Results 1 to 3 of 3
    June 2010
    cali
    need help with reinstall
    Pretty Much after the last update the TS3 server is completely down. I got to the point that I would just reinstall the whole server after the suggested updates will not work.... below is where I am at . I need step by step directions ... This is Cent OS 5.2 I am working with
    [[email protected] ~]# cd /home
    [[email protected] home]# cd teamspeak
    [[email protected] teamspeak]# cd teamspeak3-server_linux-x86
    [[email protected] teamspeak3-server_linux-x86]# ls
    CHANGELOG logs ts3server.ini
    LICENSE logs? ts3server_linux_x86
    doc serverquerydocs ts3server_minimal_runscript.sh
    libts3db_sqlite3.so sql ts3server_startscript.sh
    licensekey.dat teamspeak3-server_linux-x86-3.0.0-beta23.tar.tar
    [[email protected] teamspeak3-server_linux-x86]# ./ts3server_linux_x86 createinifile=1
    TeamSpeak Server 3.0.0-beta23 [Build: 11239]
    (c)TeamSpeak Systems GmbH
    Logging started
    2010-06-05 18:30:47.968959|INFO |ServerLibPriv | | Server Version: 3.0.0-beta23 [Build: 11239], Linux
    2010-06-05 18:30:47.985492|INFO |DatabaseQuery | | Please make sure you use the supplied ts3server_minimal_runscript.sh to run the server, or set LD_LIBRARY_PATH yourself
    2010-06-05 18:30:47.985699|CRITICAL|DatabaseQuery | | unable to load database plugin library "libts3db_sqlite3.so", halting!
    so I try to use is command
    ./ts3server_startscript.sh
    [[email protected] teamspeak3-server_linux-x86]# ./ts3server_minimal_runscript.sh
    Logging started
    2010-06-05 18:51:54.418621|INFO |ServerLibPriv | | Server Version: 3.0.0-beta23 [Build: 11239], Linux
    ./ts3server_minimal_runscript.sh: line 9: 25161 Bus error ./ts3server_linux_x86 [email protected]
    June 2010
    sweden
    you have wrong filepremissons for your files download the tar.gz file agin and use
    tar xzf teamspeak3-server_linux-x86-3.0.0-beta23.tar.gz
    and try agin.
    then copy over your config files but dont overwrite ts3server files
    Good old Germany
    222
    use the search function....
    edit by mod
    I removed you link it shows no result. Please point to a thread .
  1. TS3 update or reinstall
    By Antology in forum Windows
    Last Post: October 19th, 2015, 10:59 AM
  2. Issue after Reinstall
    By Nived in forum Windows
    Last Post: July 7th, 2011, 01:02 AM
  3. ReInstall
    By tbarlow in forum Windows
    Last Post: September 15th, 2010, 04:01 AM
  4. OS Reinstall!
    By Glazz in forum General Questions
    Last Post: February 12th, 2010, 05:38 PM
