Page 52 of 70 FirstFirst ... 242505152535462 ... LastLast
Results 766 to 780 of 1036
  1. #766
    November 2014
    Created a server , but no one can get in
    Thats the problem anyone can help me? i created a server , but ppl saying that message failed to connect always appear... what am i doing wrong?
  2. #767
    November 2014
    TeamSpeak 3 Server on Chromebook using Crouton/Ubuntu Linux
    I have set up a TeamSpeak 3 server on an Ubuntu/Crouton chroot on top of Chrome OS. I can successfully login to the server using a client on Ubuntu using 127.0.0.1 and it works fine, but I am not able to access the chromebook TeamSpeak server from outside of the machine. I have installed iptables and have enabled it to allow input and output of all ports. There is a chance it is using ip6tables, but I am not aware. I have set up a TeamSpeak server on MacBook Air in the past with no issues.
    -Clay Spencer
  3. #768
    November 2014
    Quote Originally Posted by clayspencer View Post
    -Clay Spencer
    This shouldn't have been moved to port forwarding. I know for a fact I was able to connect to my MacBook Air TeamSpeak server without forwarding ports. On top of that, I am forwarding ports, but it makes no logical sense to think port forwarding has anything to do with connecting from within the gateway.
    Here is the client log.
    12/4/2014 12:15:42 ClientUI Info Connect to server: 192.168.1.69
    12/4/2014 12:15:42 ClientUI Info Blacklist check ok
    12/4/2014 12:15:42 ClientUI Info Initiating connection: 192.168.1.69:9987 192.168.1.69
    12/4/2014 12:15:43 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    12/4/2014 12:15:43 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    12/4/2014 12:15:43 Windows Audio Session Debug WAS:penDevice-enter
    12/4/2014 12:15:43 Windows Audio Session Debug WAS Buffer size: 896
    12/4/2014 12:15:43 Windows Audio Session Debug WAS:penDevice-leave
    12/4/2014 12:15:43 Windows Audio Session Debug WAS::startDevice-enter
    12/4/2014 12:15:43 Windows Audio Session Debug WAS::startDevice-leave
    12/4/2014 12:15:43 PreProSpeex Info Speex version: speex-1.2beta3
    12/4/2014 12:15:43 ClientUI Info Connect status: Connecting
    12/4/2014 12:15:48 ClientUI Info Connect status: Disconnected
    12/4/2014 12:15:48 ClientUI Info Failed to connect to server, want autoreconnect = 0
  4. #769
    December 2014
    Internet Friends not able to join my Team Speak 3 server.
    My internet friends are not able to join my TS3 server. Everything is running and has been up for a little while now. It is very weird because I am able to join my TS3 server just fine with my Password and IP that I set up for the server. Please help me AS SOON AS POSSIBLE!
    Thanks a ton!
  5. #770
    2,354
    I guess missing Port Forwarding or Firewall Rules are the problem in your case.
  6. #771
    December 2014
    Wales UK
    I cant connect to my Teamspeak 3 Server from outside my router network(LAN)
    hello,
    im in a bit of a black hole....
    I decided that I wanted my own teamspeak server to be able to have fun and conversations in peace with my friedns with out the pain of a public server nuinsance.
    So I have downloaded teamspeak 3 server 64 bit.
    Set up my server.
    its accessible from within LAN, but not by anyone from out side the router network (aka WAN aka The internet)
    Im sure you can understand my frustration when even after thinking I opened all the ports by using a guide on portforward.com for my router, I still couldent connect from outside the network. Oh my life is brilliant isn't it.
    After consoulting with friends I decided to make a host on no-ip.com. Even after I SUCCESFULLY connected it to my router and activated the dynamic DNS my server just wont give up. So here I am, worn and beaten after 5 hours of forums after forums and google search and manual ....the lot. I thought I give TeamSpeak a try, once more...
    My router is a : Technicolor TG582n
    My OS is: Windows 7 64-bit (laptop)
    Any other info you guys need just ask me...I am desperate...and near the end of my tether.
    please help.
    Thanks
    Gwion
    A guy from wales raging about his server problems.
  7. #772
    April 2013
    Clients only able to connect sometimes
    I recently opened up a server on another computer running Windows Server 2011. After starting up the TeamSpeak server, I was able to connect via "localhost" and from my computer to it's external IP address. After I tried to have another person connect the server wouldn't allow anyone in who disconnected and tried to connect back. Reserved slots have been set to "0", max clients is "32", channel max is unlimited, and all ports have been forwarded with the firewall exceptions. Additionally, I do not have another anti-virus software installed on the server computer that could be blocking a connection.
    If anyone has any ideas, they would be very much appreciated!
    Zac
  8. #773
    18,151
    It's good, that a local connection works for you (even if try your external IP).
    But this does not mean, that your port forwardings or firewall rules do work.
    Compare your port forwardings and firewall rules with the LANIP.
    Deactivate your firewall or set DMZ for testing (ONLY FOR TESTING. CLOSE IT AFTER TESTS ARE DONE.).
    These are blind hints.
    Because you gave no details about any network settings, port forwardings or rules and server version.
    Thread merged
    Next time -> Please use the search feature before posting anything.
  9. #774
    January 2015
    unable to find valid license key falling back to limited functionality
    Yesterday i had my teamspeak working when my friends could join and talk. As i log onto my pc today it dosent work as it says nable to find valid license key falling back to limited functionality. This is what it says in the logs:
    015-01-26 19:04:35.124662|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.11.2 (2014-12-15 14:43:52)
    2015-01-26 19:04:35.125662|INFO |ServerLibPriv | | SystemInformation: Windows 8 (9200) x64 (AMD or Intel) Binary: 64bit
    2015-01-26 19:04:35.125662|INFO |ServerLibPriv | | Using hardware aes
    2015-01-26 19:04:35.126663|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2015-01-26 19:04:35.126663|INFO |DatabaseQuery | | dbPlugin version: 3.8.0.2
    2015-01-26 19:04:35.305117|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2015-01-26 19:04:35.350600|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2015-01-26 19:04:37.887746|INFO | | | Puzzle precompute time: 2524
    2015-01-26 19:04:37.889751|INFO |FileManager | | listening on 0.0.0.0:30033
    2015-01-26 19:04:37.960757|INFO |CIDRManager | | updated query_ip_whitelist ips: 87.115.125.228,
    2015-01-26 19:04:37.961750|INFO |Query | | listening on 0.0.0.0:10011
    Could anyone help me, I looked it up but cant resolve the problem.
  10. #775
    18,151
    The Warning is not related to your connection problem!
    Thread merged
  11. #776
    August 2013
    How To : TeamSpeak 3 Server + Windows Server 2012?
    Hi, Windows Server 2012 has installed TeamSpeak 3 Server, and router configurated port forwarding.
    I try to add rule in firewall. But incoming connections rejecting.
    <01:21:33> Trying to connect to server on ***********
    <01:21:38> Failed to connect to server
    How I need to set my Windows Server 2012 for TeamSpeak 3 Server ? Please Help!
  12. #777
    August 2013
    Quote Originally Posted by S1AnGeR View Post
    So , any tips why i can't run TS3Server?
  13. #778
    December 2013
    Brazil
    23
    Dude, check if opened the right ports. What did you do? Could you run the server without problems?
  14. #779
    February 2015
    Please Help me fast
    i just downloaded and installed teamspeak 3 to play leagueoflegends with friends
    and followed the complete tutorial about how to setup server and checked the ports with the portchecker program and all are open, but i can't connect to the server
    please tell me what to do
  15. #780
    March 2015
    No one can connect (read relevant threads)
    So I'll just dive right in, I have a D-Link DIR-850L, and I've set up a TS3 server on my laptop.
    No one can seem to connect to my server except me (even in my network), I've forwarded ports 9987, 10011, and 30033.
    I can connect through my external IP, or through "localhost"
    Here's some screenies.Click image for larger version.
ID:	12076Click image for larger version.
ID:	12077Click image for larger version.
    ---merged---
    Also, I've checked on http://www.canyouseeme.org/ and the 10011 & 30033 ports are open, but the 9987 port is not.
    ---merged---
    Not sure if this is relevant, but if i go to connection info, the IP shows as local...but i figure that's just because it connects locally to a server I'm hosting anyways
  1. SRV port forwarding
    Last Post: October 7th, 2016, 10:10 AM
  2. Replies: 1
    Last Post: May 2nd, 2012, 08:12 AM
  3. Replies: 3
