Please don't PM me with a question or problem related to this topic unless you've first posted in this topic and are having trouble after receiving an answer to your post. Posting the question or problem in this thread is much better as someone else may have the same problem or question and if you PM me for the answer no one else reading this thread will know what the answer was to that question or problem.
Here's a brief explanation on port forwarding for those that are having trouble getting clients to connect to their server.
Beta 25 - The black box that opens when you run your server is your server so don't close this!)
First you need to know the ports TS3 is using. In the FAQs these ports are listed as follows:
Default voice port (UDP): 9987
Default filetransfer port (TCP): 30033
Default serverquery port (TCP): 10011
(this part for windows users only )
Next you need to know the IP address of the computer running the server. Go to the start menu and click RUN. Now type cmd. In this new window type ipconfig and find the
IPv4 address. (see pic #1) This is your
LAN IP address. You will forward the ports to this IP address. Anyone on your personal network will need to use this IP to connect to your server.
for all operating systems)
Now go to
http://whatismyip.com/ to find your
external IP address. (see pic #2) This will appear in the top center of the page. Give this to your friends so they can connect.
Go to
http://portforward.com/ and find your router make and model. On the 2nd page select SKIP THIS ADVERTISEMENT in the top right then select Teamspeak on page 3.
**NOTE** If you only have a modem or use a fiber optic internet connection You may have to consult your device's manual or contact your ISP for more information.
Follow the instructions on this page but be sure to use the ports for Teamspeak 3 and not the Teamspeak 2 ports they have listed on this page.
NOTE: Some routers require a port range and not just a single port. Example would be 9986-9988 to open port 9987.
If this is done properly your ports will be forwarded through your firewall and your friends outside your LAN should be able to connect.
Please don't PM me with a question or problem related to this topic unless you've first posted in this topic and are having trouble after receiving an answer to your post. Posting them in this thread is much better as someone else may have the same problem or question and if you PM me for the answer no one else reading this thread will know what the answer was to that question or problem.
