Page 7 of 70 FirstFirst ... 567891757 ... LastLast
Results 91 to 105 of 1036
  1. #91
    April 2011
    I gave my frieds my IP 76.87.38.91, can you try to connect to it if posible, to see if you can? Port is 9987
    They said they could not connect. I think i have my server up, because i see a red head icon on the bottom right of my screen.
  2. #92
    February 2006
    Texas, USA
    4,143
    I am unable to connect. If you are connected to your server then it is up and running. Did you forward the ports as individual ports or as a range?
    Example
    To forward 9987 you would do 9986-9988. Some routers require the range.
  3. #93
    April 2011
    no, but let me try that, now go and see if you can get on
  4. #94
    April 2011
    I am trying to port forward ports UDP 9987, TCP 10011, and TCP 30033 for my Teamspeak 3 server. I have a 2Wire 2700HG-B from AT&T. When I put in the port #s and give each port an app name, then press "Add Definition", it adds it succesfully, but when I go to add the port definitions to the device (my PC), an error message comes up stating "Unknown Error". Literally, that's what it says. I DID put the port #s in, and I DID give it a description, so I don't see why it wont be added to my PC. Please Help!!!!! Thanks in advance!
  5. #95
    February 2006
    Texas, USA
    4,143
    @jetboy
    You will need to find the user's manual for your device to verify that you performed the correct steps. I am not familiar with it myself.
  6. #96
    April 2011
    Next you need to know the IP address of the computer running the server. Go to the start menu and click RUN. Now type cmd. In this new window type ipconfig and find the IPv4 address. (see pic #1) This is your LAN IP address. You will forward the ports to this IP address. Anyone on your personal network will need to use this IP to connect to your server.
    what does this mean im confused
  7. #97
    February 2006
    Texas, USA
    4,143
    That step is for you to find your computer's IP address so you know what IP you are forwarding your ports to.
  8. #98
    April 2011
    6
    ok i have probably a stupid question but when i go on the port forwarding website do i choose my wireless router or the other one with the telephone and all that by the way i should mention im on a desktop upstairs and the router is connected to a desktop downstairs im using a wireless card.
  9. #99
    February 2006
    Texas, USA
    4,143
    What is your setup? In the example below you should select the wireless router.
    Example
    internet->DSL modem->wireless router-> PC
  10. #100
    April 2011
    6
    i think thats it but when you put the ip in the browser doesnt it tell you what kind of router you have
  11. #101
    February 2006
    Texas, USA
    4,143
    Once you log into it, yes it should. If you know where your router is just take a look at it. Somewhere on it will be the make and model.
  12. #102
    May 2011
    15
    Solved Failed to connect to server
    Yesterday i was on teamspeak (i am the server host) and everything was working great, people could join and so could i but a little later our router went down and everything was deleted from it, i put all the ports back in and it was fine again but today i woke up and i could not connect so i checked the ports again and everything was in order, its the same as before but now the server wont even work.
    I have everything open.
    Teamspeak server - open
    Teampseak Client - Open but cannot connect
    Ports - All in order
    I did everything i did before.
    Please help.
  13. #103
    February 2006
    Texas, USA
    4,143
    Did the IP address of the server's computer change?
    http://forum.teamspeak.com/showthrea...cannot-connect)
  14. #104
    May 2011
    15
    yeah its all good thanks
  15. #105
    11
    Server problems
    So I made a server and all but people can't join it for some reason. Can someone help me out.
    --- Merged ---
    I think the problem is my address which is currently set to localhost.
    --- Merged ---
    I think I gotta port forward. Could someone walk me through how to port forward?
  1. SRV port forwarding
    Last Post: October 7th, 2016, 10:10 AM
  2. Replies: 1
    Last Post: May 2nd, 2012, 08:12 AM
  3. Replies: 3
