Results 1 to 9 of 9
    May 2010
    Kiruna, Sweden
    Wierd connection problems after Beta22
    Hello people!
    Got some wierd problems going on after server move and upgrade to beta 22. Running xp sp2, ports are set up correctly through the router.
    Had some friends without problem connecting to the server yesterday with one who couldn't. Today I have restarted the serverand done a fresh install. The one who couldnt join yesterday cant join today, asked them both to upgrade to latest client and now no one of them can connect. After messing around some one of them could join but the other couldn't.
    TS3 has always worked perfectly up untill beta 22.
    Can it have anything to do with this?
    "2010-05-12 09:32:17.859375|WARNING |Accounting | | Unable to find valid license key, falling back to limited "
    May 2010
    Kiruna, Sweden
    We just came to the conclusion that they can connect one time each if their computers has been rebooted. The second time they cannot connect.
    Suggestions?
    May 2010
    Indiana
    I am having the same issue but to elaborate a little more;
    The only time I have this problem is when there are 2 people trying to connect to TS that are sharing the same internet connection.
    Both users are running 3.0.0-beta20 [Build: 10723] QT 4.6.2
    Both users can connect 1 at a time but never at the same time.
    I have been having this issue ever since I installed beta22
    I am running 3.0.0-beta22 [Build: 10723] on Windows 2003 server SP2.
    Any help on this issue would be greatly appreciated.
    Thanks.
    December 2004
    RF
    3,008
    Some server logs to comments on the issue, ReFro?
    May 2010
    Indiana
    Here is the most recent log file, but I don't really see any information that would help with this issue.
    2010-05-11 22:09:23.687647|INFO    |ServerLibPriv |   | Server Version: 3.0.0-beta22 [Build: 10723], Windows
    2010-05-11 22:09:23.718897|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, (c)TeamSpeak Systems GmbH
    2010-05-11 22:09:23.718897|INFO    |DatabaseQuery |   | dbPlugin version: 3.6.21
    2010-05-11 22:09:23.734522|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2010-05-11 22:09:23.812647|INFO    |SQL           |   | pruning old database log entries where timestamp is older than 90 days
    2010-05-11 22:09:25.265772|INFO    |Accounting    |   | Licensing Information
    2010-05-11 22:09:25.265772|INFO    |Accounting    |   | type              : Non-profit
    2010-05-11 22:09:25.265772|INFO    |Accounting    |   | starting date     : Sat May 08 00:00:00 2010
    2010-05-11 22:09:25.265772|INFO    |Accounting    |   | ending date       : Sun May 08 00:00:00 2011
    2010-05-11 22:09:25.281397|INFO    |Accounting    |   | max virtualservers: 10
    2010-05-11 22:09:25.281397|INFO    |Accounting    |   | max slots         : 512
    2010-05-11 22:09:25.422022|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2010-05-11 22:09:25.578272|INFO    |VirtualServer |  1| listening on 0.0.0.0:9987
    2010-05-11 22:09:25.718897|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2010-05-11 22:09:25.718897|INFO    |Query         |   | listening on 0.0.0.0:10011
    Rest of the log is just filled with these types of entries
    2010-05-16 04:09:23.874875|INFO    |SQL           |   | pruning old database log entries where timestamp is older than 90 days
    December 2004
    RF
    3,008
    Well, I was actually interesting in the log parts related to the mentioned issue.
    May 2010
    Indiana
    In the time period that log file shows, I have had both users trying to connect at the same time but nothing seems to show up in the log about them connecting.
    Is there a setting I can change to make it a more comprehensive log file to see if we can pinpoint the issue?
    December 2004
    RF
    3,008
    You listed logs from May, 11. And skipped everything till the last line is from May, 16.
    From absence of information I can't tell you anything about issue.
    Restart server, let people (try to) login, then look in logs.
    May 2010
    6
    I have the same Problem. 2 friends of mine are not able to connect to my Server beta23 at the same time.
    Then i looked in the log file locatet in the Log-Directory, but in there is nothing written since days. No connectin from others and also noting about the restart of the server. Could there be another Logfile somewhere else?
    Here are the last lines of the Log in the Log-Folder
    2010-06-01 21:52:01.250000|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-06-01 22:52:01.250000|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-06-01 23:52:01.250000|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-06-02 00:52:01.250000|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-06-02 01:52:01.250000|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-06-02 02:52:01.250000|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-06-02 03:52:01.250000|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-06-02 04:52:01.250000|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-06-02 05:52:01.250000|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-06-02 06:52:01.250000|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    But we were using it yesterday (2010-06-09) for a short time before whe had 2 swich back to TS2 because one could not connect.
    So, where do i find the log where i see people connecting?
  1. Replies: 29
    Last Post: June 1st, 2010, 05:21 PM
