Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 121
  1. #61
    June 2010
    Alzenau / Germany
    97
    @Soljia: Making the source available to the public is not an option at the moment. I'm currently in contact with some companies that create cheat protection software to get them make my plugin white-listed - which they won't do if the source is available to the public...
    A full-fledged Teamspeak client? This sounds like quite a bit of work, but may be an idea for the future. (and I somehow like the recursive idea of having a TS3 client in a plugin of a TS3 client) ;-)
    @Thunder63cs: I just signed for a test account, I'll check what I can do (it might however already work with the latest version)
  2. #62
    July 2010
    USA
    I think part of it is the dx 11 with windows 7 but I have ti work and not work and soem times when it does work it is all jumble. but others it is perfict unless I open up a wiindow in game. over all works great.
  3. #63
    Hungary
    404
    Unfortunately your plugin crashes for me on enabling the plugin:
    2010-08-17 19:51:12.432617|INFO    |              |   | Logging started, clientlib version: 3.0.0-beta26 [Build: 12040]
    2010-08-17 19:51:13.213867|INFO    |ClientUI      |   | TeamSpeak 3 client version: 3.0.0-beta26 [Build: 12040]
    2010-08-17 19:51:13.213867|INFO    |ClientUI      |   | Qt version: 4.6.2
    2010-08-17 19:51:13.213867|INFO    |ClientUI      |   | Using configuration location: C:/Users/Slater/AppData/Roaming/TS3Client/ts3clientui_qt.conf
    2010-08-17 19:51:13.698242|INFO    |ClientUI      |   | Last update check was: K aug. 17 17:56:50 2010
    2010-08-17 19:51:16.950195|INFO    |PreProSpeex   |  1| Speex version: speex-1.2beta3
    2010-08-17 19:52:25.609375|INFO    |              |   | Registering plugin command id: {a256884e-7389-4b53-baf9-37e1b8bd9562} dx_overlay_plugin.dll
    The crash log (.dmp) is empty.
    Windows 7, latest client release.
  4. #64
    February 2010
    USA
    37
    Hi, Im using your Overlay and it works great with windows 7 64bit edition.
    I have a GTX260
    However. The color of the user that is speaking illuminates but its hard to tell just from looking at it.
    Is there a way to change the color instead of illumination?
    Thanks
    Edit: clanmates get whole system crash on enabling the plugin
  5. #65
    June 2010
    Alzenau / Germany
    97
    The font color can be configured since the latest version (2.0.21)
  6. #66
    2,354
    Quote Originally Posted by MarkR View Post
    Still 10 versions to wait :P .
  7. #67
    June 2010
    Alzenau / Germany
    97
    Oops, this should have been 2.0.11
  8. #68
    Arizona
    49
    needs to be updated to the new api
  9. #69
    June 2010
    Alzenau / Germany
    97
    Version 2.0.13 with OpenGL support is out.
    You can download it (as always) from http://ts3overlay.r-dev.de
  10. #70
    October 2010
    uk
    Thanks MarkR, Just tried with Il-2 Stormovik and works well. Is it possible to have a config set up GUI ?
  11. #71
    June 2010
    Alzenau / Germany
    97
    What do you mean with "config set up UI"?
    You can configure the basic settings (position, size, colour etc) in the configuration file (you can find it in the TS3 plugins folder).
  12. #72
    Germany, Cologne
    1,358
    Update to API 8?!
    http://img408.imageshack.us/img408/6010/image1vf.png
  13. #73
    June 2010
    Alzenau / Germany
    97
    The package includes a 32bit addon as well as a 64bit addon.
    The 32bit addon cannot get loaded on 64bit versions and vice versa. So ONE "red" addon is intentionally here ;-)
  14. #74
    Germany, Cologne
    1,358
    Why you don't compile an "only 64"?
    Maybe, because an 64er couldn't run on a 32 Game?
  15. #75
    October 2010
    Hi there,
    tried today your addon and i find it is great. I only have one problem, first time i started the plugin my CPU usage is alway on 50% and my PC is going very slow. I dont know why maybe you have an answer.
    If i load addon it takes about 10 sek for loading without responding and then CPU usage goes up to 50%.
    Win7 64
    Intel core duo
    Creative x-fi.
  1. [Outdated] TS3 GroupChat Plugin
    By SilentStorm in forum Client Plugins / Lua Scripts
    Last Post: October 15th, 2014, 01:04 AM
  2. [Release]Rhythmbox plugin
    By Dominik in forum Client Plugins / Lua Scripts
    Last Post: December 3rd, 2010, 09:06 PM
  3. ts3 overlay plugin (Failed to open plugin)
    By netmario in forum Windows
    Last Post: September 22nd, 2010, 08:29 AM
  4. [Release] TS3PHPBot-Plugin
    By Neytiri86 in forum Tools / Web Based
    Last Post: August 24th, 2010, 11:04 PM
