Page 2 of 6 FirstFirst 1234 ... LastLast
Results 16 to 30 of 77
  1. #16
    May 2011
    Quote Originally Posted by florian_fr40 View Post
    MacOS, you'r wrong.
    This script use an external database to store information.
    Yes, I know. But the question was did we need MySQL database on which TS3 server is running. So the answer is we can use SQLite and MySQL version of TS3 database.
  2. #17
    May 2010
    6,310
    Ok yes
    @Cobra
    This scritp is very old and I don't remember all function
    I will rebuild it for the end of the week.
  3. #18
    February 2010
    Internet
    62
    Auto Delete channels without activity x days is very usefull for me.
    Florian, this script, when you rebuild, will work for big servers? 3.000 + channels, 300MB db.
    Because some script have problems to "check" everything....
    Thank you!
  4. #19
    May 2011
    Nice thing to add imho is exception list, because some channels don't need to be checked (for example informational channels or channels with list of admins).
  5. #20
    May 2010
    6,310
    @MacOS ok maybe
    - Update -
    To add all desired functions/options and also for the big public servers, this tool will be rebuilt like a software (not a php script).
    It will be add in the addons section the next weeks.
  6. #21
    Baghdad, Iraq
    367
    addon ? client side ? or its stand alone ?
    i hope it will have the option to run as stand alone on Linux servers if not now then maybe in a future update or something?
  7. #22
    October 2011
    Remove Channel and Sub-Channel after X days unused ???
    Is possible to make any type of setting on an channel and its sub channels that stay for more than 'X' days without anyone connect, the TeamSpeak 3 will automatically delete the Canal and its sub channels?
    Regards.
  8. #23
    September 2011
    7
    Does something exits with Servers? Does a server on a instance will be deleted if there was 10 Days no one on the server? That will be perfect for my sponsoring!
    Edit: How i use this script for only one server at a instance?
  9. #24
    May 2010
    6,310
    Do you mean a same behavior but for virtual server instead the channel ?
    And accordgin your private message, do you mean the same tool for only one virtual server without Teamspeak instance control (without query access ) ?
  10. #25
    September 2011
    7
    No i mean, that only one virtual server (selected by port) has to been checked of the inactivity to the channels. Do you know what i meen?
    --- Merged ---
    I mean this is just a virtual server checks whether the channel is Activity. Of course I would like to register via query server and then want to specify only the server port, does not automatically select the entire instance. shows you what I mean?
  11. #26
    May 2010
    6,310
    Ok, this is how the software version will work.
    (You'll can choose which virtual server will be checked on each instance)
  12. #27
    September 2011
    7
    The software check all virtual server onan instace or??
    --- Merged ---
    i think all servers will be checked or?
    Instance create succes
    Server port 2000 was added into the database
    Server port 2005 was added into the database
    Server port 2006 was added into the database
    Server port 2007 was added into the database
    Server port 2008 was added into the database
    Server port 2009 was added into the database
    Server port 2010 was added into the database
    Server port 2012 was added into the database
    Server port 22222 was added into the database
  13. #28
    May 2010
    6,310
    I repeat myself:
    You'll can select which virtual server will be checked by the new software version.
    http://forum.teamspeak.com/showthrea...854#post296854
  14. #29
    September 2011
    7
    Where can it be download?
    Edit by mod
    Please read my provious message, I wrote "it will add in addons section"
  15. #30
    November 2011
    Can't wait for the software version of this. Will be an awesome tool when it is done.
    Thanks florian_fr40 for all your hard work.
  1. Auto group for users whoose x days on ts3
    By dramcio in forum General Questions
    Last Post: January 18th, 2014, 03:18 PM
  2. Delete Users that weren't online for x Days?
    By Jupdi in forum Server Support
    Last Post: September 5th, 2012, 11:38 PM
  3. Auto Delete channels
    By Ar2rJke in forum Tools / Web Based
    Last Post: June 26th, 2012, 01:45 PM
  4. [request]a tool to automatically delete channel for x days(improved)
    By El_makong in forum Client Plugins / Lua Scripts
    Last Post: March 22nd, 2012, 05:43 PM
