Results 1 to 9 of 9
    April 2010
    Greece
    2 Different Servers(not Virtual)
    I want to run from my pc 2 server not virtual but 2 different folders the ts server.But how i can set the different ip and port for the second server ?
    Iwant use
    1 server i use ip:xxxxxx.dyndns.com port : default
    and in 2 server ip:zzzzz.dyndns.com port : 9999
    February 2006
    Texas, USA
    4,143
    I can't be positive since I have not tried this but you don't need a 2nd IP if both servers are running on the same machine. Using different ports should be all you need to do to connect to server 1 or server 2 with the same IP
    April 2010
    Greece
    how i can set the ip in server ?
    i have 2 dns
    February 2006
    Texas, USA
    4,143
    Review the server query manual to find how to set a port other than default. I am at work and don't have access to the manual to tell you the specifics.
    Also take a look in the server_quickstart.txt
    March 2010
    23
    I don't think that this is possible because otherwise you would be able to circumvent the limitation set upon the number of servers by the developers.
    Eddy
    February 2006
    Texas, USA
    4,143
    How so?
    Let's assume he runs 2 servers without NPLs. No harm, no foul. Now lets assume he runs 1 server with an NPL and 1 without. Still no harm, no foul. He should not have more than 1 NPL as they only issue 1 NPL per organization.
    NPL = up to 10 virtual servers with 512 clients between all servers
    w/out NPL = 1 virtual server with up to 32 clients
    March 2010
    23
    How so?
    in the "license.txt" file in the installation directory of the TeamSpeak 3 Server I have found the following text:
    Under "5.1. Non-Profit License: Unregistered":
    "b. The individual or organization may host up to 32 slots using only 1 Virtual Server for their entire operation. Exceeding the use of 32 slots or 1 Virtual Server over multiple physical machines operated by the same individual or organization is strictly prohibited."
    Under: "5.2. Non-Profit License: Registered":
    "c. The individual or organization may host up to 512 slots using a maximum of 10 Virtual Servers for their entire operation. Any combination of slots or Virtual Servers over multiple physical machines is allowed, as long as the individual or organization does not exceed 512 slots or 10 Virtual Servers..."
    Eddy
    February 2006
    Texas, USA
    4,143
    Good point Eddy
    August 2008
    Texas
    6
    Each server instance creates a "virtual" server, so running more than ONE server on a free license is forbidden. That would create 2 virtual servers.
    You can create on an NPL any combination of virtual servers not exceeding 10.
  1. Too many virtual servers - NPO?
    By Lexenstar in forum Server Support
    Last Post: February 8th, 2015, 03:53 PM
  2. [Not possible] NPL +2 virtual servers +2 physical servers
    By Un0rThOd0x in forum Server Support
    Last Post: June 18th, 2014, 08:57 AM
  3. Replies: 1
    Last Post: October 8th, 2012, 04:44 PM
  4. Replies: 1
    Last Post: May 12th, 2012, 06:46 PM
  5. [Resolved] How can I get my TS servers virtual ID?
    By nbtc971 in forum General Questions
    Last Post: November 3rd, 2011, 02:44 AM
