Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 63
  1. #16
    February 2005
    Germany / Berlin
    26
    Perhaps this helps:
    2010-06-19 15:22:10.548499|INFO |ServerLibPriv | | Server Version: 3.0.0-beta25 [Build: 11421], Linux
    2010-06-19 15:22:10.549051|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2010-06-19 15:22:10.549119|INFO |DatabaseQuery | | dbPlugin version: 3.6.21
    2010-06-19 15:22:10.549618|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2010-06-19 15:22:10.654316|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-06-19 15:22:10.675197|INFO |SQL | | updated permissions to version 3
    2010-06-19 15:22:10.685061|INFO |SQL | | updated permissions to version 4
    2010-06-19 15:22:10.695261|INFO |SQL | | updated permissions to version 5
    2010-06-19 15:22:10.789525|INFO |Accounting | | Licensing Information
    2010-06-19 15:22:10.790495|INFO |Accounting | | type : Non-profit
    2010-06-19 15:22:10.791319|INFO |Accounting | | starting date : Mon Dec 28 23:00:00 2009
    2010-06-19 15:22:10.792077|INFO |Accounting | | ending date : Tue Dec 28 23:00:00 2010
    2010-06-19 15:22:10.792820|INFO |Accounting | | max virtualservers: 10
    2010-06-19 15:22:10.793552|INFO |Accounting | | max slots : 512
    2010-06-19 15:22:10.832607|INFO |FileManager | | listening on 0.0.0.0:30033
    2010-06-19 15:22:10.885843|INFO |VirtualServer | 6| listening on 0.0.0.0:9987
    2010-06-19 15:22:10.886914|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2010-06-19 15:22:10.888223|INFO |Query | | listening on 0.0.0.0:10011
    2010-06-21 18:21:06.720701|INFO |VirtualServer | 6| client connected 'ABC'(id:280) from 89.14.XXX.XXX:55035
    2010-06-21 18:24:09.251245|INFO |VirtualServer | 6| client connected 'DEF'(id:57) from 89.14.XXX.XXX:64574
    2010-06-21 18:53:44.041799|INFO |VirtualServer | 6| client connected 'GHI'(id:188) from 95.117.XXX.XX:60340
    2010-06-21 19:09:47.445311|INFO |VirtualServer | 6| client disconnected 'ABC'(id:280) reason 'reasonmsg=connection lost'
    2010-06-21 19:09:47.446997|INFO |VirtualServer | 6| client disconnected 'DEF'(id:57) reason 'reasonmsg=connection lost'
    2010-06-21 19:09:47.448905|INFO |VirtualServer | 6| client disconnected 'GHI'(id:188) reason 'reasonmsg=connection lost'
    Please note: The time isn't correct, the correct time would be 2h later.
  2. #17
    February 2005
    Germany / Berlin
    26
    We've tried to locate the problem and after the disconnect from the three users they have tried to login automaticly. It needed exactly 10 Minutes until they connected again with the teamspeak. So could it be that there is an problem with an automatic ban system or something like this? (But there is no message in the server or client that there was an ban / kick)
  3. #18
    Taiwan
    313
    With regard to this issue, I do have a temp solution
    1. change the IP
    or
    2. change the server port
    trust me, once you changed either one, and all those who were having problems will instantly have their problem solved. as to the cause to this still remains unknown
  4. #19
    Texas
    745
    intermittent connection issues for some clients
    my server has been dropping most clients at random times for months. i was running on xp x86 until recently. i just upgraded to win7 x64 and am havingg the same issues. i have a npl. my current server has a dual core amd processor with 4 gigs of ram. i am running the latest version of teamspeak. my router is a verizon router. my server is dmz host. ports are also forwarded. i use windows firewall and MSE antivirus.
  5. #20
    February 2010
    brazil
    55
    well im not sure about your mysql server but most of the webhosters arround, who provide mysql service, have a limitation on server access, like 50 query at same time, so you can contact your mysql server hoster and ask them if that is true, and if is that so, if they have a log or something to make sure if that is what happend.
    and just maybe a silly question, but why use mysql, at out side host, when you could use sqlite w/o this problem?
  6. #21
    Taiwan
    313
    Quote Originally Posted by loest View Post
    Just to correct you, this problem happens EVEN if you use SQLIte.
    As to someone private messaged me about the exact steps on how to change server port with serverquery, here are the steps to do it.
    1. log in to the ServerQuery
    2. Stop the virtual server
    3. perform neccessary changes
    4. Start virtual server again.
    5. logout of ServerQuery
    here are steps in action, with steps described noted on the end of each command
    login serveradmin your_server_admin_password_here (Step 1)
    serverstop sid=your_server's_sid_here (Step 2)
    serveredit virtualserver_port=your_new_server_port sid=your_server's_sid_here (Step 3)
    serverstart sid=your_server's_sid_here (Step 4)
    quit
    Here's what'd probably look like on your screen if you followed the steps above
    TS3
    login serveradmin myServerPass
    error id=0 msg=ok
    serverstop sid=1
    error id=0 msg=ok
    serveredit virtualserver_port=9999 sid=1
    error id=0 msg=ok
    serverstart sid=1
    error id=0 msg=ok
    quit
    And that's it.
    If you changed the server port and the server doesn't seem to be listening on the new port, try close the server process with the command "serverprocessstop"and force the server to complete shut down and they try start the server again.
  7. #22
    February 2010
    brazil
    55
    well alright i see at my log that error too, im using sqlite, but not so often.
    Line 26: 2010-06-06 10:31:13.814867|ERROR   |VirtualServer |  1| connectionLost() invalid clientID: 3
    	Line 27: 2010-06-06 10:31:14.817943|ERROR   |VirtualServer |  1| connectionLost() invalid clientID: 4
    	Line 28: 2010-06-06 10:31:14.818620|ERROR   |VirtualServer |  1| connectionLost() invalid clientID: 5
    	Line 29: 2010-06-06 10:37:58.863162|ERROR   |VirtualServer |  1| connectionLost() invalid clientID: 1
    	Line 44: 2010-06-06 23:02:10.799647|ERROR   |VirtualServer |  1| connectionLost() invalid clientID: 0
    	Line 72: 2010-06-07 15:19:54.272663|ERROR   |VirtualServer |  6| connectionLost() invalid clientID: 0
    	Line 76: 2010-06-07 22:53:36.644635|ERROR   |VirtualServer |  1| connectionLost() invalid clientID: 0
    	Line 130: 2010-06-09 05:53:13.566705|ERROR   |VirtualServer |  6| connectionLost() invalid clientID: 17
    	Line 150: 2010-06-10 02:22:31.176279|ERROR   |VirtualServer |  5| connectionLost() invalid clientID: 0
    	Line 174: 2010-06-10 05:29:02.412412|ERROR   |VirtualServer |  4| connectionLost() invalid clientID: 0
    	Line 177: 2010-06-10 21:55:51.973752|ERROR   |VirtualServer |  4| connectionLost() invalid clientID: 7
    	Line 185: 2010-06-11 01:29:54.929055|ERROR   |VirtualServer |  1| connectionLost() invalid clientID: 0
    	Line 186: 2010-06-11 01:30:35.706865|ERROR   |VirtualServer |  1| connectionLost() invalid clientID: 0
    	Line 187: 2010-06-11 01:46:56.966396|ERROR   |VirtualServer |  1| connectionLost() invalid clientID: 0
    	Line 250: 2010-06-12 18:39:59.147676|ERROR   |VirtualServer |  4| connectionLost() invalid clientID: 0
    	Line 290: 2010-06-14 01:55:49.532263|ERROR   |VirtualServer |  7| connectionLost() invalid clientID: 0
    	Line 347: 2010-06-17 03:09:05.817012|ERROR   |VirtualServer |  6| connectionLost() invalid clientID: 0
    	Line 357: 2010-06-19 17:44:14.680191|ERROR   |VirtualServer |  3| connectionLost() invalid clientID: 0
    	Line 360: 2010-06-20 00:46:59.068747|ERROR   |VirtualServer |  6| connectionLost() invalid clientID: 5
    	Line 372: 2010-06-21 08:55:08.876150|ERROR   |VirtualServer |  2| connectionLost() invalid clientID: 1
    	Line 377: 2010-06-22 00:48:36.497490|ERROR   |VirtualServer |  1| connectionLost() invalid clientID: 0
    	Line 382: 2010-06-22 22:41:32.590350|ERROR   |VirtualServer |  1| connectionLost() invalid clientID: 0
    server is up for 18 days w/o any restart or changes and only found 22 conection lost for that reason.
  8. #23
    February 2005
    Germany / Berlin
    26
    Damn, I've tried this but I got the following error:
    TS3
    login serveradmin XXXXXXXX
    error id=0 msg=ok
    serverstop sid=6
    error id=0 msg=ok
    serveredit virtualserver_port=9999 sid=6
    error id=1024 msg=invalid\sserverID
    So I can't change the port, but I've jus have this one virtual server. Why does it come and is there a possibility to change the sid to 1 for example? Could this be the problem?
    Greetz,
    Alex
  9. #24
    October 2003
    2,527
    You have to select the virtual server before you can change the port. Here's an example:
    login <username> <password>
    use <server_id>
    serveredit virtualserver_port=<new_port>
    serverstop sid=<server_id>
    serverstart sid=<server_id>
  10. #25
    February 2005
    Germany / Berlin
    26
    Thanks, it works now! So let's see if this work around will help for this bug.
  11. #26
    February 2005
    Germany / Berlin
    26
    So, what I've to say it not such a surprise: It doesn't work like we hope. I've lost again my connection for almost 10 minutes until I connected back automaticly.
    PLEASE FIX THIS PROBLEM!
  12. #27
    germany
    56
    i had the same problem 1 - 2 month ago....i have restartet my vps...since then it works. donīt know if this helps you.
  13. #28
    February 2005
    Germany / Berlin
    26
    Are there any news from the developers about this bug / problem? Will it be fixed in the (soon?) incoming Beta 26?
  14. #29
    Taiwan
    313
    My lucky port is 8000, yeah, even though I know that changing port does fix, but there are just seem to be some "unlucky" ports that when you change, it doesn't do a thing. So you should try some other ports until it works for you :P
  15. #30
    February 2005
    Germany / Berlin
    26
    Exclamation
    I think we will try it, but there has to be a solution by the Teamspeak team. You can't change the port again and again without losing the user at the own teamspeak server!
    But what's really matters: Why is there no status update from the team? It would be much easier to wait for the patch if we know a status and a time frame for the release of a fix, because that's no error which shows a wrong color or something else, it's a critical bug.
  1. Replies: 1
    Last Post: December 5th, 2013, 04:25 PM
  2. [On Todo] complainlist "invalid ClientID"
    By Magissia in forum Windows
    Last Post: March 2nd, 2013, 07:44 AM
  3. ServerGroup Dialoug says "invalid clientID"
    By Sebi94 in forum Server Support
    Last Post: October 25th, 2012, 03:38 PM
  4. How to remove "connect" and "disconnect" popups on overlay?
    By Floydrose in forum General Questions
    Last Post: July 30th, 2012, 02:35 PM
  5. [Fixed] Problem with simbol "=" in Web server list
    By Kaosvf in forum Bug Reports [EN/DE]
    Last Post: August 5th, 2010, 02:02 PM
