close but you're missing one thing.
    I started from a fresh install and i changed 2 permissions for the server guest group to allow them to toggle priority speaker.
    1. i_permission_modify_power (added value of 75)
    2. b_client_is_priority_speaker (added grant of 75)
    edit: These values can be edited to suite your needs
    So I set "i_permission_modify_power" of the group Server Admin to 75 and grant value of "b_client_is_priority_speaker"
    of Server Admin to 74
    According to Chris I also have to set "i_channel_needed_permission_modify_power" of the channel:
    for the i_channel_permission_modify_power you need to have it's value at least equal to the channels' i_channel_needed_permission_modify_power of the channel in which you want to use priority speaker.
    As such you can even specify in which channel(s) someone can use priority speaker.
    Also done, "i_channel_needed_permission_modify_power" of the channel is 75.
    But still, the channel group works only for non-Server-Admins... (already thought about the skip flag but taking away the skip channel permissions flag doesn't help either). Do I need any other values set for this to work?
    (If you need further info on the Server Admin group feel free to ask )
    By the way, I'm trying this as a Server Admin myself so I should have all the required permissions... setting priority speaker manually works also
    Thanks in advance for your help
  12. #57
    18,409
    You did not show us a permissions overview. So... I still bet it's permission b_client_skip_channelgroup_permissions in Server Admin group ignoring the permissions coming from a channel and channel groups.
    Please do not remove the permission from Server Admin group.
    You will have lot of ddisadvantages in case you remove it.
    Post 25 shows you the minimun permissions needed to set priority speaker.
    For your Server Admin the values should be 75.
  13. #58
    January 2018
    Ok, so here's the complete permission overview (see Attachment - Text is too long to paste it here).
    And yes, b_client_skip_channelgroup_permissions ist set - but as you already mentioned I don't really like the option to take it away for this channel group to work (and even if i do it's still not working). i_channel_permission_modify_power=75 and grant=75 (ServerAdmin), i_permission_modify_power=75 and grant=75 (ServerAdmin) and b_client_is_priority_speaker-grant=74. I also read this post and tried setting the permissions like this but it's still not working
    Attached Files Attached Files
  14. #59
    18,409
    I still doubt that you do not get priority speaker assigned when b_client_skip_channelgroup_permissions is disabled for Server admin.
    I did retry what you did post before and that worked as expected.
    Your permissions overview shows the desired situation when b_client_skip_channelgroup_permissions is enabled and skips the priority speaker from channel group. There is nothing wrong with it and nothing you can do here.
    You have to decide if you want to be a full admin where no channel group removes your admin permissions or if you plan to harm this Admin group.
    Please show the permissions overview when b_client_skip_channelgroup_permissions is disabled.
  15. #60
    January 2018
    Ok I just tried again removing the skip flag (I had forgotten to remove it in the client rights - sorry that was my bad ).
    Indeed with both skip flags removed now it's working for Server-Admins.
    So - there is no way to assign new positive permissions like priority speaker via channel groups with the skip flag enabled? I would have expected it to skip negative effects on the effective permisisons only So if I understood you correctly there's no way to add permissions via channel groups while ths skip flag is set, is there?
    So I guess I'll have to change it into a server group so the skip flag can stay enabled... I guess there's no way to rebuild this behaviour with a server group that priority speaker is only valid in certain channels, is there?
    Thanks for the help and sorry for forgetting to disable client rights skip flag in the previous post...
  1. Priority Speaker - removed grant rights by accident
    By haloanoobis in forum Permission System
    Last Post: July 25th, 2013, 06:42 PM
  2. [Resolved] Give priority speaker permission
    By titanomachie in forum Permission System
    Last Post: March 13th, 2013, 04:03 PM
  3. [Resolved] give another group the rights for a conversation leader
    By CalibeR.50 in forum General Questions
    Last Post: April 2nd, 2011, 12:18 AM
  4. give rights to my own group
    By St3v3 in forum Permission System
    Last Post: October 21st, 2010, 12:16 PM
