Results 1 to 10 of 10
    June 2010
    sweden
    6
    win7 + ts problem
    this is mainly a teamspeak problem not just ts3.
    dunno how to properly setup the sound in win7.
    when other ppl speak on ts they here it thru me.
    and i even have every sound on max on the microphone and still ppl here my realy low. but when other ppl speak they here themself loud.
    in win xp u could mute the microphone on the inbound to solve this problem
    i use voice activation and im complete silence when other ppl speak still my mic starts to send, ( im not using speakers ) just a sennheiser headset so its impossible for the mic to get noices from the headphones.
    any tip on how to fix this?
    February 2006
    Texas, USA
    4,143
    You can also mute the mic on your personal computer in Win7. It's not quite as obvious but if you view the properties of your playback device (most likely SPEAKERS) and go to the LEVELS tab you can scroll down and mute or lower the output volume of the mic.
    This sounds to me like you have your sensitivity levels turned up to high in TS on your mic. Have you tried turning them down a bit?
    June 2010
    sweden
    6
    yeah i found that in option under sound settings and its muted, but still the problem occours.
    i have the voice activation set so i can almost speak normal without it activate.
    but its weird. the activation goes from -50 to 50
    atm i have it on like -28 if i put it on -26 i have to scream for it to activate. and if put it on -30 it sends non stop.
    November 2008
    United States
    1,718
    That's weird. Do you have another mic to test perhaps?
    Are your sound drivers up to date that you are aware of?
    February 2010
    brazil
    55
    what you need to do, is set the record device at windos
    soud
    you probably have the mixer as your default divice right now
    this is actualy quiet usual bug, alot of ppl have it, once it is a windows problem and not teamspeak itself
    June 2010
    sweden
    6
    http://img808.imageshack.us/img808/7780/testut.png
    http://img810.imageshack.us/img810/4323/test2e.png
    i hope these pics can help abit
    the headset i use is a sennheiser pc-161 if i recall
    and the motherboard with the integrated sound is a
    ASUS P6T DELUXE X58 S-1366 2XGBLAN FW ATX
    and i have the latest sounddriver for it
    June 2010
    sweden
    6
    did the thread die ?: )
    November 2008
    United States
    1,718
    I am stumped so i can be of no further use
    germany
    56
    your problem is the driver.
    in your mic settings you have no mic boost button.
    you need this button because this makes +20 db generell and then max record lvl.
    i had the same problem with old drivers. with new drivers the button for mic boost +20 db ist there and then it works very fine.
    go to your motherbord company and download the newest driver...and im sure the button will be there because bevore i by my new mainboard i had also a soundmax onboard crad with the mic boost.
    look what i mean:
    http://img811.imageshack.us/img811/126/unbenannt1p.jpg
    without these 20 db you will always be to low in pegel
    June 2010
    sweden
    6
    i understand what u mean. but i have the latest driver, i checked asus page.
    i have version 6.10.2.6585 from 2009-05-21
    tho i have the mic boost, but can just tick/untick it.
    *edit* update the driver, was the same that i already had and no new volume bar for mic boost
  1. Replies: 3
    Last Post: July 7th, 2013, 05:50 PM
  2. Win7, UAC and update.exe
    By shadow_lmd in forum Suggestions and Feedback
    Last Post: February 2nd, 2011, 10:27 AM
  3. TS3 Under win7 64 X-Fi
    By Rageman in forum Windows
    Last Post: October 2nd, 2010, 05:47 PM
