Page 12 of 70 FirstFirst ... 210111213142262 ... LastLast
Results 166 to 180 of 1036
  1. #166
    October 2011
    16
    Although the ports are open on your server, you still likely need to forward the ports from your router. Also, make sure your outside users are using your outside IP address. Internal IPs will not work for them (ie: 192.168.x.x, 10.x.x.x, 172.16.x.x, etc will not work for outside users)
  2. #167
    October 2011
    The ports are forwarded from the router but I more than likely i gave out the internal ip addy. I'll see if that was the problem.
    --- Merged ---
    that fixed it...lol thanks for pointing out my stupidity!!
  3. #168
    October 2011
    16
    Glad it worked! Sometimes it's easy to forget which IP to use depending on where you are.
  4. #169
    October 2011
    Question
    Hi, i want to creat TS3 virtual server on my own server and i'm tryin to do it on my pc first.. I downloaded ts3 server for win x64 and i started server, how i saw it in video manual on ts3 website. Everythin was fine, i tryed to connect by usin localhost and it works, i tryed to connect from my notebook by usin LAN IP and it works, but if someone else try connect by WAP IP it don't work.. i can't connect there by usin ip too.. please can u help me why is this happenin'?
    --- Merged ---
    Hello guys, please ive problem with connetcion of other ppls on my ts3 server.. i just created it, i can connect there by usin local host, i can connect with my notebook in lan by usin lan ip but i cant connect by usin ip (89.176.165.106) and anyone else can't connect too.. Maybe is there a problem with ports, cus i didn't get how to activate it by reading this thread.. please someone help
  5. #170
    May 2010
    6,310
    Quote Originally Posted by Treen
    The often time, just open your web browser and go to the http://192.168.1.1 or http://192.168.1.254 go to NAT or Forward section.
    But that depends of your router and his documentation.
  6. #171
    October 2011
    Quote Originally Posted by florian_fr40 View Post
    on second one i can't connect and the first one need user name and password.. what is this pls?
  7. #172
    May 2010
    6,310
    We don't know the password of your router. You have to read the documentation from this one.
  8. #173
    October 2011
    and when i create that virtual ts3 server on my own server will that work without thi passwords? Or are there in a server room too some routers whitch i need to know?
  9. #174
    October 2011
    Exclamation Tf3 connecting problems :(
    Hi
    I can't connect to my server exept using logmein hamch(hamachi create a own ip)
    Can someone help me so I can config my server so I can use it online
    I have a Thomason gatway with ip 81.237.240.56 and my hamchi is 5.171.39.207 but the problem with hamachi is that they need to have it too
    need help verry mutch so don't be afrid to tell what you think !
    PLZ HELP ME !
  10. #175
    May 2010
    6,310
    First questions before further,
    - where is the server ?
    - If the server is on your home network (or in a firend home network), do you open/forward the port ?
  11. #176
    October 2011
    In my house in sweden (my computer in my room)
    and I don't know how to open my port or forword the port i don't know what that stuff is
  12. #177
    May 2010
    6,310
    @Treen
    You have to open each port that the Teamspeak system use. So if you create a new virtual server, you have to open the new voice port.
    @robbanifk
    I merged your thread. So look at the top of this thread.
  13. #178
    October 2011
    ye i get i need to somehow open that ports, but i rly dont get how to do that.. someone posted here some links, but i dont know what to do with them.. one link didn't worked and second one needs some username and password..
  14. #179
    November 2011
    Port forwarding / TS3 behind a router
    which ports have to be forwarded if my TS3 Server is behind a router
    I appreciate your responses
    jokron
    Edit by mod
    Thread Merged. Next time please use the search function or read the FAQ
  15. #180
    November 2011
    Cant connect to my server
    Okay so i connected to my server using the localhost option but nobody else can connect to it. I dont know what it means by forwarding a port so i just went through my firewall and listed the 2 ports incoming and outgoing to be able to use as per what the vidio tutorial said.
    My op is Windows 64 bit
    Server is windows 64 bit
    I gave them the server id address which worked for me to connect, but nobody else can.
    I'm running wireless internet.
    Please help
  1. SRV port forwarding
    Last Post: October 7th, 2016, 10:10 AM
  2. Replies: 1
    Last Post: May 2nd, 2012, 08:12 AM
  3. Replies: 3
