Results 1 to 8 of 8
    June 2010
    Belgium
    8
    Question insufficient client permissions
    Hello guys, I'm new here, I don't speak very good English, but I need your help
    so, I created a Teamspeak 3 Server on my VirtualServer, the vserver is from server4you.de, its a Linux 32 Bit server. I used the token at the begin, but now, if I want to do something on "ServerQuery" in my Teamspeak 3 Server, then it comes this bug...
    insufficient client permissions (gescheitert an b_client_issue_client_query_command (20639/0x509F))
    I don't know what I can do And I think, I don't have Serveradmin rights, I used the token already, but I don't have "Serveradmin" only "Normal" & "Channel Admin".
    I hope you understand me & my problem ;D
    Sorry for my bad english .
    February 2006
    Texas, USA
    4,143
    This isn't a bug. The error tells you what permission has caused the problem. Go to that permission in the server group and verify you have this and have enough power.
    If no one has admin server query you have to run a server query to add yourself.
    login serveradmin {password here}
    use sid=1
    servergroupaddclient sgid=2 cldbid={client ID here}
    June 2010
    Belgium
    8
    Hey, thx for the fast answer, but It doesn't work or I make which wrongly.. here I have a Picture :
    http://img97.imageshack.us/img97/9306/firstsw.jpg
    http://img686.imageshack.us/img686/9095/secondo.jpg
    Thx
    Secret Base in Arctic Region
    1,671
    Check if your servergroup has permission "b_client_issue_client_query_command" set.
    Else you cant use ServerQuery from the client, use putty or something instead as florian said.
    June 2010
    Belgium
    8
    Hey, and how can I do this in Putty? I don't have an idea, I have a Vserver and its dif for me
    so, it's the same problem if I don't write the "{}", this isn't the problem,
    Yes I used the first token, but I think, there was an error and now, it works perfect, but I'm not Serveradmin, what can I do? Does I need to install the server new?
    1,671
    Me wouldnt give this permission to guest.
    Only SA and SSA should have access to ServerQuery.
    May 2007
    Eastern NC
    1,793
    I would advice against using that SQL command above. Use putty or even telnet if using windows 2000, XP (maybe others) as your main system.
    To use telnet in windows open a command window and enter:
    telnet
    open {server_address} {query_port}
    {continue with query commands}
    logout
    quit
    If you get an error after the telnet command use putty.
    server_address = address you use in TS3 client to connect
    query_port = server's query port, default is 10011
    June 2010
    Belgium
    8
    Hey okay, in Putty I can connect, but what Commands I need to write there?
    use sid=1
    servergroupaddclient sgid=2 cldbid={2}error id=0 msg=ok
    error id=1540 msg=convert\serror
    use sid=1
    error id=0 msg=ok
    servergroupaddclient sgid=2 cldbid=2
    error id=2568 msg=insufficient\sclient\spermissions failed_permid=17292
    login serveradmin 30061993
    error id=520 msg=invalid\sloginname\sor\spassword
    ^[[A^[[A
    error id=256 msg=command\snot\sfound
  1. insufficient client permissions
    By CreepYx in forum Permission System
    Last Post: July 10th, 2014, 10:38 PM
  2. insufficient client permissions
    By cohen40 in forum Permission System
    Last Post: June 29th, 2012, 10:32 AM
  3. insufficient client permissions
    By Havon in forum Client Support
    Last Post: October 6th, 2010, 06:58 PM
  4. Insufficient Client Permissions
    By Stiicker in forum Windows
    Last Post: August 22nd, 2010, 11:30 AM
  5. insufficient client permissions
    By Nikuda in forum Permission System
    Last Post: June 3rd, 2010, 10:22 PM
