Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 63
  1. #46
    Taiwan
    313
    Unfortunetly, Server 11927 STILL generate this problem.
    I think the devs needs to generate more output other than just the default logs for those who are most likely to encounter these kind of problems = =
  2. #47
    Catalunya
    2,350
    Solved, thanks
  3. #48
    February 2005
    Germany / Berlin
    26
    Quote Originally Posted by willy_sunny View Post
    Yep, the problem still exists. We have now almost two months with this problems, almost ALL (long year) players from our TS run away and nothing changed... it's such a poor situation. Could you generate a special developer update or something to get more informations? I don't understand how you want to fix a problem which you can't reproduce - but of course, you don't ask the people for details or gave them something to log it's more in detail.
  4. #49
    July 2002
    2,192
    Post drop log with most recent server version please...also the fix we added will only prevent those timeout that were preceeded by a line in the log saying something like "Incorrect time source detected". If you didn't get this line before in the log there is no fix with this update.
    You think my answer is stupid ? Read This:
    http://www.catb.org/~esr/faqs/smart-...ons.html#intro
    In a world without fences and walls - who needs windows and gates ?
  5. #50
    July 2010
    Peru
    Hi everyone,
    I'm having the exact same issue but I'm not 100% sure this is a problem with TeamSpeak. Reason why I say this is because when this happens, I also loose all my SSH sessions to the server.
    I'm using CentOS Linux 5.5 x86_64 with kernel 2.6.18-194.8.1.el5 (latest version). All RPMs are updated as well. This is a dedicated server so no limitations in terms of DB connections. I started testing TS3 since version beta22 and seen it in beta25 and beta26. Currently I'm running version 3.0.0-beta26 build 11927 (64 bits). I'm using the libts3db_mysql plugin but the same happens with libts3db_sqlite3.
    I'm always connected to my server through SSH and never payed much attention to these disconnects until recently I started timestamping everything. Noticed my SSH goes down almost at the same time TS disconnects everyone (difference of few seconds). The odd part is that I'm running constant pings to my server and I dont get a single "request timeout", which means is only TCP/UDP connections.
    At first I thought it was the ip_conntrack table being full and droping packets (I use iptables as firewall), so I increased it but then again I keep seeing my users disconnect from TS. In my case, I can reconnect few seconds later. Check all my logs (messages, dmesg, etc.) and nothing that can point me to the cause of these. I've already tried with different kernel versions and nothing.
    I'm doing some more changes to my server in terms of OS to see if something else is affecting my TCP/UDP connections. Eventually I'll try removing completely all my iptables rules and see if that changes anything. I haven't tried running TS on a different port yet.
    As soon as my server disconnects everyone again, I'll post my logs.
  6. #51
    tester123 Guest
    No connection to server
    Hey,
    I made a Ts3 server 2 days ago on a Server with a fixed IP.
    I can connect to the server as usual and i could use Admin token. After i used the server for about 5 mins it started to say "connection lost" and then i cant connect to the server for about 10 min. Always when i can connect again it kicks me after 5 mins. Any suggestions? or u need further information? I thought it could be Auto-ban ot sth like that but i turned all bans off and still no connection. Thx for fast help
    Edit: I know the Server was online at that time because the server is nor only for about 30 hours when i click on it so it was me that couldnt connect
  7. #52
    June 2010
    Russia
    11
    Disconnect every 2 min
    PHP Code:
    2010-08-21 19:46:20.906250        Info    Logging startedclientlib version3.0.0-beta26 [Build12040]
    2010-08-21 19:46:21.437500    ClientUI    Info    TeamSpeak 3 client version3.0.0-beta26 [Build12040]
    2010-08-21 19:46:21.437500    ClientUI    Info    Qt version4.6.2
    2010
    -08-21 19:46:21.437500    ClientUI    Info    Using configuration locationD:/Program Files/TeamSpeak 3 Client/config/ts3clientui_qt.conf
    2010
    -08-21 19:46:21.937500    ClientUI    Info    Last update check was: �� 21. ��� 10:38:25 2010
    2010-08-21 19:46:24.546875    PreProSpeex    Info    Speex versionspeex-1.2beta3
    2010
    -08-21 19:53:02.093750    Bookmarks    Info    Disconnecttotal time396 1039
    2010
    -08-21 19:53:02.093750    ClientUI    Info    Connecting to next server...
    2010-08-21 21:21:44.890625    Bookmarks    Info    Disconnecttotal time5315 6354
    2010
    -08-21 21:21:44.890625    ClientUI    Info    Connecting to next server...
    2010-08-21 21:21:45.140625    EncodeCelt    Info    CELT bitstream version0x8000000b
    2010
    -08-21 21:21:56.609375    Bookmarks    Info    Disconnecttotal time11 1326451
    2010
    -08-21 21:21:56.609375    ClientUI    Info    Connecting to next server...
    2010-08-21 21:33:52.140625    ClientUI    Info    Failed to query client server groups1794
    2010
    2010
    -08-21 21:33:52.140625    Bookmarks    Info    Disconnecttotal time715 7069
    2010
    -08-21 21:33:52.140625    ClientUI    Info    Connecting to next server...
    Server: beta 27
    Client: beta26
  8. #53
    US
    133
    Server b27
    I'm seeing a lot of my members disconnect and auto reconnect. This is happening quite often. I don't have access to the server logs (Hosted server) so I'm not sure what data I can provide.
    However, one of the weird things was, there were three users in particular at the time (I had 70 online at that time) that I would see disconnect and reconnect at the exact same time. Two of them had client b26 and one had client b22.
    I've also done spot checks as I see people disconnect and reconnect and their client versions range from b22-b26.
    This leads to me believe it's probably something server side. If you need any info, please let me know how and what to get for you and I'll do so.
  9. #54
    Rafter Guest
    Connection Lost..
    Clients on my TS3 server get alot of those disconnections. And it is starting to get really annoying.
    We are only few total clients on my server. Max 10-15 at the same time and often it is the same 5-8 clients using it each day.
    They have a lot of disconnections
    Sometimes 8/pr day, sometimes 3, 4, 7, 5, 2... Sometimes the clients on the server gets disconnected at the same time, and then they can reconnect almost immediately.
    The messages are just standard: client disconnected ..... reasonmsg=connection lost.
    Really annoying. What could be the issue, and how do I fix it?
    Using server: 3.0.0-beta27 [build: 12002]
    My own client is 3.0.0-beta26 [build: 12040], used by most of the clients. 1 client uses beta22.
  10. #55
    February 2006
    Texas, USA
    4,143
    The disconnect issue is being worked on. Not sure when it will be fixed but hopefully when the get it fixed it will fix your problem.
  11. #56
    August 2010
    germany
    dito
    I second that. We started to have the same problems a couple days ago. You get kicked suddenly from the server and can reconnect after a few seconds. The log states "invalid client id: 0". Running on Suse Linux 10.3
  12. #57
    18,151
    We are able to reproduce this Bug!
    Thank you English Talk from our public server!!
    To fix it temporarily, set i_client_max_clones to 0 for all groups!!!!!
    This will be fixed in Server Version: 3.0.0-beta28-pre [Build: 12203] or newer.
  13. #58
    February 2005
    Germany / Berlin
    26
    And it doesn't work... we have still the disconnects.
  14. #59
    18,151
    Quote Originally Posted by Dragi View Post
    Because your disconnects arn't the same as reported in the main post with that error Error connectionLost() invalid clientID: 0
    I have no idea, why you have "Normal" timeouts.
  15. #60
    September 2010
    Sorry, but these are not "normal Timeouts", a normal Timeout is if i get "connection lost" and after that i can reconnect to the Server and not being blocked for 10 minutes.
    Is it so hard to find the Problem ? Now its 3 Month with this annoying Problem. Most of our Users left our Server, so this ist not "normal" for us. U are invited to connect to our Server and to see how "normal" this Problem is. Maybe u can reproduce the Problem.
  1. Replies: 1
    Last Post: December 5th, 2013, 04:25 PM
  2. [On Todo] complainlist "invalid ClientID"
    By Magissia in forum Windows
    Last Post: March 2nd, 2013, 07:44 AM
  3. ServerGroup Dialoug says "invalid clientID"
    By Sebi94 in forum Server Support
    Last Post: October 25th, 2012, 03:38 PM
  4. How to remove "connect" and "disconnect" popups on overlay?
    By Floydrose in forum General Questions
    Last Post: July 30th, 2012, 02:35 PM
  5. [Fixed] Problem with simbol "=" in Web server list
    By Kaosvf in forum Bug Reports [EN/DE]
    Last Post: August 5th, 2010, 02:02 PM
