Page 20 of 70 FirstFirst ... 10181920212230 ... LastLast
Results 286 to 300 of 1043
  1. #286
    March 2012
    server connection
    I'm running windows 7 64-bit, and teamspeak 3-64 bit, but I seem to be the only one able to connect to my server. I have forwarded all the ports through the modem, checked the firewall for problems,,,,and my friend still can't get into my server.
    I must be missing something but I don't know what.
    Can anyone help?
  2. #287
    May 2010
    6,310
    Do you provide the correct IP (your external IP) ?
    It's really a modem or a router ?
    Some model request a range port (9986 - 9988 instead 9987 - 9987)
    Do you check the server log ?
  3. #288
    March 2012
    Well checked server log and there is nothing in it {empty} I did go through Portforward setup for a Static Ip that I need for the Pk5000 DSL modem and router, or so it's said, and then got the pfportchecker program to see if they were all working and they were, nothing there now. The only think I did't do was to use the IP in the right spot,,,no sure where it should be added.
    --- Merged ---
    I was also wondering if there is a way to check if the server is working without calling a friend have see if they can get in or not?
  4. #289
    May 2010
    6,310
    I merged your thread.
    Check all points listed in the first post of this one.
  5. #290
    March 2012
    Yes, I think I'm using the right IP the modem is 192.168.0.1 and so forth for the modem, the IP for ts3 says it needs or is using is (97.121.61.175) and this is the IP that whatismyip.com sends back to me as my net IP,,,I know there are other sub-net IP's.
    I also so made a static IP (192.168.0.150) that one of the online help sites said I had to have for tp3, but it didn't seem to make and differnce so at a loss here. I may just have to go back to ts2, I had that one working. I don't know, I'm at a loss here, I'm good at building up computers, but when it comes do sofeware, well I'll just say that most of the time I can make the sofeward do what I want, but that's about it.
  6. #291
    February 2006
    Texas, USA
    4,143
    @MayLawnA Fawn
    You need to ensure that your port forwarding is pointing to the LAN IP of the machine that hosts your server. If that is the 0.150 address ensure that you either set it as a static route, enable an IP reservation for that machine or do both. That will ensure that even if the machine gets rebooted it always has the same IP address for port forwarding. Check any software firewalls/anti-virus you have to make sure it isn't blocking a connection. The IP address you get from whatismyip.com is the address you need to give to anyone outside of your network.
    ***EDIT***
    I was able to connect to your server w/ out an issue.
  7. #292
    December 2011
    Windows PC Failed To connect to sever
    I am having trouble setting up my teamspeak server on my pc. I have portforward the ports. Tried my best in the firewall but nothing is happening can anyone else help?
    http://img594.imageshack.us/img594/6964/prts.png
    *** Thread Merged ***
  8. #293
    March 2012
    help please nobody can connect to me
    Hi I need help with my teamspeak no body can connect to it yes all my ports is forward and ip is right my ip is (192.168.0.150)or(41.133.53.32) I can connect to it if I press 192.168.0.150 but other people cant find it if they press search they find me but they can connect console says:Failed to connect to server plz help me my servers name is headshotgroup thank you very much
  9. #294
    18,396
    http://forum.teamspeak.com/showthrea...not-connect%29
    This has been answered many times. Please read post #1 of this thread
  10. #295
    May 2006
    Europe/Czech Rep.
    1,616
    Quote Originally Posted by christo View Post
    41.133.53.32
    thank you very much
    I was able to connect to the IP you have provided. But I am not sure that your filetransfer port is opened.
    Saw some charlden user.
  11. #296
    December 2011
    10
    homemade teamspeak
    i made my own ts , but the prob is only i can log into it...
    what i need to do so other ppl can log in???
    Please loo at the top of this thread.
  12. #297
    March 2012
    Done all the Port Forwarding instructions.. friends still cant connect
    I've followed all the instructions on the port forwarding thread, but friends still can't connect, unless I've done something wrong.
    This may be a silly question, but do I look for my Router IP address on my broadband or wireless router? I'm no computer genius :P
    I used the broadband box anyways, and when it came to the' Port Forwarding Teamspeak on Linksys RT31P2', the box where you enter the ip address you setup says 192.168.1.__, and youre left to fill in the blank, but my IP address was 192.168.15.50, so is that where im going wrong? and if so im not being given another option ...
    Any help is appreciated! Thanks.
  13. #298
    February 2006
    Texas, USA
    4,143
    For most users their LAN IP will start 192.168.1.X In your case it is 192.168.15.50. This can only be used for computers on your network. Visit whatismyip.com to get your WAN IP address. This is what you give to friends outside of your network. If you want to follow the instructions on that page just put the number 50 in the blank and remember that the address is 15.50 not 1.50 so anywhere you see 192.168.1.50 you would use 192.168.15.50.
  14. #299
    April 2012
    8
    Issue home server
    I want to run a server from my own computer for a cod2 clan,
    But when i load it up after doing this in target: C:\Users\eigenaar\Desktop\ts3\ts3server.exe '' voice_ip=86.90.135.27
    it gives me this error:
    2012-04-07 14:31:42.144713|ERROR |VirtualServer | 1| bind failed on 86.90.135.27:9987
    2012-04-07 14:31:42.153714|INFO |VirtualServer | 1| stopped
    and noone can join, even me
    Anyone knows how to fix this,
    Thanks in advance.
  15. #300
    Catalunya
    2,350
    Why you used this parameter?: voice_ip=86.90.135.27
There are currently 20 users browsing this thread. (0 members and 20 guests)
  1. SRV port forwarding
    Last Post: October 7th, 2016, 11:10 AM
  2. Replies: 1
    Last Post: May 2nd, 2012, 09:12 AM
  3. Replies: 3
    Last Post: May 24th, 2011, 09:20 AM
