Results 1 to 12 of 12
    July 2010
    Canada
    6
    connection lost.. and lost.. and lost..
    Hi guys, i don't know why but i'm always crashing on TS3, i have the last version of the TS3 and the server is updated.
    I can be 1hour without problems, and sometimes i even can't be 2minutes in peace.
    I can crash "None-stop" with the "Connection Lost" .. it's not my internet because my games are not crashing, msn, Radio... it's only TS :/
    Thanks if you have an idea why!
    **I'm the only one on this TS with that problem**
    *I'm french btw so sorry for my bad english**
    February 2006
    Texas, USA
    4,143
    Do you have an anti-virus or firewall program that might be causing this? What's your packet loss look like? Does it happen more frequently if there are more people on the server? Does it happen if you connect to the TS public server?
    July 2010
    Canada
    6
    Thanks for trying to help me ! =)
    My windows Firewall is not activated so that's probably not the problem.
    My Anti-Virus is NOD32, It never blocked my games/program so i don't think that may be the issue :/
    The numbers of people on TS doesn't matter, i can be alone and get the Connection lost 100 times, and we can be 4-5 and i won't crash for like 1-2 hours and get a Connection lost for any reason and there it will begin to crash none-stop :/
    I tryed to connect on a Public server, and it still crash :/
    When i will have this "Connection Lost" none-stop i will copy the Client Log here maybe it will help to see what happen
    *i have no idea if i make my own server if it will happen, i'm always on the server of my friend*
    May 2010
    6,310
    Have you an crash dump file (.dmp extension) ?
    July 2010
    Canada
    6
    Nope i don't see anything .dmp
    I just have 3-4 some connection lost but nothing abbusive like yesturday!
    TS3 Folder: http://img267.imageshack.us/img267/1386/ts1m.jpg
    TS3 Connection lost: http://img130.imageshack.us/img130/6241/ts2t.jpg
    Client Log: http://img823.imageshack.us/img823/338/ts3i.jpg
    i still have some connection lost till i took these pictures XD and now we are 2 on TS.
    *I have Windows Vista Ultimate 32x*
    February 2006
    Texas, USA
    4,143
    Try turning off NOD32 for a bit and see if you still crash. If there is an option, add TS3 to the exception list in NOD32.
    When you loose connection is it only TS3 or is it all of your internet?
    July 2010
    Canada
    6
    It's only the TS3, my games/msn/radio aren't crashing :/
    Nope it's not the NOD32, And if it was it will "pop-up" to tell me he block something =P
    *Edit*
    Now it begin to crash almost none-stop Lol..
    http://img189.imageshack.us/img189/4115/ts1i.jpg
    July 2010
    Canada
    6
    No one have an idea why? It keep crashing ;_;
    November 2008
    New Mexico, USA
    12
    Our TS is doing the same thing to a member of ours. It will boot him saying that same message and then he is unable to get in at all unless he uses a VPN to connect. He says he is not using any AV or Firewall and we have even put his IP in our Dedicated servers Whitelist and on our Firewalls whitelist. As far as we can tell there is no reason for it. We have a 512 member lic. and never atp surpass 20 people. The server is powerful enough to hold 512 5 times over so we know it isn't the server causing it.
    So does anyone have any ideas on this???
    January 2011
    same problem here, disconnecting MANY of times, without having any clue why.
    It seems also that it is only on 1 specific server - and i am the only user from that server getting that error.
    It is really annoying!
    Any clue?
    Firewall there's an exception addet. Newest TS3 Client. 32 bit and 64 bit having the same problems with that server.
    2011-01-25 18:22:00.812206|INFO    |              |   | Logging started, clientlib version: 3.0.0-beta36 [Build: 12815]
    2011-01-25 18:22:00.827207|INFO    |Query         |   | listening on 127.0.0.1:25639
    2011-01-25 18:22:01.095222|INFO    |ClientUI      |   | TeamSpeak 3 client version: 3.0.0-beta36 [Build: 12815]
    2011-01-25 18:22:01.095222|INFO    |ClientUI      |   | Qt version: 4.6.2
    2011-01-25 18:22:01.095222|INFO    |ClientUI      |   | Using configuration location: C:/Program Files (x86)/TeamSpeak 3 Client/config/ts3clientui_qt.conf
    2011-01-25 18:22:01.586251|INFO    |ClientUI      |   | Last update check was: Di 25. Jan 17:57:55 2011
    2011-01-25 18:22:03.382353|INFO    |PreProSpeex   |  1| Speex version: speex-1.2beta3
    2011-01-25 18:35:40.071065|INFO    |Bookmarks     |   | Disconnect, total time: 816 - 1701674
    2011-01-25 18:35:41.075123|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 18:36:35.663245|INFO    |Bookmarks     |   | Disconnect, total time: 538 - 126124
    2011-01-25 18:55:06.143761|INFO    |Bookmarks     |   | Disconnect, total time: 1164 - 1702838
    2011-01-25 18:55:07.151818|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 18:56:13.151593|INFO    |Bookmarks     |   | Disconnect, total time: 64 - 1702902
    2011-01-25 18:56:14.154651|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 18:57:05.152568|INFO    |Bookmarks     |   | Disconnect, total time: 50 - 1702952
    2011-01-25 18:57:06.164626|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 18:57:56.157485|INFO    |Bookmarks     |   | Disconnect, total time: 49 - 1703001
    2011-01-25 18:57:57.161542|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 18:58:44.160231|INFO    |Bookmarks     |   | Disconnect, total time: 46 - 1703047
    2011-01-25 18:58:45.162288|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 18:59:33.164033|INFO    |Bookmarks     |   | Disconnect, total time: 47 - 1703094
    2011-01-25 18:59:34.178091|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:00:18.767642|INFO    |Bookmarks     |   | Disconnect, total time: 44 - 1703138
    2011-01-25 19:00:19.778700|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:01:10.171582|INFO    |Bookmarks     |   | Disconnect, total time: 50 - 1703188
    2011-01-25 19:01:11.179640|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:01:59.179385|INFO    |Bookmarks     |   | Disconnect, total time: 47 - 1703235
    2011-01-25 19:02:00.180442|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:02:47.175130|INFO    |Bookmarks     |   | Disconnect, total time: 46 - 1703281
    2011-01-25 19:02:48.181188|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:03:41.187220|INFO    |Bookmarks     |   | Disconnect, total time: 52 - 1703333
    2011-01-25 19:03:42.189277|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:04:35.188308|INFO    |Bookmarks     |   | Disconnect, total time: 52 - 1703385
    2011-01-25 19:04:36.196366|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:27:45.276817|INFO    |Bookmarks     |   | Disconnect, total time: 1388 - 1704773
    2011-01-25 19:27:46.290875|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:28:34.277619|INFO    |Bookmarks     |   | Disconnect, total time: 47 - 1704820
    2011-01-25 19:28:35.289677|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:29:22.581382|INFO    |Bookmarks     |   | Disconnect, total time: 47 - 1704867
    2011-01-25 19:29:23.587440|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:30:15.290397|INFO    |Bookmarks     |   | Disconnect, total time: 51 - 1704918
    2011-01-25 19:30:16.302455|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:31:04.296200|INFO    |Bookmarks     |   | Disconnect, total time: 47 - 1704965
    2011-01-25 19:31:05.302258|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:31:52.296945|INFO    |Bookmarks     |   | Disconnect, total time: 46 - 1705011
    2011-01-25 19:31:53.303003|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:32:44.304920|INFO    |Bookmarks     |   | Disconnect, total time: 50 - 1705061
    2011-01-25 19:32:45.312978|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:50:51.371097|INFO    |Bookmarks     |   | Disconnect, total time: 1085 - 1706146
    2011-01-25 19:50:52.376154|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:51:43.372071|INFO    |Bookmarks     |   | Disconnect, total time: 50 - 1706196
    2011-01-25 19:51:44.385129|INFO    |ClientUI      |  1| Autoreconnecting...
    January 2011
    2011-01-25 19:52:34.380989|INFO    |Bookmarks     |   | Disconnect, total time: 49 - 1706245
    2011-01-25 19:52:35.383046|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:53:23.383791|INFO    |Bookmarks     |   | Disconnect, total time: 47 - 1706292
    2011-01-25 19:53:24.396849|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:54:14.387709|INFO    |Bookmarks     |   | Disconnect, total time: 49 - 1706341
    2011-01-25 19:54:15.393766|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 19:55:05.394626|INFO    |Bookmarks     |   | Disconnect, total time: 49 - 1706390
    2011-01-25 19:55:06.407684|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 20:08:02.535076|INFO    |Bookmarks     |   | Disconnect, total time: 10 - 126134
    2011-01-25 20:56:35.636696|INFO    |Bookmarks     |   | Disconnect, total time: 3689 - 1710079
    2011-01-25 20:56:36.641753|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 22:59:45.100349|INFO    |Bookmarks     |   | Disconnect, total time: 7388 - 1717467
    2011-01-25 22:59:46.112407|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-25 23:00:36.103266|INFO    |Bookmarks     |   | Disconnect, total time: 49 - 1717516
    2011-01-25 23:00:37.108324|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-26 05:06:00.579275|INFO    |Bookmarks     |   | Disconnect, total time: 21924 - 1739440
    2011-01-26 05:06:01.584332|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-26 09:38:19.526809|INFO    |Bookmarks     |   | Disconnect, total time: 16337 - 1755777
    2011-01-26 09:38:20.534867|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-26 09:39:12.527840|INFO    |Bookmarks     |   | Disconnect, total time: 51 - 1755828
    2011-01-26 09:39:13.527898|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-26 09:40:02.531700|INFO    |Bookmarks     |   | Disconnect, total time: 48 - 1755876
    2011-01-26 09:40:03.543758|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-26 09:40:54.535675|INFO    |Bookmarks     |   | Disconnect, total time: 50 - 1755926
    2011-01-26 09:40:55.538732|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-26 09:41:45.539592|INFO    |Bookmarks     |   | Disconnect, total time: 49 - 1755975
    2011-01-26 09:41:46.549650|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-26 09:42:36.543509|INFO    |Bookmarks     |   | Disconnect, total time: 49 - 1756024
    2011-01-26 09:42:37.547567|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-26 09:43:25.631317|INFO    |Bookmarks     |   | Disconnect, total time: 47 - 1756071
    2011-01-26 09:43:26.640375|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-26 11:20:35.969793|INFO    |Bookmarks     |   | Disconnect, total time: 5829 - 1761900
    2011-01-26 11:20:36.974851|INFO    |ClientUI      |  1| Autoreconnecting...
    2011-01-26 11:21:24.270556|INFO    |Bookmarks     |   | Disconnect, total time: 47 - 1761947
    2011-01-26 11:21:25.273613|INFO    |ClientUI      |  1| Autoreconnecting...
    help?
    ZIP file of a crash report:
    ts3_clientui-win32-12815-2011-01-26 09_42_37.605570.zip
    September 2011
    Hi folkz,
    two friend have the same problem on my TS while serveral other havn´t. Doesn´t matter how many others are logged into channel or server. Server is outside in a grid. all other services installed there are running pretty well.
    There is a common thing for these both friends.
    They are using USB-Stick with Sim-cards (like sold by O2 or from ciscount stores).
    Problems are heavier on weekends.
    So I think there is a problem with their internet connection.
    We have a TS2-server installed on the TS3-machine and there are some probs when they start to talk, but there is no connection lost.
    At the end we havn´t found a solution, but I wanna give this hint for checking internet connections.
    And I can say that TS3 seems to be more histeric than TS2.
    I´m looking forward to find a solution for that. Maybe an adjustment that surpresses these connection losts.
  1. Connection lost after 30 sec.
    By froidy in forum Windows
    Last Post: November 24th, 2014, 11:12 AM
  2. connection lost
    By OutLawer in forum Windows
    Last Post: March 19th, 2013, 02:50 PM
  3. connection lost
    By cornelius in forum Linux / FreeBSD
    Last Post: May 15th, 2011, 09:38 PM
  4. connection lost.. and lost.. and lost..
    By rottenz in forum Bug Reports [EN/DE]
    Last Post: July 9th, 2010, 07:46 AM
