Results 1 to 4 of 4
    March 2010
    us
    18
    Privilege Key/Token Key Not Working!!
    Whenever i go to gameservers.com to reset my token key i get the following message when i paste the key into the privilege key section:
    failed to use privilege key: duplicate entry
    ive tried several different keys why is it doing this???
    18,151
    I don't know ho your Hoster sends you the tokens.
    When it looks like token=E8EjVG5/8tdjgvk36xFBwb/2Ol31yMrXY5OdfAdg,
    then you only have to enter E8EjVG5/8tdjgvk36xFBwb/2Ol31yMrXY5OdfAdg
    Maybe they add the token to the wrong server. You should contact them.
    February 2006
    Texas, USA
    4,143
    @Dante
    I had a clanmate have a similar problem. We just had our server recreated and I genereated a token using the key manager. When he used the key it gave him that error and then when he tried again it gave him the error that tells you the key doesn't exist. I was online so I just granted him SA. Not sure if this was just a fluke on our end or if this might be a more widespread problem. I will mess around with my server a bit and see if I can't reproduce this with my many identities I have...
    May 2010
    6,310
    This message appear when you used a token for a group you're already gone.
    Exemple :
    You are in the "Server Admin" group.
    You create a privilege Key for "Server Admin" group.
    When you used this privileges Key, this message appear
    Failed to use Privilege Key : duplicate entry.
    And the privilege key is deleted by the server.
    1 - You create a privilege key for your group and you want used this (I think not)
    2 - The database server have a little problem in permission table.
    I already report the inconsistency in the database. Contact your hoster and ask him to verify his database. Maybe the solution is a little bug in this one
  1. [Resolved] Token vs privilege key
    By Toine in forum Server Support
    Last Post: July 1st, 2014, 11:21 PM
  2. Privilege Key not working
    By Dragonlance in forum Permission System
    Last Post: May 2nd, 2014, 11:49 PM
  3. Lost Server Admin / Need new privilege key/Token
    By Cockatiel in forum Server Support
    Last Post: July 11th, 2011, 02:05 PM
  4. Token- Privilege.
    By Fatality1 in forum Windows
    Last Post: June 15th, 2010, 01:49 PM
