Results 1 to 9 of 9
    February 2010
    Seattle
    69
    Beta 21 - FMOD system initialization changes?
    Hi TS3 Dev's -
    Our current project is heavily using the FMOD system objects provided by TS3. I see no notes in the changelog about an FMOD upgrade nor any changes.
    But in B21, the following has stopped working:
    1. Load a sound from a resource into memory
    2. Get the global FMOD system object via getCurrentPlaybackDevice()
    3. Load the sound via createSound() with the following: FMOD_OPENMEMORY_POINT | FMOD_CREATESAMPLE | FMOD_SOFTWARE
    Ex:
    exinfo.length = sound->length;
    ts3Functions.getCurrentPlaybackDevice(ts3Functions.getCurrentServerConnectionHandlerID(), (void **)&this->mSystem);
    err = this->mSystem->createSound(sound->data, FMOD_OPENMEMORY_POINT  | FMOD_CREATESAMPLE | FMOD_SOFTWARE,&exinfo,&sound->fmodHandle);
    	if(err) {
    		TRACE("FMOD error! (%x) %s", err, FMOD_ErrorString(err));
    The system object is initialized correctly, and the function does call correctly. However, the createSound now fails with
    FMOD_ERR_INVALID_PARAM
    whereas with B20, this code worked fine.
    I know this might be an FMOD question - but nothing in the recent changelog of FMOD suggests any changes in this either. So I'm not sure if perhaps it underlying changes?
    July 2002
    2,191
    to clarify, are you using the client plugin interface? Or the stand alone SDK?
    February 2010
    Seattle
    69
    Okay. I have the problem resolved now.
    Note to anyone else who runs into this:
    B21 used a development build of FMOD (while B20 used the stable release). This development build only lasted about 15 days, and then was lapsed.
    Currently, there is no way to tell what version of FMOD TS3 is using (DLL's don't change versions, etc). So the only way to find it is to use:
    FMOD::System->getVersion() and then dissect what this is.
    The version used was dev-beta build 4.31.02 of FMOD.
    You can download it here: http://www.fmod.org/index.php/download/find
    Dear TS3 Dev's,
    I request that the team please include FMOD version changes within the changelog.
    February 2010
    Seattle
    69
    Quote Originally Posted by Peter View Post
    Client plugin interface; apologies for not mentioning that. but as seen above, it was a more generic problem.
    November 2009
    Dublin, Ireland
    379
    you sure? in windows it says
    Fmodex.dll
    0.4.31.2
    FMOD Ex SoundSystem
    im on Beta22pre btw.
    February 2010
    Seattle
    69
    Quote Originally Posted by azzy101 View Post
    Fmodex.dll
    0.4.31.2
    FMOD Ex SoundSystem
    I am positive. There was a silent version change from b20 and b21/b22.
    TS3 Devs:
    I repeat my request. Please document fmod changes; or please official state you will *not*, and we, as plugin developers, must keep API's available to track your changes every release.
    June 2010
    Sweden
    I second to that motion.
    Please help Jaynus out!
    Posting changelogs with the updates is really important..
    2,360
    Quote Originally Posted by jaynus View Post
    TS3 Devs:
    At one position they said that there was a FMOD update :
    Linux users: Thanks to the folks at FMOD we now have native Pulse Audio support. Pulse Audio will be used automatically when available (and "Automatically Use Best" is chosen) or can be chosen explicitly from your playback and capture settings.
    July 2002
    2,191
    We will try to remember to add the fmod version to the changelog when we bump it in the future.
  1. Replies: 65
    Last Post: November 26th, 2017, 12:39 PM
  2. [Fmod unfixable] No wave sound played since beta 30
    By Styks in forum Bug Reports [EN/DE]
    Last Post: October 14th, 2010, 12:53 PM
  3. TS3 3.0.0 beta 29 system lockup after exit
    By maxiumguitar in forum Windows
    Last Post: September 13th, 2010, 08:19 AM
