Results 1 to 4 of 4
    September 2009
    Holland
    10
    Problem with binding the IP Adress..
    Hey All,
    I am trying to run a Teamspeak 3 server on a Dedicated Linux Centos Server.
    I have already created an .ini file but i am all the time getting the same problem.
    listening on 0.0.0.0:30033
    listening on 0.0.0.0:9987
    listening on 0.0.0.0:10011
    This is my ts3server.ini.
    The IP i want to bind is in that file..
    machine_id=
    default_voice_port=9987
    voice_ip=91.198.27.175
    licensepath=
    filetransfer_port=30033
    filetransfer_ip=91.198.27.175
    query_port=10011
    query_ip=91.198.27.175
    query_ip_whitelist=query_ip_whitelist.txt
    query_ip_blacklist=query_ip_blacklist.txt
    dbplugin=ts3db_sqlite3
    dbpluginparameter=
    dbsqlpath=sql/
    dblogkeepdays=90
    logpath=logs
    logquerycommands=0
    dbclientkeepdays=30
    I really hope you can help me out..
    Greetings Peter-Jan
    July 2008
    94
    Edit by mod
    Please don't use this outdated script anymore! The script got an overhaul long time ago.
    Please use the minimal or startscript instead
    Add this command on your startparameter: ./ts3server_linux_x86 inifile=ts3server.ini
    ToM
    September 2009
    Holland
    10
    Quote Originally Posted by Nightwing View Post
    ToM
    Hey Tom,
    Thanks for your reply
    I did what u said..
    Logging started
    2010-05-22 15:15:48.223920|INFO |ServerLibPriv | | Server Version: 3.0.0-be
    ta22 [Build: 10724], Linux
    2010-05-22 15:15:48.224217|INFO |DatabaseQuery | | Please make sure you use
    the supplied ts3server_minimal_runscript.sh to run the server, or set LD_LIBRAR
    Y_PATH yourself
    2010-05-22 15:15:48.224292|CRITICAL|DatabaseQuery | | unable to load database
    plugin library "libts3db_sqlite3.so", halting!
    After that i did : ./ts3server_startscript.sh start
    But when i check the log its still not correct and i can't connect to the server..
    EDIT.
    When i try this: ./ts3server_minimal_runscript.sh inifile=ts3server.ini
    The server starts up without any problems hmm?
    2,360
    Quote Originally Posted by MetalGovy View Post
    Where is the problem? This is the right way, only start the TS3 server with one of the two start scripts.
  1. Problem with adress truxgo.net
    By Nifus in forum General Questions
    Last Post: January 28th, 2012, 12:09 AM
  2. [Resolved] Binding problem
    By vee-ell in forum Windows
    Last Post: January 21st, 2012, 05:45 PM
