Results 1 to 13 of 13
    April 2010
    USA
    Solved [Solved] [Not Possible] Global Mute
    Is there a way to global mute in TS3 ?
    February 2006
    Texas, USA
    4,143
    Turn the volume slide on the client down all the way... or just click MUTE SPEAKERS/HEADPHONES
    April 2010
    USA
    I am wanting to be able to select another user in the channel that I am channel admin for and be able to mute them for for all people in that channel. The mute key that comes up then right clicking the user is only a local mute that mutes them for me only
    2,360
    Quote Originally Posted by tsonka View Post
    You can do this as server admin:
    Set the client permission (of this target client) for talk power to -1 and tick negate. Now this client is muted on the whole server for everyone.
    Of course you can also create a server group with this permission and just add the client to this group.
    18,513
    There is no real function to mute someone on whole server.
    The only option is like Stefan1200 already said, but user still grant him talk power to talk.
    June 2010
    Lake Superior
    14
    Can I globally Mute, except a few?
    Okay I am new to all this.
    Teamspeak build 11315
    version 4.6.2 beta 3
    When I have a Guest speaker I want to be able to globally mute everyone except the speaker and myself and maybe a couple of others. Is there a global mute as you enter team Speak setting?
    Then I can unmute the couple people I want to speak?
    February 2006
    Texas, USA
    4,143
    Set the needed_talk_power for that channel higher than everyone's talk_power in that channel. Then you can right click->grant voice.
    57
    Its a quite old post i know, but will there be a function to globally mute s.o. without this "trick"?
    Regards,
    Phil
    18,513
    Edit by myself
    The answer is still: This is not possible and won't be included.
    Use the needed Talk Power for a channel. This permission makes it possible for you to mute everyoneenough Talk Power.
    Also remove the ability to grant Talk Power ot others.
    57
    The answer is still: There is no way.
    Do you refer to your previous post? Because this answer could suggest a "there might be this function in the future"
    18,513
    I updated my Statement :-/
    Everything was said in post's before.
    June 2010
    Mississippi (USA)
    30
    i made a group that i can set someone to that mutes the person globaly but it didnt work on server admins. gonna have to figure out how to fix that so it will be eaisier to mute them instead of having to go through the Client permissions.
    18,513
    Remove the Talk power from Server Admin group or set it to a value of 0 or -1.
    Or Remove the skip flag for Talk Power.
    The Server Admin group has b_client_skip_channelgroup_permissions enabled by default.
    This value sets Skip to every permission for that group.
    This means no Channel Group & Channel permission overwrites the values for an Server Admin.
    When you plan to remove this permission, then you have to skip each permission manually.
    Think about it.
  1. Global mute
    By Rinaldus in forum General Questions
    Last Post: September 21st, 2011, 11:04 AM
  2. Global Mute
    By reaply in forum Permission System
    Last Post: May 13th, 2011, 04:29 AM
  3. Global Mute
    By reaply in forum Client Plugins / Lua Scripts
    Last Post: May 2nd, 2011, 07:05 AM
  4. [Solved] Can you "Global Mute" all drivers?
    By nwo-fubar in forum General Questions
    Last Post: March 14th, 2010, 09:16 AM
