Today, Right out of the Blue the Server started acting on it's own with the Flood protection. It started this morning, I'm told she was uploading a file and was disconnected as her provider went down (Timed out).
2010-07-14 21:13:51 VirtualServer Info server was edited by 'Tearlow'(id:2)
2010-07-14 21:15:10 Accounting Info Licensing Information
2010-07-14 21:15:10 Accounting Info type : Non-profit
2010-07-14 21:15:10 Accounting Info starting date : Sat Dec 26 23:00:00 2009
2010-07-14 21:15:10 Accounting Info ending date : Sun Dec 26 23:00:00 2010
2010-07-14 21:15:10 Accounting Info max virtualservers: 10
2010-07-14 21:15:10 Accounting Info max slots : 512
2010-07-14 21:15:11 FileManager Info listening on 0.0.0.0:30033
2010-07-14 21:15:11 VirtualServer Info listening on 0.0.0.0:9987
2010-07-14 21:15:11 CIDRManager Info updated query_ip_whitelist ips: 127.0.0.1,
2010-07-14 21:15:11 Query Info listening on 0.0.0.0:10011
2010-07-14 21:15:18 VirtualServer Info client connected 'The Music Box'(id:17) from xxx.xxx.xxx.xxx:xxxx
2010-07-14 21:15:21 VirtualServer Info client connected 'Tearlow'(id:2) from xxx.xxx.xxx.xxx:xxxx
2010-07-14 21:31:02 VirtualServer Info client (id:6) was removed from servergroup 'Normal'(id:7) by client 'Tearlow'(id:2)
>> Here the testing starts...
2010-07-14 22:09:37 VirtualServer Info client connected 'Rodea'(id:11) from xxx.xxx.xxx.xxx:xxxx
2010-07-14 22:09:37 VirtualServer Info client disconnected 'Rodea'(id:11) reason 'invokerid=0 invokername=Server reasonmsg=Anti-Spam measure, you will be able to reconnect in 00:03:12 bantime=300'
2010-07-14 23:08:13 VirtualServer Info client connected 'Rodea'(id:11) from xxx.xxx.xxx.xxx:xxxx
2010-07-14 23:08:14 VirtualServer Info client disconnected 'Rodea'(id:11) reason 'invokerid=0 invokername=Server reasonmsg=Anti-Spam measure, you will be able to reconnect in 00:12:17 bantime=300'
2010-07-14 23:08:40 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) with values (value:1) was added by 'Tearlow'(id:2) to client (id:11)
>> Removes "Rodea" from the Temp. Ban list. Yet the same thing occured again as you can see...
>> From here on I messed around and accidently added the wrong things that was later on fixed back again but as you can see, She's still being kicked.
>> I will have a look at the Database later but if there are other solutions I'd like to hear them ;)
2010-07-14 23:09:00 VirtualServer Info client connected 'Rodea'(id:11) from xxx.xxx.xxx.xxx:xxxx
2010-07-14 23:09:01 VirtualServer Info client disconnected 'Rodea'(id:11) reason 'invokerid=0 invokername=Server reasonmsg=Anti-Spam measure, you will be able to reconnect in 00:13:32 bantime=300'
2010-07-14 23:09:05 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) with values (value:1) was added by 'Tearlow'(id:2) to client (id:11)
2010-07-14 23:09:06 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) with values (value:1) was added by 'Tearlow'(id:2) to client (id:11)
2010-07-14 23:09:09 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) with values (value:0) was added by 'Tearlow'(id:2) to client (id:11)
2010-07-14 23:09:17 VirtualServer Info permission 'i_needed_modify_power_client_ignore_antiflood'(id:65441) with values (value:100) was added by 'Tearlow'(id:2) to client (id:11)
2010-07-14 23:09:18 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) with values (value:0) was added by 'Tearlow'(id:2) to client (id:11)
2010-07-14 23:09:30 VirtualServer Info client connected 'Rodea'(id:11) from xxx.xxx.xxx.xxx:xxxx
2010-07-14 23:09:30 VirtualServer Info client disconnected 'Rodea'(id:11) reason 'invokerid=0 invokername=Server reasonmsg=Anti-Spam measure, you will be able to reconnect in 00:15:28 bantime=300'
2010-07-14 23:09:37 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) with values (value:1) was added by 'Tearlow'(id:2) to client (id:11)
2010-07-14 23:09:50 VirtualServer Info client connected 'Rodea'(id:11) from xxx.xxx.xxx.xxx:xxxx
2010-07-14 23:09:50 VirtualServer Info client disconnected 'Rodea'(id:11) reason 'invokerid=0 invokername=Server reasonmsg=Anti-Spam measure, you will be able to reconnect in 00:15:49 bantime=300'
2010-07-14 23:09:53 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) with values (value:0) was added by 'Tearlow'(id:2) to client (id:11)
2010-07-14 23:10:04 VirtualServer Info permission 'i_needed_modify_power_client_ignore_antiflood'(id:65441) was deleted by 'Tearlow'(id:2) from client (id:11)
2010-07-14 23:10:34 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) with values (value:0) was added by 'Tearlow'(id:2) to client (id:11)
2010-07-14 23:10:38 VirtualServer Info permission 'i_needed_modify_power_client_ignore_antiflood'(id:65441) with values (value:100) was added by 'Tearlow'(id:2) to client (id:11)
2010-07-14 23:10:43 VirtualServer Info permission 'i_needed_modify_power_client_ignore_antiflood'(id:65441) was deleted by 'Tearlow'(id:2) from client (id:11)
2010-07-14 23:11:02 VirtualServer Info client connected 'Rodea'(id:11) from xxx.xxx.xxx.xxx:xxxx
2010-07-14 23:11:03 VirtualServer Info client disconnected 'Rodea'(id:11) reason 'invokerid=0 invokername=Server reasonmsg=Anti-Spam measure, you will be able to reconnect in 00:15:17 bantime=300'
2010-07-14 23:11:12 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) with values (value:0) was added by 'Tearlow'(id:2) to client (id:11)
2010-07-14 23:11:15 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) was deleted by 'Tearlow'(id:2) from client (id:11)
2010-07-14 23:12:07 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) with values (value:1, negated:0, skipchannel:0) was added by 'Tearlow'(id:2) to servergroup 'Girlfriend Power'(id:12)
2010-07-14 23:12:20 VirtualServer Info client connected 'Rodea'(id:11) from xxx.xxx.xxx.xxx:xxxx
2010-07-14 23:12:21 VirtualServer Info client disconnected 'Rodea'(id:11) reason 'invokerid=0 invokername=Server reasonmsg=Anti-Spam measure, you will be able to reconnect in 00:14:40 bantime=300'
2010-07-14 23:12:55 VirtualServer Info permission 'b_client_ignore_antiflood'(id:20641) was deleted by 'Tearlow'(id:2) from servergroup 'Girlfriend Power'(id:12)
2010-07-14 23:13:56 VirtualServer Info client connected 'Rodea'(id:11) from 86.120.148.7:2269
2010-07-14 23:13:57 VirtualServer Info client disconnected 'Rodea'(id:11) reason 'invokerid=0 invokername=Server reasonmsg=Anti-Spam measure, you will be able to reconnect in 00:21:13 bantime=300'
Around here is where I'am right now, the only thing I can think of after attempting poisonpanik's Idea- At no success sadly...
