Page 46 of 70 FirstFirst ... 36444546474856 ... LastLast
Results 676 to 690 of 1050
  1. #676
    July 2014
    22
    I am not doing it wrong, and i'm not using a third party program to do it. Yes I am on Wi-Fi.
  2. #677
    December 2013
    Brazil
    23
    That is bad, can you connect on it by cable? do you have the server already running for me try to connect from here
  3. #678
    UK
    769
    Had to Google what Optimum was (since you didn't tell us), but what makes you think the ports aren't opening, i.e. what tests are you doing to check this and are there any firewalls between your connection & the Teamspeak server.
    Also, since Optimum seems to be remote management of modems (if I've got it right) are you sure your settings are being relayed to your modem?
  4. #679
    July 2014
    22
    I'm using multiple open port checkers and since I've port forwarded before, there shouldn't be any issue with the settings being relayed..
  5. #680
    UK
    769
    I guess you know that no port checker will be able to check that the voice (UDP) port is open?
  6. #681
    July 2014
    22
    Regardless none of the ports for TS are opening.
  7. #682
    September 2013
    Croatia
    93
  8. #683
    July 2014
    22
    Lol, I've been there before, but as you can see Optimum is not there..
  9. #684
    UK
    769
    Can you not log in directly to your modem & see if the port forwarding has been set up? The only conclusions I can come to are -
    • Port forwarding is not set up
    • Port forwarding is forwarding to the wrong IP
    • A firewall somewhere is blocking the ports
    • Your Teamspeak server isn't running
  10. #685
    February 2014
    6
    server start, but can't connect
    Hi friends.
    I configured teamspeak on CentOS 6.5 in a specified user (no root). It start good without error.
    But no one can't connect.
    server has ping with 4.2.2.4
    I looked at last topics about it, but I can't solve it.
    plz help
    Last edited by dante696; July 15th, 2014 at 08:12 AM. Reason: merged. please open your ports for the server
  11. #686
    June 2014
    Please help, Cant get my friends to join my teamspeak
    HI, just set up a TS3 sever but I cannot get my friend to connect.
    Im not too sure what I am doing tbh I just watched a tutorial how to do it.
    I think my server name is localhost (im not sure) please could someone help me out?
    cheers
  12. #687
    July 2014
    22
    Need Help Quick
    So I've been hosting my own teamspeak 3 server for a bit now, and it was working perfectly last night, but this morning it stopped working. No one can connect they all get failed to connect errors. But, after taking closer look at my first log of the day this was what I see.
    2014-07-28 17:52:48.999398|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.10.3 (2014-01-01 16:28:39)
    2014-07-28 17:52:49.057036|INFO |ServerLibPriv | | SystemInformation: Windows 8 (9200) x64 (AMD or Intel) Binary: 64bit
    2014-07-28 17:52:49.059042|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2014-07-28 17:52:49.059042|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2014-07-28 17:52:49.061038|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2014-07-28 17:52:49.142092|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2014-07-28 17:52:54.251245|INFO | | | Puzzle precompute time: 3887
    2014-07-28 17:52:54.588599|INFO |FileManager | | listening on 0.0.0.0:30033
    2014-07-28 17:52:58.674202|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2014-07-28 17:52:58.676204|INFO |Query | | listening on 0.0.0.0:10011
    I'm not too sure what to do, this is the only thing I've found that looks like it could be causing this issue..really need my server back up soon though.
  13. #688
    UK
    769
    I don't see any problems there if you don't have any form of license, what does the other log show?
  14. #689
    18,513
    Maybe your WAN IP (and/or LAN IP) did change. You gave no details about network settings etc.
    Please check your ip and port forwardings.
  15. #690
    4,368
    You most likely got a new DHCP lease and your LAN IP changed.
  1. SRV port forwarding
    Last Post: October 7th, 2016, 10:10 AM
  2. Replies: 1
    Last Post: May 2nd, 2012, 08:12 AM
  3. Replies: 3
