Page 9 of 70 FirstFirst ... 78910111959 ... LastLast
Results 121 to 135 of 1036
  1. #121
    July 2011
    Server support
    I have just set up a new server and have given the details to a friend. this would be my IP address, password. When my friend tries to connect its saying error. i cant figure out how to put port number onto the end to make it work and noone can get into my server. please help
    Thanks
  2. #122
    February 2006
    Texas, USA
    4,143
    Format is <server IP>:<port>
  3. #123
    July 2011
    6
    ok i am stumped i have watched video after video deleted and started over and over again i can connect to my server however no one else can connect ive forwarded all the ports give them the external ip but nada and advice will be greatly appreciated
  4. #124
    July 2011
    I can't find my router between all the names, what should I do, I live in holland and have internet via a company called KPN, the box says Experia Box, and in my connaction screen it says ThomsonXXXXXX (X is just a random number). How can I find out what it is! Please help
  5. #125
    August 2011
    Friend's can't connect?
    Hi there,
    I have set up a teamspeak 3 server, but friends can't connect to my server.
    I give my friends my ip, I have open the port in my firewall 9987 as UDP.
    But they can't connect?
    Erik
  6. #126
    May 2010
    6,310
    Ok for your firewall, but about your router ?
    COuld you connect with your local IP (or the loopback : 127.0.0.1) ?
  7. #127
    August 2011
    I don't set the port open in my router.
    I can connect to this: 127.0.0.1 .
    That works, but my ip not.
  8. #128
    May 2010
    6,310
    Quote Originally Posted by Erikkk View Post
    So, do it
    More info in the first post of this thread
  9. #129
    August 2011
    Oke and do you know how I can change the connect addres?
  10. #130
    18,153
    Erikkk Please use your external IP address for oyur friends and open port 9987 UDP
  11. #131
    August 2011
    I have just recently set up my teamspeak server and started using it. After my router had been configured to forward the ports everything was working fine. I had 3 people connected (myself internal and 2 from external) and we were talking normally. Then one had a little problem with his client and had to restart. He could NOT connect back to my server. I have checked my router... portforwards are still there, i have disabled my firewall and he still cannot connect, my IPs both internal and external did NOT change. Then I though this was just with one person but my GF is now having the same problem. I have dont nothing with the clients, they are not on any ban list or anything.
    UPDATE: All users connect using the IP. My computer can also be reached from others by ping with no pakets lost. The users that are having difficulty connecting to my server can connect to the TS Public Servers with some sort of Bookmark error but it says this is always fixed automatikally! What is really wrecking my brain is that one User that was on this morning CAN connect to my TS server without any error messages however the 2 other clients still have the same error message....
    The last 2 things i remember doing was creating login data for a queryserver and trying to access the server logg were i get the error message that this is currently not possible? Could this be the problem?
    Any Ideas? Your help would be greatly appreciated!!!
    Thank you
    Marcel-D
  12. #132
    February 2006
    Texas, USA
    4,143
    If any user outside your network can connect to your server the issue is not port forwarding. Has your external IP changed?
  13. #133
    August 2011
    No my external IP has not changed. As mentioned above 1 of the 3 friends as been able to reconnect
  14. #134
    August 2011
    Server IP
    http://img638.imageshack.us/img638/4711/serverip.png
    Volledige Resolutie
    I have a problem with my new teamspeak server. My friends can't connect with the server, and I think that the problem is that the server 2 different IP's have. Can anybody say what I can do to solve this problem?
    Edit by mod
    Thread merged. Next time use the search function
  15. #135
    February 2010
    11
    127.0.0.1 is your Computer, no one can connect via that IP, cause its the same on all machines. You propably need to bind Teamspeak to your current external IP (86.92.51.142) and open the Ports in your Router.
  1. SRV port forwarding
    Last Post: October 7th, 2016, 10:10 AM
  2. Replies: 1
    Last Post: May 2nd, 2012, 08:12 AM
  3. Replies: 3
