Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    July 2010
    United Kingdom
    14
    I tried IPv4 as the address and it still says failed to connect to server.
  2. #17
    February 2006
    Texas, USA
    4,143
    If the server is on the same machine you are running your client from you can use either localhost or 127.0.0.1 as your IP. When you do an IPCONFIG in the CMD window you get your IPv4 address which is your local machine address on the LAN.
    If you think it will help try deleting the server and starting from scratch.
  3. #18
    July 2010
    United Kingdom
    14
    -facepalm- yeah, I was closing the black box, I didn't know I needed to keep it open for it to work thanks a lot for all your help guys
    Everything works now !!
    One more question, the IP i give to others to connect to my server is the one I find on www.whatismyip.com ?
  4. #19
    February 2006
    Texas, USA
    4,143
    Yes, what you get from whatismyip.com is your EXTERNAL IP address. No one will be able to connect if you give them the LAN IP unless they are on your LAN with you.
  5. #20
    July 2010
    United Kingdom
    14
    Thank you so much ! Problem fixed
  6. #21
    July 2010
    United Kingdom
    14
    I have another problem now, I can connect to my server but nobody else can, what's going on? D:
    I gave them the correct IP and port, they added teamspeak to their exceptions list on the firewall but it still won't let them connect. Help!
  7. #22
    February 2006
    Texas, USA
    4,143
    Did you forward the correct ports to the right IP on your network?
  8. #23
    July 2010
    United Kingdom
    14
    Yes I did. I spoke to a friend who set up his own server and they said that most routers won't allow these sort of ports to be forwarded or something along those lines, and that I should think about renting a server.
    I'm hosting the server on my home computer, is this the problem? :s
  9. #24
    February 2006
    Texas, USA
    4,143
    Hosting your own server isn't a problem as long as you've got the bandwidth. Not quite sure what your friend meant by his comment about ports being forwarded. Most (if not all) routers have a firewall in them and through their web access you can forward ports. Take a look at http://portforward.com/. Find your router make/model then click SKIP at the advertisement on the next screen. Now select Teamspeak and the site will tell you exactly how to forward ports for your router.
    One thing you need to verify is that your server computer ALWAYS gets the same IP when it connects to your network. Easiest way to do this is to setup a static IP or an IP reservation for that computer's MAC address. If the computer is assigned a different IP then your forwarded ports will not work properly.
  10. #25
    July 2010
    United Kingdom
    14
    How do I set a static IP?
  11. #26
    February 2006
    Texas, USA
    4,143
    You'll have to look in your router's manual for that one. It's different for every router. You can try google as I am sure it'll find what you need
  12. #27
    July 2010
    California
    Hi, I too downloaded the server and followed the instructions given on youtube, and on the first time, logged in using 'localhost' with no problem, but now, it is giving me a message saying:
    <12:34:16> Trying to resolve hostname localhost
    <12:34:16> Trying to connect to server on localhost:9987
    <12:34:22> Failed to connect to server
  13. #28
    February 2006
    Texas, USA
    4,143
    Did you close that black box that opened when you clicked on the server exe file? That is your server and if you close it the server stops running. With the next update that box goes away and the server becomes a tray icon like TS2 was.
  1. Failure to connect
    By that11d0i7 in forum Windows
    Last Post: June 2nd, 2015, 07:01 PM
  2. Failure to connect
    By Baaddare in forum Windows
    Last Post: December 28th, 2011, 07:57 AM
  3. failure to connect
    By carriey in forum Server Support
    Last Post: July 5th, 2010, 02:30 PM
