Results 1 to 2 of 2
    Denmark
    13
    [Solved] Use SDK 3 callbacks in C++
    I'm currently trying to move the C client example over to a C++ class but I face some problems- The C example runs fine.
    My problem is related to the callback functions which im sure is either not defined in the correct place for propper initializing and use of struct.
    I have declared these in the class as class variables.
    struct ClientUIFunctions funcs;
    Following is placed in constructor.
    /* Initialize all callbacks with NULL */
    memset(&funcs, 0, sizeof(struct ClientUIFunctions));
    funcs.onConnectStatusChangeEvent = onConnectStatusChangeEvent; ...etc.
    Is this correct or do someone have a small example i can use ?
    The problem that occurs is during runtime when i connect. All seems okay but the connection to the server is not seen on server and application terminates (CTD) short after.
    I'm sure it is related to the callbacks and the struct.
    Appreciate any feedback to get me moving.
    Booster
    Denmark
    13
    Ha, problem is solved :-)
    Turned out to be password fail that prevented the client to log in.
    So the class is working after all
    Booster
  1. [Forwarded] Plugin Audio callbacks not included in recording
    By Philosound in forum Bug Reports [EN/DE]
    Last Post: July 26th, 2013, 11:42 AM
  2. Problem using Callbacks with C++ (member function)
    By Stryder2k in forum General Questions
    Last Post: August 24th, 2012, 06:30 AM
  3. [Solved] URL For IP
    By BottleKid in forum General Questions
    Last Post: June 14th, 2010, 06:05 PM
