Page 15 of 70 FirstFirst ... 513141516172565 ... LastLast
Results 211 to 225 of 1050
  1. #211
    July 2011
    6
    i just recently changed modems i am now using a TP-Link TD-W8960N i have forwarded the same ports and am unable to connect now any ideas i am also using http://www.no-ip.com/ (i have from the start as it is easier
  2. #212
    December 2011
    Problem with external connection
    I'm having problems with connecting to my external address.
    I'm having win7 x64 and latest stable server. Ports are forwarded correctly, according to with portforwarding.com tool. Currently my computer is in DMZ, windows firewall is set to allow any communication with ts3server_win64.exe
    I've checked connection to 127.0.0.1 and 192.168.1.2 (my local address), with a success, but I'm unable to connect to my external address.
    Any ideas what am I missing?
    *** Thread Merged ***
  3. #213
    May 2010
    6,310
    Don't forget that almost every router you can't use your EXTERNAL IP from your INTERNAL network to return on this one.
    Ask to a friend
  4. #214
    December 2011
    OK, thanks. It worked
  5. #215
    December 2011
    Problems with connecting in my home-network.
    So I am from Germany and I am sorry for my bad English. ;D
    I have set up a server on my mac. Everythin runs well but there are some tricky problems.
    1. From my Mac I cant join the server with the dyndns (no-ip.com) adress. Only with the Adress:127.0.0.1.
    I downloaded the TS3 app to my iPhone 4 and there I can join with the dyndns adress, but only when I am not connected with my wlan router. So over 3G everything is good on my iPhone.That I can only connect to the server with 3G on my iPhone isnt a big thing for me. But I thought it would be important for my problems.
    2.The server runs on my mac, but I want to play and talk on my PC. But I cant join from any other PC which is connected with the same router as my mac.
    I also forewarded the Ports. (UDP:9987 TCP:10011 TCP 30033)
    I also have a minecraft server on the same dyndns host. I hope this isnt the Problem.
    It is on a other port and I cant add a new dyndns host on my router.
    Please help me
  6. #216
    February 2006
    Texas, USA
    4,143
    @prodevil_bf
    You won't be able to connect to your server using your dns address, only your internal LAN IP address. Use the LAN IP for any computer on your network. Those connecting from outside your network need to use your WAN IP or dns address. If you are connecting on the same machine the server is on you are going to need to use 127.0.0.1 or localhost for your IP address. The PC needs to use the LAN IP address of your Mac to connect to the server.
  7. #217
    December 2011
    Question
    I can connected to the TS3 in my LAN, but not from the WAN.
    *I have opened all required ports
    *OS: xp
    LOG:
    2011-12-30 11:40:17.828125|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.1 (2011-11-17 07:34:30)
    2011-12-30 11:40:17.843750|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2011-12-30 11:40:17.843750|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2011-12-30 11:40:17.843750|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2011-12-30 11:40:18.015625|INFO    |SQL           |   | db_CreateTables() tables created
    2011-12-30 11:40:19.890625|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2011-12-30 11:40:19.984375|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2011-12-30 11:40:20.015625|INFO    |VirtualSvrMgr |   | executing monthly interval
    2011-12-30 11:40:20.031250|INFO    |VirtualSvrMgr |   | reset virtualserver traffic statistics
    2011-12-30 11:40:21.546875|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2011-12-30 11:40:21.546875|INFO    |Query         |   | listening on 0.0.0.0:10011
    I use hamachi too on ts servern (BTW)
    so what is wrong here?
    --- Merged ---
    I now what is wrog My port is in TCP and not UDP
    Now its work^^
    --- Thread Merged ---
  8. #218
    January 2011
    GB
    14
    Connection Problems
    I have set up a TS3 server on a computer on my network I am able to connect to it using the internal ip but cant seem to use the external. I have set up the ports but dont know why else it wont work. I am using windows professional.
  9. #219
    Catalunya
    2,350
    Some routers don't allow connections by Wan_IP.
    Ask a friend to try to connect from outside your LAN
  10. #220
    December 2011
    NPL license Won't let others connect..
    Well I got a NPL server for my friends and I to play iRacing; but it won't let my other friends connect I read the other topics about it but I amd still confused and help would be great. On this computer I connect to the server as 127.0.0.1 I've also tried with my friends on other computers using that IP address and my external IP address with the port :9987 at the end.
  11. #221
    January 2012
    help !!
    Good, a month ago TS3 mount a licensed server and it worked, I recently had marred the computer and formatting, I remounted the server again and now people can not connect to the server, I need help.
    Google translator excuse my English: D
    *** Thread Merged
  12. #222
    January 2012
    Exclamation team speak 3 sever
    i installed the ts 3 server on my pc fellowed the everything down to the letter an now one can connect to it i already fowared my ports an my router firewall is on my pc firewall is can some help plz becouise cant figer out why
  13. #223
    January 2012
    Lightbulb
    Excusme admin, mod , and all members . im so sorry if i post this thread in wrong place.
    i need your help
    i create teamspeak server and i do all step in the tutorial video ts server
    but when i was done setting the configuration . i order to my friend to connect my server
    i give my ip public . but failed conect to server .
    in case. if i put server addres with : localhost , it work .
    its my connection info.
    http://farm8.staticflickr.com/7155/6...8f2bbd07f5.jpg
    what should i do ?
    --- Merged ---
    hello guys
    how to forward ports to IP address ?
    Default voice port (UDP): 9987
    Default filetransfer port (TCP): 30033
    Default serverquery port (TCP): 10011
    because i dont know the step portforward.com
    please help me
  14. #224
    Catalunya
    2,350
    Go to http://portforward.com/ and find your router and model.
    On the 2nd page select SKIP THIS ADVERTISEMENT in the top right then select Teamspeak on page 3.
  15. #225
    January 2012
    how . if i dont know my router model ? any suggest ?
  1. SRV port forwarding
    Last Post: October 7th, 2016, 11:10 AM
  2. Replies: 1
    Last Post: May 2nd, 2012, 09:12 AM
  3. Replies: 3
    Last Post: May 24th, 2011, 09:20 AM
