Results 1 to 4 of 4
    June 2010
    Allowing certain clients to not use PTT
    Hello everyone ...
    I would like to enforce push-to-talk on a particular channel and have set this up by setting b_force_push_to_talk to 1 in that channel.
    Now, certain clients should be exempt from this policy .... and here comes the problem:
    - Negate only works within the server groups. Thus, adding those clients to a group with negate enabled did not help.
    - As the Flag is sort of inverted, setting grant to 0 e.g. in the channel-client-permissions will not work, either.
    Is there any way to accomplish this WITHOUT enforcing ptt client-by-client?
    February 2006
    Texas, USA
    4,143
    Have you tried applying this permission in the client permissions w/ a negate flag? or just adding the permission but do not put 1 for the value? Since client permissions are higher in the tier I would think this would work but you'd have to do it for every client you want this for.
    Secret Base in Arctic Region
    1,671
    Note that "negate" flag does not reverse a permission.
    Negate means that the lower value will be considered.
    Sometimes you might want to create a Server Group that negatively affects the users that are put into it. For example a "Sticky" group that disallows switching of channels or a "Silent" group that removes the privileges to talk from the clients that receive it. To allow this the negate flag can be added to permissions in a server group. If you are member of a group that has a permission flagged with the negate flag, you will not receive the highest value of this permission, but rather the lowest that is flagged with negate.
    Example:
    You created a Server Group called "Sticky". It contains only one permission: i_channel_join_power set to "-1", and a negate flag is applied to this permission. Now if I grant sticky group to any client they will not be able to switch channels anymore. This also works if the user I put into "Sticky" group has a positive i_channel_join_power set, since the negate flag will make sure the Tier 1 result will be the lowest negated i_channel_join_power permission, so -1 or less than that. The reason why it is not possible to switch channels anymore is that normally a channel has no i_channel_needed_join_power set, and if a permission is not set it is assumed to be zero. Since -1 is smaller than zero, the user won't be able to join.
    Set "b_force_push_to_talk" for the users in the client-layer, uncheck it and set "Skip Flag".
    February 2006
    Texas, USA
    4,143
    I realized after I said that that there is no negate in the client permission area.
  1. Allowing Phantoms
    By Slicky456 in forum Suggestions and Feedback
    Last Post: June 16th, 2010, 12:45 AM
